View Full Version : Glow Engines
- Webra carb help needed.
- 29cc gas/glow engine experiment
- TT 130
- Early Saito Engine reference
- tartan twin mod.
- Questions about an OS 120 Surpass Super Charged Motor
- Adapting OS engines to pusher configuration
- saito 150 damaged
- 90 degree elbow extension?
- I may need a fuel regulator for my os120
- Glow Plug Selection
- KB .18, any users?
- YS 175 to gas prop size?
- HP 40R PR pylon racing engine
- Irvine engines
- GS 40 Bearings
- OS 40-52 FS exhaust nut source?
- os max 90 manual pic added
- OS .10FP
- Need help finding a source...
- pros&cons on the evolution 61nx
- evolution 61nx
- Saito 40 pull an LT Kadet?
- O.S. FS-95V
- CMB 65 Engine??
- Saito makes a Clicking Sound
- Question on OS 120AX
- Old Engine
- ASP FS91AR Valve Adjustment?
- Odd-Ball Fuji .09 engine
- Odd parts fit coincidence
- Dynamite Mach .26 BB engines
- Os max 60 SR mishap help
- Super Tigre 2300 CDI Ign timing w/glow fuel
- OSMax 46 FXi wont start
- Is a muffler required?
- Help with replacing Webra TN carb O-ring
- Need Cox TD .020's...Parts And Engines
- Old Glow engine question
- Rossi Engines USA (SG Model engines )
- Engine Value
- Super Tigre 3000 piston ring
- Saito FA-65 prop suggestion on J3 cub
- OS.46 FX engine
- OS 65AX ABL "rust" issue
- Bad Mufflers
- tuned pipes
- Did/does YS make a 1.80 4-stroke engine?
- Engine Exhaust Tube?
- Old Enya 60 muffler bolts?
- Adding electronic ignition to a Saito 450R glow engine
- OS max 52 surpass 4 stroke is this true
- Fox 60 Nitro Info
- Super Tigre G-2300 w/ Canister Exhaust & Xoar 18x8 @ 8,500+ (video)
- Bead Blasting
- difference in prop types
- supertigre 61
- bad engines
- asp engines
- Dexron VI full synthetic question???????????
- Webra 25 parts
- Cool Power MV fuel
- please submit your comments and pictures on your favorite .60 and .65 engine.
- Please help identify these engines
- props saito125
- OS 46AX O-Rings
- OS Pre surpass 120 issues
- glow engine setup
- Saito 125
- Glow Fuel Pump questions
- glow engine
- GMS 2000 1.20 help
- OS 61 FX
- Can't take out piston from .46 thunder tiger pro
- help with an accessory
- Cleaning a 10 year old .46 TT pro engine & carb
- Beware - eBay scammer !
- Can't remove cylinder liner!!! O.S. .32
- The first start of the day
- "New" 55AX?
- OS 70 surpass replacement muffler
- O.S. .91 FS with fuel pump, compression problems.
- YS 110
- What to do after 6 years?
- 40-50 size engine with separate oil supply?
- Ringed 2 Stroke Break In
- Enya 60 XF-4 VS. (new model) Enya 60 CXL
- Novarossi .75 SE
- Enya .90 4C Nitro % question
- Evolution engine @symbol on side-What size?
- os 160 repair
- O.S. 70 surpass looses rpms at full throttle.
- Four stroke repairs
- Glow plug question
- GMS 2000 47 NEED FUEL NIPPLE
- O.S. 55AX Vs 65AX
- Older Saito FA-120
- ASP RedHead 91 Bearing Replacement
- MOVED: Introduction to Glow Engines
- Magnum xl 180 2 stroke
- OS .61 FSR power curves
- Cox TD .020 Crankshaft Wanted
- Upgrading Cam in 4 stroke
- Hype Engines
- Crock Pot
- need help ID engine
- New ring for ST G61
- enya 1.20 4c
- Help for a Spanish friend: what this word means?
- os-60
- evolution 61nx
- Broken pushrod on lightly used Saito 100
- ASP .91 2C Crankport Finishing
- Need work done on a Webra Speed 120
- Infinity .18 engine non start
- OS70 Settings
- K&B 61 w/pump starving!!! HELP
- Is Fox Manufacturing still producing RC engines?
- Webra .40 GT front bearing?
- Strange noise of supertiger
- COX .09 HOP UP IDEAS
- Why can't walbro type carbs work on glow?
- Carb on a Rossi .40?
- New 55AX upgrade version out soon.
- Saito 82 will it fly a H9 warbird okay
- Super Tigre 2300 with Canister designed for 23cc gas engine
- Forster .99
- OS 91 MAX FX (RINGED)
- Baseline HS/LS needle settings for Saito FA40?
