View Full Version : Glow Engines
- Edwards 5 cyl. Radial Glow Engine
- os 21 connecting rod
- Are OS screws made of butter?
- Webra 61F Conversion
- Engine Stand?
- YS 91AC same as FZ?
- Killed my .55 AX?
- Enya .80 4 Stroke Motor problems
- ST2300
- OK Cub .049 RB model glow engine
- TT GP 40 Problem
- veco 61 has a nipple on crank case ?
- Dooling Yellow Jacket?
- Breaking in a glow plug?
- Three blade prop for Saito 100
- O.S. 55ax Piston/rod question
- HB .15 exhaust pressure nipple source
- fox 60
- sealing the head button
- how do i build a smoke muffler for a Saito 125?
- Need pipe measurments?
- Needle valve assembly parts for a Moki 1.80
- Unknown Racing Engine
- OS 120 FS III W/PUMP
- Crankshaft sizes
- PLEASE READ THIS,,,,,
- O.S. 55 AX exhaust question
- Suggested 4 stroke equivalent
- Piston Ring Question......
- A new Super tigre 3250
- Info needed for Webra Speed 50 GT
- OS FS-20 Disassembly
- New os engines for 2011I found on the the home page
- Thunder Tiger Engine parts
- Parts Lists for HB Engines ?
- FUEL TANK HOOKUP
- Crosshatch?
- Anti-vibration engine mounts - who is better
- Evolution 61 Please Help me
- Saito won't start
- Magnum Blue head vs Grey head
- ST .45 won't start
- OS FS-70 Disassembly question
- Tuned-pipe / fuel recommendations for OS .30VG(P)-X?
- remove its a duplicate
- Super Tigre G .75 ringed
- OS 1.60
- ST2300 Problem
- YS Dimensions
- "ram air" scoop idea
- Needed - OS FT120 Jugs
- Teflon Pads - OS .10 FSR or FP Engines
- Perry P-30 pump questions
- K&B 65 Sportster
- Small Glow engine question
- YS115
- Crankshaft runout
- Saito 45 Special throttle arm
- engine question please?, 0s 91 4 stroke
- CC to glow Equivalent
- MOVED: 3.3 or .26 ??
- Why so much oil in glow engines?
- Help anyone still make K&B outboard 13cc pipes??
- Renew old glow plugs
- Having a tuning brain-fart!
- Pullstart Not Cranking over engine.
- YS 1.20 Nc low speed needle?
- Is Tower / GMS ever going to produce again?
- Rossi Engines
- OS 7M vs 7H three needle carb
- Evolution 60nx for 3d flight w/ Jett / Evolution performance muffler
- Saito FA-91 rebuild
- Magnum .91 Muffler
- HP .61 info older model...
- need help with Thunder Tiger f-75s needle settings!
- Enya 40 ss - A good engine?
- Pitt-style muffler performance
- YS F-120
- OS .61 FSR,,,,
- When does a four stroke need a new ring.
- air flow
- OS 91 4 STROKE, QUESTION PLEASE.
- Pulled my Tower 46 out of storage after 4 yrs
- C-Tronics?
- Seidel product support
- Powermaster Fuels
- need reverse cam shaft for o.s. .20 to .26fs
- Bowman rings
- Saito FA-82a
- .46 Magnum XLS question
- New O.S 4 strokes!
- What is vassal?
- Fox .74 Eagle Initial Prop
- Merlin Glow Plugs, did me right!
- YS 115
- Hobby King
- Dave Shadel and YS split
- Moki 360 twin mount needed
- Broken barrel - how to fix?
- evolution 61
- asp 1.20 four stroke (Magnum )
- Do two .70s = a single 1.40
- Evolution 60NX
- How to replace a crank shaft? new question added
- Prop for OS FS 120 S III
- hi percerntage nitro jato
- Saito parts differences
- Recommend a glow plug
- What size tank for a ST90 with pipe?
- Radial made from single cylinder engines
- Wrong bearings being sold
- OS .46AX Need help!
- OS FS20 Bearings
- Wanted :Rossi 60-61 Piston, Sleeves
- Mufflers
- MODEL ENGINE COLLECTORS ASSN EXPO XII
- OS 120AX ............... What's happening??
- Evolution 61 Stalls going Vertical
- Dave Brown adapter nut
- OS Max 60 FP Needle Valve
- Webra 55 P5 heli to aero question
- KOLM engines
- ASP 400 AROwners are you flying it?
