PDA
View Full Version : Speed - RC Nitro Boats
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27
  1. o geez this .32 engine
  2. AquaCraft SuperVee 27 Nitro Information
  3. dynamite .32 carb upgrades ?????
  4. Pro Boats Miss Llumar
  5. RTR Class Will Run at Miami District 3 Race
  6. Grease prop shaft?
  7. should i run it in agane
  8. Looking to buy my first Boat ????
  9. where to buy flex drive n stub in OZ?
  10. Miss Bud-Worth Buying?
  11. Looking to buy a boat
  12. Kyosho GS 11 muffler?
  13. TC 31 steering suggestions please
  14. Are 20oz pop bottle and silicone adhesive nitro safe??
  15. Are 20oz pop bottle and silicone adhesive nitro safe??
  16. any do this before?
  17. flex shaft size
  18. stupid question
  19. Help! cant get Miss bud flex drive to plane/get up and go!!
  20. Tygon vs Silicon for Nitro fuel lines
  21. Dura Trax DTXM4000 fail safe
  22. Aquacraft.18 starting and tunning proublems
  23. TC31 owners, think custom....
  24. TC 31 drive shaft
  25. new boater..kills at launch..help?
  26. thunder cat 31 mod questions
  27. Stufing tube
  28. NITRO HAMMER HEADER PIPE UPGRADE!!!
  29. getting miss vegas tomorrow, any suggestions?
  30. small outrigger cost?
  31. Miss Vegas Fuel
  32. TC31 with a electric start?
  33. Miss Attitude
  34. How much should my Hotshot.45 weigh?
  35. Aftermarket 3.5 K&B Rod Question
  36. Nitro Fuel - - The ABC's Please
  37. thunder cat 31 help, boat noobie
  38. RTR rules claiming clause?
  39. prop nut for 3/16" shaft?
  40. Glueing shaft guide to polyester hull
  41. Sodering flex cable to fairow or prop side end.
  42. Fail Safe
  43. K&B 3.5 outboard lower unit - water intake?
  44. quick question
  45. RTR's a Huge Success at Broward District Race!
  46. Hydro, Cat, pics from LSMBC Spring Race
  47. More Pics From LSMBC Hawg Lk. Race
  48. Glow Igniters Pros and Cons
  49. Fuel pumps
  50. Nitro vs oil vs Methanol Mix ratios
  51. SOME PICS FROM LSMBC HAWG LK THIS PAST WEEKEND
  52. need a boat
  53. cheapest place to get the miss vegas???
  54. Flex Shaft Drive Lock for Prop Retention
  55. Replcement Exhaust Pipe Pressure Fitting
  56. Water Proofing Servo?
  57. TT Bandit 3.5cc
  58. Cat Scratch
  59. Silver bullet pipe length
  60. Plastic/Graphite Props for Nitro Boats
  61. RC Nitro Boat Starter kit
  62. Radar Guns for Boat Speed
  63. irvine 61marine eng
  64. TS2 radio box
  65. Sharpening and Cupping propeller
  66. how to retrieve my boat
  67. macs tuned pipe
  68. Octura M445 propeller
  69. Removing Flywheel
  70. 3rd Channel mixture adjust
  71. 1/12 llumar
  72. noob to boats what to get first???
  73. L.S.M.B.C. Spring Race
  74. Tunnel Championships this weekend in South Carolina
  75. Radios
  76. Publicizing races
  77. Oklahoma 2007 District 6 Race April 14-15
  78. microburst w/mac 67
  79. Looking for a prop
  80. Identify This Coupler
  81. Tunnel Hull
  82. Team Infinity 18 Class Nitro Marine Engine - ANY GOOD?
  83. What happened to the prop working sticky?
  84. Beginning racers, got questions?
  85. blackjack 26
  86. Aeromarine Mean Machine .18 RTR
  87. Pro Boat Miss Llumar Bigger Motor
  88. looking for a Nitro Catamaran
  89. Is an HS 55 too small for throttle control?
  90. Florida 2007 District 3 Race March 24-25
  91. worth a look for use in mini riger
  92. Miss Vegas legal for IMPBA Sport 20?
  93. OPS .21 vs OS .21 RG-M
  94. Waterpomp for twin nitro's?
  95. Pro Boat Miss Llumar
  96. K&B 3.5 outboard
  97. aquacraft nitro hammer- need opinion
  98. 1/24 scale hydroplane?
  99. Best glow plug for a Dynamite .32 engine
  100. Reducing Newton plans for NAMBA .21
  101. Can you cool your engine too much?
  102. How does the proboat blackjack 26 compare to the thundercat 31?
  103. Nitro shut off
  104. proboat decision
  105. K/B Rear Exhaust .21 (old version)
  106. proboat is crap?
  107. aqua craft .15 marine problems, please help
  108. converting a .45 OPS engine?
  109. Arrow Shark RC Boats?
  110. Carbon over aluminum tubes for sponson supports on a rigger?
  111. Vision Tunnel
  112. how fast the top speed 2 with K&B 3.5 outboard
  113. Digital Servos
  114. Sport 18 Class
  115. Twisted Liquid Racing SW 36 Engine upgrade?
  116. cmb .65 parts
  117. Miss Vegas Servos - Futaba?
  118. Talk about an impulse buy
  119. aqua craft .15 marine problems, please help
  120. Is there an RTS (Return to Shore) for a shockwave 36?????
  121. Refunds? How long is to long to wait?
  122. Novarossi Question
  123. removing stringers
  124. WATCH!!!Newly Found Pond...
  125. how to remove flex coupler?
