View Full Version : Glow Engines
- Inner Bearing of a TT 46 Pro
- Magnum XLS 91a muffler
- OS 46 LA props?
- WD 40 as After run oil
- Thunder Tiger F-91S
- Anybody flying a magnum .91 2stroke let me know what you think of it
- TT.46 Pro glow plug
- Moki Update
- Tower Warrenty on TH .75--Take a Look At This
- os .61 starting trouble
- Telescoping Tuned Pipe
- Irvine engine problem
- MOVED: Mega-Picco .21 Thoughts
- How to pressurize tank on OS 91 FX?
- Moki 2.10 ring
- O.S. Muffler Adapter 90 Degree #744B?
- Saito 100 Redline RPM
- Should I use thread lock on glow engine?
- OPS .60
- Help with OS 91 FX exhaust?????
- OS 32 Strip Down Stuck !!
- 4-strokr fuel vs. 2 stroke fuel
- GMS 120 and ideal prop for Funtana 90
- .28 mgt engine wont start new HELP
- O.S. MAX S 30
- Saito 100 Stuck Valve
- mvvs .40 tuning question
- ASP 70 four stroke
- fuel tank size
- Books?
- Saito 220
- Black Gunk from OS 32 HELP !!
- Your opinion on YS63
- sc 91 fs, timing?
- saito muffler thread sizes
- running engine inverted
- OS 1.60FX RPM's
- What fuel for an Enya .15?
- New ST G90's for $80?
- quick question on OS 1.08
- Rossi .90
- OS 160 FX FLAME OUT
- RCV Engines
- ST G61 ring VS ST G61 ABC
- keeps loosening glo plugs
- bad seal?
- Leaking exhaust valve
- NIB Tower .75 Won't Run
- ST 90 I thought this was real interesting
- Parts Cleaner
- Enya and Webra sixties
- G2300 low speed needle adjustment
- Connecting rod bushing
- Mounting an IronBay regulator solution.
- rebuilding a 4stroke
- MOVED: ys 110 problem
- TT 42 muffler bolt size
- Prop tips supersonic?
- Are ASP engines any good?
- Cloning O.S. Engines
- YS 91 Slimline Muffler
- Throttle Linkage Woes
- Webra .91 -vs- Magnum .91
- New OS Engines for your old ones
- Bison muffler-gasket, or not?
- WNT. Carburator for O.S 0.91
- Crock pot cleaning
- cowling vs. cooling on Funtana 40
- MDS Engine parts
- On board glow?
- On board glow?
- OS FS70II VS saito 72
- Cleaning OS 46 LA engine instructions?
- Moki 2.10 pipe with smoke, which one should I buy
- Anyone have a spare/used Crankshaft of Magnum 91 4 Stroke?
- Engine break in
- Busted Head Gasket - Please Help!!!
- What prop for a YS 63
- SUPERTIGRE 90 ultrathrust
- O.S. 1.60 FX Inverted Yes No Maybe So ???
- Glow engine ID
- MDS parts
- Priming the OS 91 FS fuel pump
- OK, I did the search...
- Prop for a TT.46 Pro
- Used Glow Engines Are to Expensive???
- Onboard fuel pump
- Saito High Cam series?
- Οppinions for OS 46 AX 2str.engine?
- OS engines users Club
- Picco .27???
- Moki 180/Glow engine
- OS MAX 80 H 2 PLUGS IN HEAD
- Need Opinions - .50 size Engine
- saito 125 mounting dimensions
- Spinning the Prop Wrong Way???
- WHAT 2 STRKS OUTLAWED??
- manual for an ASP 91
- OS Surpass .48 rebuild
- TAPPING O.S. 160 CRANKCASE
- ATF Type for Afterun
- YS regulator mod
- Tee Dee Carb body
- after run oil problems plz help
- suprer tigre G90 vs. o.s. 90fx
- Engine for GP Extra 300s 40 ARF
- ST G90 and Mac's header question
- Help with a ASP 80 4 stroke!
- Magnum XL-FS 1.20 AR troubles...
- Critical dimension to use a ST 3250
- Revive Enya 35 model 5224?
- Fuel/oil spraying on plane (noob)
- Last batch Engkush Irvines??
- Super Tigre question
- saito 125 in Australia
- OS 120 ax
- Aluminium spinner for OS 91 FX?
- 120AX..first impression
- stripped heatsink screw
- Irvine question.
- Fox .36 and .40 BBRC, series 5
- ΟS 91 FX propeller sizes
- K/B 7.5 Boat engine won't fire
- Oil Collector For the RCV 91CD
- Break in Temperature
- Hotter glowplug than 8 on OS 91 FX.