- Stripped threads on OS 46AX Engine Head
- Saito FA-40 tuning help
- Evolution 61NT
- Saito FA-40 help.....
- OS 61FX Piston/Sleeve
- OS 61FX Piston
- saito fa220 fuel question
- WIB C4 bearings?
- The Weirdest use of Glow Engines. is this for real?
- OS Throttle Sop Screw
- Rossi R45 Aereo suggestions.....
- Super Tigre 3250 front oil seal needed!!
- Can anyone I.D. this engine ?
- ASP S91A Idle problems
- Happy Thanksgiving everyone!
- Tarno Carb Recomendition For Cox TD .09
- CH Ignitions is back
- Zesus .61
- MOKI 2.10 help
- Weird engine/glow plug trouble
- Saito twin Flex pipe pressue tap for smoke
- Saito Rusted Guts = Lost RPMs?
- OS .60 SR muffler
- 4HP From A N/A Saito FA180!
- HP/Fuel Consumption Tests: Saito FA180, FA180CDI, FA180HC CDI BBC
- Older Saito 100T rebuild.
- Kraft 61 suggestions
- Nitromethane find
- Id and locating parts...
- OS 25AX vs 25FX. What am I missing?
- ys engine after run lube.
- Magnum 91 XL 4-Stroke Airplane Engine
- Testing the new NV (Norvel) .40 size (6.5cc) gasoline glow engine
- RCV 120 making loud clicking noise
- OS 1.20 Surpass wrist pin removal
- Saito FA-82A versus FA-82B
- asp fs180 wont run below 4000
- stuck valve..saito 60 twin
- Fox Engine ID ....
- Sullivan flex tank experience?
- Fireball Hot Glow Plugs.....
- Maxima Racing Castor 927/Cool Power Mix?
- Which is more powerful?
- Enya 46 4C-glowplug suggestion ?
- Saito FT60T help
- Laser 80
- Saito .91 rebuild, Power Point Presentation
- Magnum .91 rebuild
- 3 engines, 1 plane.....
- Removing Cooked on Varnish from an engine
- OS 60 FSR
- MDS
- K&B 9020 Engine, Need Information
- Prop to suit OS 155
- craigslist engines in atlanta GA
- 505 Internal server error!
- kool power and after run oil
- Suevia 1.50 RC engine
- O.S surpass 2 .70 HELP!!!!
- SAITO FA-56. HOW TO DISASSEMBLE VIDEO??
- Saito 1.80 Golden Knight Needs a Freshening Up
- ST engines again
- Magnum XLS46 or Evolution 52?
- WANTED OS 60 open rocker manual
- Glow Plug stem seal
- Saito 100 needle problems
- Magnum XL52/Magnum XL70/Thunder Tiger F54S?
- Super Tigre 45 Glowplug
- Are Chinese made Super Tigre engine parts compatible with the Italian made engines?
- Moki 2.10 question
- What's The problem With Photobucket PIX?
- ASP Engines
- Saito .30 What are you guys intalling them in?
- OPS 60
- shortest fasted prop for a super tigre 90
- Do Glow Plugs Wear Out?
- Everybody loves a Mystery Engine
- Old Saito 40 lost compression after attempted cam replacement
- Saito to Magnum
- Idle issues (O.S. SF 46 MAX
- COX .051 R/C MOTORS
- My glow plug thread...
- Mount spacing
- RCU Member Review: Rogeau Intake Manifold
- Making a radial out of multiple single engines
- What to look for in used 4 stroke....
- Model Engine Spitting Fuel pics
- FS110A v/s 75ax
- OS 75ax help
- Engine Speed ??????
- magnum 91 4 stroke
- Which Glow Plug for Evo 60NX ?
- Help, OS 40-FS
- Irvine .53 vs OS .55AX
- Bearing advice
- OS .61 FSR with 20% Nitro?
- Enya 53FS tank vent question
- carb for OS Max .60FSR
- ST 2300 & MAGNUM 1.08 CARB = POWERFULL NO FUSS ENGINE
- moki with cline regulator problem
- OS Gemini 160 Twin.
- Evolution PTS at Altitude - Issues, Please Help!
- Question on AP Engine .15
- Which mfg'r makes the heaviest props?
- Safe to repair exhaust flange?
- Help with Moki 1.80
- Saito 150s Intake gasket
- Strongest 46 engine
- Irvine 53 - 2 Stroke Needle settings Help
- mactep tk10 russian engine
- Attn gearhead: I fear my Saito is out of time. *Video included*
- OS FS40
- Prop. for Moki 1.80
- Webra 61
- Moki 180 Fuel problems
- Thanks to Clarence Lee!
- any tutorials out there
- engine rough when plane inverted
- New(ish) Rossi R46CR/R57CR
- NIB Italian SuperTigre GS45: Better Than Current Ones?