  126. flywhell help 3.5
  127. Installing a Hopper tank
  128. New to boats.. a few questions
  129. DRIVE SYSTEM
  130. 1990 winston lobster boat
  131. Phase II 31" off shore victory cat
  132. Nitro supervee 27 anounced
  133. Will S3003 Servos turn .21 30" Deep V
  134. What to buy. HELP!
  135. post pics of driveshaft setups
  136. how to connect driveshaft
  137. What Pipe for OS 21 inboard?
  138. remote needle
  139. what prop do I use
  140. OPS Bearing Material
  141. What is this exhaust control?
  142. CMB pipe?
  143. Servo mount
  144. Engine decide
  145. ops .90 jets
  146. kyosho sunstorm 1000
  147. Boat for K@B 3.5 outboard?
  148. fuel proofing aquajet hull
  149. Wich is the Best Tunnel Hull?
  150. OFF- TOPIC BOAT PEOPLE
  151. What colors?
  152. Where to buy pipe mount?
  153. Well...Phooey again...
  154. K&B 21 outboard engine??'s
  155. Proboat Miss Budwiser problems
  156. making a fiberglass hull for this summer
  157. gps checking speed
  158. Rossi .21 Marine Quiet Pipe
  159. Prather, Where'd They Go?
  160. Time to build a rigger for race in April-video added 31mar
  161. Painting
  162. aeromarine avenger pro
  163. Gas To Nitro?
  164. Workshop - safe to keep engines in?
  165. MISS VEGAS PULL STARTER PROBLEM
  166. new to the engine thing..
  167. Fly wheel jet stream 800 ep now gp
  168. converting a airo engine
  169. Bad day at the pond
  170. undecided
  171. having problems with rc boat radio
  172. what brand of nitro
  173. black jack 26 catamaran
  174. New RTR hydro Miss Attitude
  175. Im new to rc's and just bought a tiger shark boat. NEED A LIL HELP
  176. Bandit Tunnel
  177. 2nd scratch built rigger
  178. thinking about building a jet boat
  179. o.s. o.b. piston & sleeve
  180. Miss Vages Bigger Motor
  181. For those that want to run A-class riggers at the OK city race in April...
  182. What wires to switch on the servo??
  183. Prop 2 done
  184. IMPBA rules.
  185. 1\8 miss bud gas or nitro?????
  186. radio problems
  187. Tuned pipe talk...
  188. Supercharged mini V8 Hemi!!! Put that in a boat!!!
  189. 1/8 scale 4 stroke hydro (is it possible)?
  190. new to nitro
  191. O.S. O.B. MUFFLER
  192. Polishing??
  193. Gonna buy my first RC Boat, need some guidance...
  194. gas sw 36
  195. pipe for OS outboard .21
  196. Tuned pipe pressure nipple location and pipe length...
  197. Flywheels...
  198. hyperformance angle drive
  199. dumas hot shot sprint v's aqua craft tunnel
  200. Help in Boat selection
  201. Skater Tunnel
  202. New HTB 290
  203. A+ Hydro, A+ Mono and RTR In Chicago Land?
  204. Miss Vegas...couple questions and a comment (updated 17 feb)
  205. 10th scale hydro
  206. RTR races in Florida
  207. Installation on a TS2
  208. Tuned Pipe Heat versus Radio Box
  209. I must be doing something right...
  210. I need a hull!!!
  211. Engine suggestion for dumas vee .40?
  212. Ballentine hobbies
  213. O.S. Lower unit
  214. issues getting motor started?
  215. Vegas Speeds
  216. AIR BRUSHING
  217. ANOTHER VEGAS SUCCESS STORY FOR JERRY DUNLAP
  218. ANOTHER VEGAS SUCCESS STORY FOR JERRY DUNLAP
  219. Ok another dumb Question
  220. Nitro Boat Fuel
  221. Strut & rudder combo for Titan 20
  222. Lil Rascal, "The evolution"(rigger video) Updated 25 Feb
  223. Radar gun for speed
  224. anyone know of any clubs in colorado or wyoming??????
  225. Help please ep to gp 3.5cc
  226. my offical scratch built .15 rigger thread. UPDATED 1/3/07
  227. What's happening in your club with RTR boats?
  228. Rossi .90 engine question
  229. sponsoon and hardware questions for a scratch rigger
  230. Crank Mod's
  231. RCPBA, Classes for RTR Racers!
  232. dumas miss circus circus
  233. Anyone have a towerhobbies discount code handy??
  234. 21 more!! Pics and 1video,of Misshydros Miss Blueangel and Miss Buds hydro boat
  235. Motor Mount Inquiry
  236. newbie building a rigger need help
  237. O.S. .21 RG-M Help
  238. Scratch built help
  239. Whats a good age for a boy to have a nitro boat?
  240. top speed 2 with 7.5cc on it plz help
  241. outrigger 7.5
  242. Another engine tuning question...
  243. Unknown hull,no markings.
  244. help..... traxxas vee
  245. OS 18 TZ vs OS 21 RG
  246. RCM, Z-Drive, MHZ Drives ??????
  247. lumar price?
  248. THE INDY MASTERS RACE
  249. Newbie Help with bj26
  250. Why are props so far behind the transom??