- os max fsr 50 parts?
- What do you prefer?OS or YS engines?
- Irvine .40 RE MKII
- Pump or regulator...
- Miracle vs OS F Plug in 4 strokes?
- Pump System
- What is cnc machining?
- T-80 Webra
- OS vs Saito
- Fuel tank size for Saito 1.80
- Look @ the size of this Ducted Fan engine
- Moki 1.35
- H9 Corsair ENGINE->2str. or 4str.???
- OS 60 FGR
- Thunder Tiger .46 Pro Carb settings
- YS 140 FZ info?
- Needle valve extension & cowlings
- K&B .35 rear exaust
- Is it time for a new plug?
- engine question . . .
- Are Magnum, ASP and SC engines exactly equivalent?
- Prop Indexing for hand starting
- Need Expert Help With A Saito Engine Installation
- REMOTE NEEDLE VALVE FOR OS MAX 40 SF?
- Spinner Size?
- Fuel pump to fill tank
- Evo 1.00 and pitts muffler, 2part question
- How long????
- .25 what RPM ???
- OS 1.20 question
- norvel 074 glow head leaking?
- magnum 120
- 2300 or 3250 ST
- Are Magnum/ASP Engines Compatible with OS Mufflers?
- More Power from OS 91 S II
- satisfied with performance w/o pump?
- Magnum 1.8?
- TT39 pro heli
- Magnum XL 120AR-II
- Do you have this Magnum 4str.?91RFS
- Another 40LA post
- Magnum XL 120 RFS - 4 Stroke Engine
- YS 140 FZ info?
- Webra .61
- Magnum .30 Four strokes
- Idle mixture starting point for OS91surpass
- Engine quits at high RPM
- high heat fuel tubing
- Bending a Magnum 4S elbow
- Cline regulator mounting?
- O.S. rebuild
- Is this piston normal? Black on the sides?
- Moki 180
- .46 Size Engine Modifications
- Evo46 runs poor with pitts muffler...
- satio 180 timeing marks
- MOVED: Running In Fuel shortage!
- Anybody have one of these
- Thunder Tiger Pro 1.20 question
- *Pitts Style Muffler For OS MAX 120AX*
- Prop Recommendation
- NORTHFIELD ROSS 60
- what engine for an Ace 4-120
- Magnum Engines dissapearance
- Thunder tiger or OS engines
- PROP. FOR ENYA80
- Magnum 1.80
- Saito 82 Fuel Tank Questions
- Evolution 1.00 needle settings
- Newest Saito muffler
- Pump setup on OS 160, Did I do it correctly?
- Question on carb needle settings from a Newbie.
- MOVED: O.S 12TZ 3 port
- Saito FA-150 VS YS 11-FZ
- Webra .20 Speed Marine w/ Dynamix Carb
- Glpw Plug Threads
- Thunder Tiger GP-15
- Tuned Pipes on 4-strokes?
- skyward 60 with a slim line?
- Jato??? I need help finding a air leak
- EVOLUTION 1.00 NX
- Rossi 105 Aero Engine?
- Piston
- Norvel 25 reliability
- YS 140 & Goldenrod linkage
- ASP 1.08 questions
- Older Enya Air Bleed Carb Question(s)
- help with engine choice for Edge 540t 60
- ST G-90 carb question
- Ring Replacement Question
- ST G-90 problem
- Saito installation
- OS 160 Two Stroke Questions
- OS 120 FS Pre-Surpass
- Rust problem. Now what??
- .32 SX-A to Ringed conversion
- os .12 cvx, cvr
- Inverted Engine and Cline regulator
- Using 3 bladed props?
- Norvel AME .15 prop shaft
- O.S. 91FS on H9 AT-6 Texan? Good or Bad?
- Magnum 90 4-stroke won't shut off
- Bought an Engine, need a plane.
- Has anyone put a Saito 125 in the H-9 Miss America P-51?
- Going from OS-4stroke to Webra-2stroke
- Webra 120 Racing pumped
- A SAITO QUESTION FOR MR. ROBISON - MAYBE
- More OS 91 Questions
- TT .61 engine problems
- Prop Nut Problem....
- Thermal Hopper Prop Nut
- New Super Tigre 3750
- Pretty Engines
- New irvine 53
- YS 1.40 Vs OS 1.60 Who got Power
- 3D prop for OS 61FX?
- Magnum Clubs
- YS 53 FZ problem
- O.S. 15 CV-A Tuned Pipe Question
- ys 110 3 blade
- Looking for a pitts/In cowl muffler
- break in question
- OS .91 II P
- O.S. or MAGNUM 1.20?