- OS91surpass breather nipple
- Rust
- Saito 180 FS Seizure
- laser engines
- OK, is this really worth this much?
- Saito 50 - what's it worth?
- Evolution 61
- TT .46 Pro problem.
- need the ball bearing link (search doesn't work)
- wanting to pump an regulate my saito 100 twin
- OS 1.20 AX Ring Reassembly Help!
- 52 Surpass oil line
- Removing paint from engine
- engines not running dead stick landings
- MOVED: G-62 slowing down ?
- Thunder Tiger parts?
- OPS Redhead bearing replacement
- YS .45
- saito 150
- ROSSI Engines and Nitro?
- Can You Identify This Engine
- ASP .40 engine
- Irvine Engines
- OS FS-90 Manual
- How loud Jett 46?
- Altering port timing/effect on power question
- SuperTigre .27 Rear Exhaust Airboat Engine w/Remote Ndl
- OS 91 Surpass bearings need replacing HELP
- OS 26 FS Rusted-In Rear Bearing
- Bull Ring Facts
- 15 years in a tomb, will it run???
- Saito 90T Twin
- best 2 stroke for a 3D profile
- ports number & displacement
- tuning O.S motor
- wen mac 049 engine
- Big SuperTigre Silent Muffler
- Geared OS300 Gemini
- need help
- super tigre g90 quitting
- 30 VG mounting bolts size
- Reversing my Royal 45
- AX.46 Bad bearings or what?
- 0s 160 twin rpm question.
- OS FS20 Rust
- Just Engines purple pipes - are they loud?
- O.S. part number needed
- OS 91 FX problem
- Torque Specs
- SuperTigre G90 and Macs Tuned pipe
- Muffler & Needle Valve for TH75 Needed
- asp 46 manual
- OS FS 91II Glow Engine W/O Pump
- Parts OS Max 80 H r/c
- RCV .91 CD & Matching prop?
- OS 95AX Tunning problum
- Independent Engine shops
- SuperTigre .61 case interchange.
- Brand New YS .45
- Saito 300 with perry VP-30
- Needle settings for a TT91FS
- Baked on Castor ?
- running out of fuel
- o.s max engines
- HB-40 PDP Performance was surprising
- Need HELP - radial Saito FA-200 R3 or Seidel 7-35 (35cc)
- Saito 125
- JBA 56F on its way
- O.S. FS-90 (vintage) vs O.S. FS-91 Surpass ?
- Question for the experts..
- Used OS .40-H Parts
- OS 91SII starting Problem
- Evo 61nx vs O.S. 65AX
- Best Inverted Glow Engines
- Saito Question
- YS 110FZ inverted setup won't Idle and Dripps fuel
- ST 3000 STOCK MUFFLERS
- How is the OS AX better than the FX line?
- Carb with Label
- Saito 150 spark knocks under power
- Gemini 1.60 Compression
- schumacher havoc engine trouble
- Saito .65 in Tiger 60?
- OS FT-120 -vs- FT120 II Gemini Engines
- piston sleeve abc an unbreakable marriage?
- TT muffler interchange with OS
- SK Engines?
- OS max 15 r/c muffler nipple
- magnum XL30RFS owners
- os .40-H ring
- JBA 56
- Jett SJ 46
- Jackal Engine??
- Bad news from Webra
- OS FS 91 surpass breackdown
- Cox/Thimble Drome fuel
- OS 91 Surpass- Bearing question
- Tower glow plug
- inverted 4 stroke
- coffee beans , castor beans?
- How many different glow engines have you flown this year
- WHAT SIZE IS "CLASS C" ENGINE???
- What alloy for unbushed rod?
- Prop hub/spinner P-47 style for ASP/Mag 91FS?
- OK guys.....One other problem
- Are 2-Strokes Behind in Weight Reduction?
- ASP Engines From Hobbypartz
- What is on your Engines wish list for Christmas?
- Central Hobbies
- searching for Data of this MVVS 6.5ccm engine
- What is the problem????
- need more help with supertigre 4500
- OS 65AX weight issues
- Supertigre 61 rebuilding and conversion to diesel
- Hot plugs
- mccoy sportsman 29 engine
- Midrange issue - glow plug?
- Best 1.2 Four Stroke
- supertigre 4500 inverted
- Anyone have a magnum 91 fs head with valves they want to part with
- Unloaded rpm of glow engine?
- 4 blade prop
- Saito Connector Rod Orientation
- Interesting Experience..w. ST.34
- buy sell page
- 4 stroke in cold weather
- Glow plug heat ranges
