View Full Version : Glow Engines
- tuning problems on old ST 61series x rear exh.
- irvine 120
- Hobbico Twinstar + Magnum XL .28s -- Prop Size?
- Muffler extension or shim it...
- 19 X 5 Prop???
- OS MAX RF 61 Burned
- Perry Oscillating Pump
- Super Tigre G51 ring
- CAR engine in a PLANE
- os 91 fs surpass וו
- Heli engine on airplane?
- Tower .46 Muffler Problem
- elp hee
- pitts syle muffler for saito 180
- saito fa 100 won't start
- Best Prop Size for a 80 Fourstroke and Fourstroke Question?
- Irvine's to be out sourced?
- Super Tigre .90 Overheating
- Muffler and Silicon
- O-rings
- In cowl Muffler Question OS 91FX?
- 0.S. 91 FX problems.....HELP
- Fuel Consump. YS 120 FZ
- Need Help With Saito FA-150/450 Repair
- Saito 82 break in trouble
- thread size for glow plugs?..o.s 91 surpass
- best prop for Moki 1.80
- manual for o.s. 91 surpass..i need a part #
- Saito 1.20 gurus HELP!
- Rossi 91 F1
- Needle valve extention/Fp-40/Pt40
- Tuned pipes....... who has theoretical or practical guidance in this area.
- Exhaust extension, where can I get
- ??? for CG Sukhoi/Saito 150 combo...
- Exhaust port height?
- OS.max puzzle
- Need help with OS 48 FS Needle Valve
- BVM in-flight mixture control?
- Mark or "MOKI" 135 weight.
- Just a little tweakin needed
- Optoglo II info ?
- RCM November 1988 ?
- os twins
- 2 stroke to 4 stroke nitro mix ?
- Magnum 2 strokes
- Which FOX .15 ???
- Best prop for YS .53
- Help with new OS 61RX ....
- Engine break-in question (with/without Pitts muffler)
- Running backwards
- Magnum 120
- Can I put a Tee here?
- Mousse Can Pipe - How to Build One
- Jett 1.00
- Enya .50 CX
- which engin for wm gs p 51
- Bought a motor online- not too thrilled
- * Looking For A Saito .82*
- Need OS120 series one, parts. Can u help?
- SuperTiger 51
- ASP break in !
- What Prop is best suited to...
- Rebuilt Fox .50
- Need to pressurize tank?
- Where to buy a Moki???
- OS FS 20
- Pressurized Engine Fuel Tank
- Muffler for a ENYA 80-4C Engine
- Saito .82 best 3D prop!!!!
- where can I get a pitts style muffler
- Saito & OS 300 Twin measurements
- Question about FS-91 II Surpass w/pump air vent
- Tower muffler (46 suze) weigth ?
- moki 210
- MY TT 46 died on me i need a new engine for speed
- webra 50 gt idle tuning
- OS .46AX vs. Evo .46
- os 46 ax oil
- Thunder Tiger Pro 36 . Any good?
- OS 61 FS overhaul
- YS 120 Muffler help
- Tiger Shark 120 engine
- saito parts
- Props and tached RPM Magnum .52 XLS
- .50SX Break in prop
- OS 1.60 2 stroke
- Evolution engines 60 Prop question
- Help w/inverted Webra
- magnum 4 stroke
- WTD: List of good 3D Engines in .40'ish class
- *Fuel For Saito .72*
- hpi .25 engine NIB
- Irvine .53, carb problems?
- ANYONE FAMILIAR WITH A CF LEE MODIFIED K&B .61 TO "ABC" W/PLUG INSERT?
- Saito FA 100
- Rossi .40, .45 & .53 ...decisions, decisions??
- Running a 45 without muffler?
- prop nut for Magnum .52 FS
- Saito 100 Assembly...
- OS 40 LA
- Magnum XL 70RFS choke valve ?
- G-2300...How are they?
- New to 4 strokes
- MOVED: ROTO 35 VI
- YS 45
- OS 1.60 Questions...
- Fuel Tank Venting
- Oversizing a Tower Hobbies muffler for an O.S. 50 SX.
- prop for SSE and a Saito 56
- P-47 YS 1.40 prop size???????
- HELP! with old Webra T4 40
- Muffler for a TT42
- O.S. Gemini 1.2 Twin 4 cycle auction value?
- OS 1.60 FX (one word... WOW)
- .S. .91 on U CAN DO .60/90
- OS 160 Mousse can muffler
- OS .30 Wankel Question
- OS 46AX sound
- prop for 56
- Break-In for Thundertiger .91
- Thunder Tiger .15 ABC
- Engine Repair Services?
