View Full Version : Glow Engines
- YS-140L Question
- Please help, ASP 75 cutting out.
- Saito 82a Valve Adjustment
- Brand New .40 LA -Problem already
- O.S. 7D Carb
- Saito ID and help
- SAITO 1.80 FLEX MUFFLER
- Enya 40 ss, leaning of when vertical
- The Vmax 52?..Worth the run?
- Gasket in Saito 82a?
- Wanted: Stock (HB) Muffler for K&B Veco .19
- vq a 26 engines
- Difference between OS FX & AX ABL
- O.S. 1.08 and VP30 Perry pump
- Cussing my Saito 100
- Width of an OS FT-120
- 4 stoke without muffler
- moki big problem
- Saito .180 advanced planning
- How do you start your 4-stroke engine ?
- OS46 AX Overheating?
- SAITO 100 fule
- Rusted engine bearings What brand of fuel used and nitro content?
- O.S. .40 FX Non-Ringed - adjust low idle?
- Which enigne is best
- OS 15 LA Problems
- Any Ohlsson & Rice gurus?????
- 3D Prop for OS 50SX
- engine problems...dies on takeoff
- G90 for speed?
- *NEW* Saito 2.20 4 stroke
- Saito 65 idles rpm fluctuates
- Bearings for a Fox 40 Quickee engine
- Prop/Exhaust Combo For G2300
- Who has the best price ( and has it in stock ) on TigerShark .91
- Fuji engine parts 2 cycle
- Supertiger 90 header/pipe options
- Breaking In an OS 50SX Ringed
- Irvine .46 settings
- Video/DVD glow engines
- asp engines
- 20 Year Old OS 40 Parts?
- Saito 180 Static thrust?
- Getting a YS 110 for my Skybolt Bipe
- Moki vs Mark ?????
- new ys 63fzs engine
- Stripped out glow plug threads
- Cleaning an old used Engine
- Glow Plugs - Difference?
- 20% nitro gms .47
- SK .50
- Problems with a Saito 91
- OS 60 and what prop. for 3D
- OS Surpass 40
- Clearances on Saito 80
- Saito vs O S
- OS46 AX Stops when full throttle
- Saito break-in on castor oil?
- Super Cyclone Parts
- OS 46FX with bisson muffler - will it let out more presure.
- Need parts for ASP .91 redhead
- Help Guys, about the Webra 120 PUMP
- Will I notice a difference? O.S .46 AX verses TT .46 Pro
- O.S. .70 4 Stroke - Start by hand?
- Tower .75 Needle Location
- tunder tiger 90
- Help me Identify this Engine-Rossi?
- Magnum 70RFS prop recommendation
- How do i upkeep my engine?
- Tiger Shark .56 - Muffler question
- Saito 91 prop threads to long
- OS Max .46 DX-DF Fuel consumption
- Tuned Pipe Coupler Clamps-Where To Purchase?
- Saito 450 setup
- Laser200 engine question
- Webra 120 pump issues
- TOLEDO WATCH...for the Saito FA-220 Zeus!
- 4 Stroke Advice
- Saito 1.00 Air leak...?
- Webra Blackhead .40 spare parts
- lets see what you think
- Evolution trainer engine prop
- enya 40, model 6002
- Saito 100 Lost Compression
- Engine Info Needed
- what is the thrust of os .50?
- Saito repairs
- problem with osfx.25
- Engine Questions
- Quick Prop Question
- Nitro or Petro ?
- Broken elbow joint on OS 91 SurpassII
- Engine Woes - Evolution .46 NT and OS 40 LA
- mokie 1.8 questions
- GLow plug thread size?
- Engine cutting out. HELP!!
- OS Gemini 300 owners
- rossi .65 ducted fan manual
- Muffler
- Rocker cover gasket, none there, and it leaks
- satio 120 or 150 ..??help
- tiger shark 56 ringed Run
- I need the some Webra pros please?????
- enya throttle arm
- K&B .40 RC ENGINE
- Satio 90 prop shaft length
- Saito 180 Spray Bar
- Custom Fuel Tanks?????
- MOVED: Rudder hinge for Extra Goldberg
- To clunk or not to clunk?
- I forgot 101 ??????
- how to tell if 4 stroke is in need for a rebuild
- Evolution 1.00NX Power figures
- Low End RPM
- os 1.20 four stroke
- Timing change for Satio ????
- Saito 91 and a 13x8... expected top end RPM?
- Webra P91 vs. Saito 1.00 rpm with APC 15X6 prop and 10% nitro
- Running a Saito inverted??
- Pump required for Saito 100 3D/pattern
- Magnum engines
- webra.32 help
- Which is better OS, K&B or Super Tiger
- Magnum 4C 70 prop??
