View Full Version : Glow Engines
- McCoy MC-59 glow plugs
- OS 20 to 26 surpass parts, will they fit?
- can't get ringed piston to fit back in cylinder
- Help!!! saito 91 barrel stuck in carb
- engine disassembly
- hand-starting a 82 saito help
- Black residue with tuned pipe
- heat range of glow plug
- where can i get dawn power dissolver motor cleaner
- Engine head help??
- Loose Muffler on Saito 91
- What size glow 4-stroke is equal in power to a 30cc gas engine?
- evo.52
- MOVED: one way bearing issue
- Y 1.40FZ cylinder head
- G-mark 30 radial
- OS .91 DF Needle Valve (9B Carb) Compatibility
- No oil. Should I be worried?
- Looking for parts OS FS 20
- Perry Pump adjusting
- OS FF-240 Prop?
- Shimming the head on a Webra Speed .91
- SF 61 w/pump, help needed
- saito 2.20 help!
- ST G4500 dies above 5000 rpm's.
- gms 76 muffler question
- Cutting a 12-8APC down to 11.75-8 "updated"
- Norvel, bye-bye
- Bisson Mufflers
- HS needle not sensitive enough?
- Sullivan Skywriter question....
- The strangest thing you've found in engine?
- YS Pump Help
- OS .91 SZ-H Prop Size?
- distance of fuel tank
- os .25 question.
- Magnum Engines, any good?
- Saito 80 carburetor question
- os 91fx
- OS .70
- Thunder Tigre Pro: no compression
- Truturn spinner and adapter for Saito 82
- YS 61-R ???
- OS 120 non-surpass feeler guages??
- Glow Exhaust is nasty stuff, but how does it do THIS !!!
- name this engine
- Another Moki 2.10 question.
- SAITO 56 PROBLEM
- Sport prop for Saito 1.25
- OS 65 LA stops.?
- Engine Question
- Rossi R40 set up question
- MOVED: idle mix screw and idle adjust screw
- Saito .40a (NIB) what plane?
- Enya 80 4 C - Help!
- Engine Tuneing Tips . . .
- MOVED: New 18ss problem
- OPS Screw Sizes
- Independant YS fix-it man
- denatured alcohol
- Does anybody know about this guys?
- G4500 long prop adapter nut?
- MOVED: O.S. VZ-B V-Spec T w/ O'Donnell Head - New Button???
- ASP 52A Help
- best motor for my hangar 9 showtime 4d
- Stripped muffler bolts?
- MOVED: Video: Worlds Fastest R/C car 134.4 mph
- MOVED: Team Infinity .27
- YS 1.20 NC as first 4-stroke engine???
- Saito 180 compression problem??!!
- ST.90 muffler
- Moki 1.35
- Prop came off, engines shot
- cant hand start a .15 OS LA?
- low end adjustment
- MOVED: My Nitro will not start
- OS .91 FX running erratic, help
- Rich Mid- Range on ST Blue Head
- ASP .91 Red Head weird
- OS 40 FSR
- Pusher engines?
- .61 hanno ?
- how much weight can a .15 LA OS fly?
- Moki 1.8 issues
- MOVED: NICE engine
- Saito 125 excess oil out of breather
- Moki 2.10 mount?
- Need some engine advice!
- OS FX 1.60 too long on the rack...help!
- Glow Plugs
- gms tuning problem
- What's a good-idling, cool-running .30-.40 4 stroke engine you could recommend?
- DU-BRO Kwik Fill Fueling Valves
- OS MAX 20
- Ceramic Bearings for engines?
- gms/towermuffler on an os 91 fx??
- OS Max 45FSR Engine questions
- Fuel tank for YS 110 FZ
- YS 63 help - install disc valve
- OPS .21 Marine SE
- OS FS-52S
- Plans for Glow Engine
- Thunder Tiger Pro 46 Bearing Failure
- O.S. .61FSR Special Edition ?
- YS .61 2 stroke
- engine for futanaX 100
- ST G90 Question?
- fly wheel leaks
- Best glowplug for Saito 150
- WOULD LIKE TO KNOW ABOUT OS MAX FP ENGINES
- Saito 150 and Tru-Turn...
- Rossi 53 questions
- Saito 100 operating temp
- Clarence Lee ????? (glow plg thrds)
- Moki 2.1 Thread Type ???
- super custom 52 engine problem
- Mac`s Per-tuned system
- Saito 180 Question
- OPS 1.80 Engine
- Seized .65 Sportster
- Is this how you start up a glow?
- Saito 56f prop size???