- Webra .50 GT
- OS 120 S III
- A question abt combining different engines and mufflers
- os 1.60 2 stroke RPM???????
- Webra Boxer 30 ccm
- I dunno but my valves vere too tightened
- how about the OS 70 ultimate?
- O.S. .52 Fourstroke question,,
- .20 size rear exhaust hi-po engine?
- Magnum mufflers
- Saito 180 and 150
- Ringed motor question...
- OS .50 SX -- Putting Back Together?
- How Much Propeller Nut Torque???
- Afterrun Oil Makes Starting Difficult
- Saito 1.80 help !!
- What prop for a Saito .82 ,,,3D
- Can't decide on a motor - 4 stroke 90 size
- saito 100 won't settle down quickly to idle
- irvine 53 air leak
- Damage from losing prop/ high rpms?
- Looking for book
- OPS carb setup
- ys 140 sport or fz
- Saito180 prop nut
- G-2300
- pump/case pressure taps
- I like my Evo 45 (trainer) but............
- Irvine 53 tuned pipe questions
- Anyone running an inverted K&B .48?
- Update on GS40 leaning problem
- OS 15 CV-A vs OS 15 LA
- OS 46 FX low speed problem!!
- Installing ring?
- GMS .76 Prop Check
- Anyone running an evolution .36 yet?
- I love 4-strokes!
- thunder tiger .40 wont start!!
- Used ASP 61 Won't Stay Running
- webra muffler
- Weight of slimline muffler for .46 engine?
- Trouble with Saito 150
- Saito FA150 carb adjustment help
- Help motor ID large glow
- Prop reamer for MVVS
- webra .20 marine needle settings ??
- Crashed Wankel 30: HELP!!!
- Help with old Fox ID
- Saito FA-100 New Can not get it to run!
- 4=stroke tuning question !
- Saito 90T twin info needed
- What glow plug for Magnum 52XLS?
- what is the best one of ys 120
- NEEN INFO ON A YS 91
- Problem building remote glow adapter...
- os 1.60
- prop nut problem
- OS70 Purchase But Which One?
- MAXTENET are you out there?
- OS 50 SX Ring Engine ?? How is it. ??
- Robart R780 Radial Engine Videos
- need engine for high alt. flying
- Spinner for Saito 100 ???
- Problems with magnum 52 2 stroke
- magnum91 rfs or OS 61FX?
- Moki 135 crank size?
- OS 61
- YS Engine users question
- GMS .47 engine that stops at midd range
- My .91 FX Runs Great!!
- Idle bars, pros and cons...
- Saito .72 Sputter ? HELP
- prop reaming
- Saito Valve Lash Screw-ThreadLock or NOt
- LOWERING COMPRESSION
- Thread locker on the air-bleed screw?
- best .61 for a extra 300s
- CH-ignition for a Laser V-twin
- Webra 50 as good as I hear??
- Inverted 4-stroke
- Perry Pump
- Need YS stock engine needle settings
- To seal or unseal my bearings that's the question
- Saito 270
- replacing saito 72 bearings
- too big?
- ASP carb on OS engine?
- Magnum XL .28 vs GMS .32 on Twin Star?
- TT pro 46 high end needle washers
- Royal 40 problems
- Exahust Pipe for Inverted 4-Stroke
- O.S. FS-70 SUrpass II, or Saito 82 for Twist 3D
- HP VT21
- Mounting a 4-Stroke on a Twist 3D
- Tiger Shark Engine Rods
- Flat spot?
- Enya .09 IV basics
- Painting RC Engines??
- Ice ON Saito Intake Manifold
- ys 120 sc
- Enya 1.55
- Inverted Moki?
- ST3250 vs Moki 2.1
- Where to buy a Webra 50
- Magnum XLS52 Muffler
- IRVINE 40 OLD - ROOKIE ON R/C
- Quick Q about MDS .18 & .28
- YS 1.10 bent crankshaft
- Old liner plus new piston?
- On Board glow ignitors
- K&B 61. Pump Problem
- Heads with Dual Glow Plugs
- Webra P5 .91
- Smoke tank size & battery size for Ultimate 120?
- Argentine motor ¨Snorer 49¨
- Saito 72 Idle shifts
- Saito 91 Flight Time
- GMS .47 transition problem
- Need a Glow Plug recommendation.
- RCV vs. other 4 strokes
- Help!! Webra 50, O.S. 50SX, or Super Tiger GS-51?
- Fuel tank height to carb centerline
- Ingenious way to protect bearings
- Should I or not?
- Magnum 91RFS Question
- Good Place to buy Ball Bearings in Dallas?
- Help reassembling Saito 1.20
- glow engine for 1/3 scale champ?