- 12 or 14oz Fuel Tank...
- OS BGX 3500 large fuel tubing?
- .91 OS 4 stroke wont idle slow...help
- Make Sure You Clean Debris From New Engines
- Tuned Pipe Header Length TT 46 and Expected RPM
- Tuned pipe question/s
- exhaust manifold modification
- Tower .46 problem?
- Fuel tank question
- What happened to the Webra Dynamix carb?
- To be or not to be: The Jett FIRE 60L and the BTE Delta Vortex
- Can anyone identify this glow plug?
- Balancing Spinner-Best WAY?
- TT120 or ST2300?
- slimline vs bisson vs OS stanard mufflers
- loop scavanged vs. schneurle porting
- What Mixture? - Fox Gold Cup .40bb
- MVVS .91
- Saito 1.50 carb spits fuel
- Satio 120 Prop??
- 3 tank setup on a twin
- GMS 47: who has one? do you like it?
- K&B Sportster .28 ?
- can I soder a muffler extension ?
- What's a good .60 size engine?
- OS 120SE Pressurized or non-pressurized setup???
- Helicoil in a stripped cranckase...
- o.s. vs super tigre
- MOVED: ducet fan for gas engine
- os .18 cvrx w/ rotary carb?
- TT120 RP
- Electric fuel pump
- OS 61FX and Pitts muffler...
- TT .46 Carb not closing
- Tower .75 engine
- Cleaning of used Glow Engines
- OS 48 4S Low speed needle valve
- NEED a .46 or .50 two stroke for Cap232
- OS 46 FX and possible bearing trouble
- I rebuilt my Saito .91 - Smoke Signals?
- 4stoke engine oil %
- YS 120 FZ??
- carbs for older os engines
- os surpass 70
- Satio 100 Prop??
- Magnum 52 pitts muffler question
- Bisson muffler
- perry pump
- OS SF .61 (not ringed) Overheating????
- OS 91 Surpass
- SC motors ????
- ST4500/good starter motor?
- Fuel tank clunk
- Helicoil for a saito 180
- O.S SURPASS
- Which prop for OS 32 on a Funfly?
- OS FL 70 4 Stroke Engine
- Enya 1.80X TN ??????
- Saito muffler loosening
- inverted VS upright VS sideways
- KB 6.5 RIRE HEAD SHIMS?
- glow starting
- magnum 91RFS question?
- Magnum 1.60FS
- Need a new 25 size???
- Purchasing Nitromethane
- what kind of engine is this?
- OS .50 SX piston needed
- 2 stroke vs 4 stroke
- Saito-100 problem?
- Problems getting Evolution .46 to run at more than half throttle
- Thrust of a Saito 72
- 15X4 or 16X4? or what?
- WHERE, WOULD YOU TAP A K&B 7.5 DUCT FAN FOR A PERRY PUMP
- Muffler for Evolution 1.00
- OS 60FX capable of a smoke system?
- os 1.60 and perry pump problems
- Magnum 70 4 stroke
- Which Three Blade Prop for Saito 56?
- What'd You have to do to mount 100 on Funtana 40?
- super tiger 61 or thunder tiger 61
- rfsmore power!
- YS-53 X H9 Funtana .40
- Magnum 91 fs of TT 91 Fs
- Magnum 120RFS low speed needle setting
- OS peeling problem fixed?
- 46 FX tuning problems
- O.S. FT 120 Gemini
- os surpass 120 fs --- with pump???
- OS .40 VF
- Magnum fuel on Saito's
- Aviastar glow engine
- Moki 210 Vs OS BGX 35cc
- Saito 80 bearing swap
- Inverted Engine Probs
- Please Advise, GMS .47 flameouts???
- question about Os 46 LA
- Engine for F20
- OK Cub .074
- 4 stroke and 2 stroke glow plugs, How...
- glow plug for .46fx
- Altitude change
- CMP Spitfire engine?
- Question about Magnum 4 stroke engine
- High speed needle setting...open 6 turn...
- Magnum 1.20 for Funtana 90
- 61FX and prop
- Magnum and O.S. 4 stroke exhaust ???
- Does the 46 Tower Muffler fit an OS 50?
- pitts style muffler
- ASP engine Distributor?
- Evo 46 Review
- Super TIGRE 75 with OS 91FX carb.
- OS 1.60 with slimline smoker muffler
- OS 20 FS SOS - part wanted
- How to identify Saito motor age by the box???
- Engine disassembly without damaging gaskets.
- Help! Perry Directional Porting and K&B 61
- Cline regulator won't work with saito 72
- Saito .65 help
- FX 46 Carb. Question
- Light Mufflers
- Iron Bay Regulator installation
- NEED M.D.S. "ADVICE"
- Need manual for Hirtenberger HP 49VT