- Trainer problems
- 30% Heli
- magnum 70 ring gap?
- ASP .91 two stroke
- WARNING ABOUT 1.OO EVOLUTION
- Saito FA-300TTDP Fuel Line Setup Help
- need my ).S. 91 surpass rebuilt...
- Rossi 60 Blackhead
- Webra 36 muffler?
- HELP-Magnum
- 2 motor manuals up for grabs
- Magnum 91 pushrods mushrooming
- Which .15, K&B, Magnum, or OS?
- exhaust extensions
- saito .82 losing power/ surging
- pitts muffler problem
- SAITO GLOWPLUG
- Weak Enya .19, no rpm?
- Motors
- Os 160 or Saito 180
- Does Unopened Fuel Go Bad??
- General Carb question
- Enya 80-C low rpm
- Big Glow Woes Continue: OS 1.60FX
- MOVED: tiger drive
- Stuck drive drive washer
- new evolution 52.... 2 stroker
- SK ENGINES
- Motor Comparison
- Icing down Cool Power fuel good idea????
- YS Engine Help
- Super Tigre G-2300 question
- YS FZ-110 mounting footprint
- Is RTV safe with nitro fuel?
- is there any prop charts around ?
- Running a glow engine on Gasoline???
- Moki 1.35 setup
- Saito 100 or OS 91FX
- Setting up an OS 1.60, cline, bisson pitts, 18x6w (finally solved)
- Thick wall 1/8" and 5/32" annealed aluminum fuel tank tubing
- Main needle valve setting on Saito 120
- come on I know someone knows how....
- Tower Hobbies Engines
- MOVED: Where is Evolution 45GX made in?
- Odd Taplin Twin
- MOVED: RB WS7 ENGINE TEMP???
- real powerfull "hunk of junk"
- help! engine starts,but then quits
- Saito 82 types
- ASP 108 carb help
- thunder tiger .40 muffler
- thunder tiger 75 4stroke? where is it?
- finding forum
- webra 10ccm 60 2 stroke
- MOVED: one-way bearing in my force .28 keeps slipping
- Saito 82 Breakin Prop
- OS .60 SR
- temp gauges
- super tiger engines?
- Idle Dipping
- Question on Saito 1.30 Twin
- Saito 72
- Identifying Glow Plug Heat Range?
- K&B Engine
- Idle trouble
- Any Feedback on Evolution .36NT
- os engines
- MOVED: Crankshaft for trinity Sirio .18
- O.S FT-120 Twin
- Saito FA82 gasket question
- MOVED: whats wrong with this engine
- Operating Temperature
- Priming an inverted, cowled 4-stroke
- OS FS 40 question
- Saito Carb Question
- Saito 1.00 Exhaust deflector needed?
- Inverting an inverted engine
- magnum 28 leaks from muffler
- OS Surpass Head/Header thread
- os 70 engins noise
- 4 stroke pick?
- OS .91FX
- YS 61 Two-Stroke Air Filter Suggestions
- MAGNUM 91 4 STROKE POOR RPMS
- OS 20 FP Muffler
- Enya two stroke 29/35 plug
- OS 1.20
- Traxxas nitro rusltler smoke/breaking/problems
- Moki 2.10 issues
- Saito 56 idle problems
- YS 1.40L missing at full throttle
- K&B 3.5
- A very sad day
- MAGNUM and ASP are they the same?
- Low-speed optimum setting.
- Problem tuning Irvine .53
- which engine for aerobatics? Saito 180 or OS 1.60 FX
- New engines on manufacturers future production
- TT F-54 Exhaust Pipe
- cheap tower hobbies plugs
- Help Identify Mystery Engine
- Tower 75 Remote NV??
- Enya Decals
- MOVED: Picco .12 HELP
- Pitts Plug....
- Webra 40 4 stroke ????????????
- The FL 70 4-stroke is driving me nuts
- MOVED: Hmmmm...
- Best Prop for ThunderTiger .46???
- After Run Oil ?????? Which one is best ???
- Best Plane For an OS 90 FSR Engine
- Homemade 4Stroke Muffler
- Methanol
- masterscrew or APC for 0S 160
- Dar Zeelon - Where Art Thou?
- engines
- FS-91 w/Pump or FS-120 III w/Pump
- FA 65
- idle
- OS 60 SR
- Prop for OS 120 (non pumped)?
- Old O.S. .61 SF
- webra
- Enya 60X model 7101 - carb questions
- how to rotate a carb
- Chrome coming off OS .32H Sleeve?
- Magnum .15XL
- inverted engine tank height question
