PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Gear troubles
  2. .40-.46 size electric replacement
  3. Need help,
  4. Shaking motor?
  5. best brushless system ?
  6. Is it a loose bell or my brain cell's?
  7. Help with ESC setup
  8. two questions
  9. how do you disable the BEC
  10. How to program Phoenix 25 ESC???
  11. prop for a 1000kv CAN style brushless motor
  12. ESC AND MOTOR
  13. Motor on Glider Shutting off Prematurely
  14. .061 conversion- small prop
  15. Brushless Sensorless ESC Question ?
  16. Help on How to connect a battery to a ESC then to receiver?
  17. help with sword 18a brushless controller
  18. High rpm brushless motor
  19. help please
  20. Amp draw of brushed 600
  21. Motor and ESC compatability question (help please)
  22. Strange problem with throttle with CC25 ESC
  23. MY Brushless esc is confusing me
  24. $35 KA-450H...3200 k/v, 30 amp Outrunner?
  25. Best Brushless motor for Parkzone FW190.
  26. Smoking a brushless motor???
  27. Zagi Tazz Brushless & ESC Question
  28. Superstar esc on 8 cells??
  29. brushless motor question.
  30. Vortex 28/22/1380 question...
  31. Suggest Flight Pack
  32. Tower Pro Brushless Outrunners Improved!
  33. ESC Programing
  34. ESC Choice
  35. align motor What size prop
  36. New Articles on Power Systems @ rctoys.com
  37. 3dfoamy su 26-mx 3d
  38. 2 motors
  39. LOW,MID,HIGH TIMING
  40. Replacement output shaft for rimfire
  41. RC-expert 30 esc manual???
  42. Namiki micro brushless
  43. Tower Pro bmc25a esc
  44. Which prop adapter for this gearbox
  45. Information Please
  46. Brushed Motors: What does the 480 mean?
  47. Mega 22/45/3E
  48. Tower pro ESC programming
  49. How do I attach my prop???
  50. ESC Polarity question....
  51. Thermal cutoff
  52. Setup in a Vip or a Stinger 400
  53. axi motr turns wrong way???
  54. Cyclon Big Boss
  55. Motor weight to power issue. Help?
  56. Multiple Motor Control
  57. 680 Motor
  58. What gear drive to buy?
  59. mystery fm80a
  60. need help here, finding the right reciever for my plane
  61. Sig 1/5 J3 piper cub
  62. Ultimate Biplane horrible sqeel from Brushless motor
  63. Servo question - can i mix and match?
  64. any problem with this setup?
  65. Motors
  66. Motor comparison chart?
  67. wiring a motor (newbie !!)
  68. underpowering a motor
  69. castle linc set up for a HV-85 esc
  70. Question re: Jeti Prog. Card for Advance Plus ESC
  71. Tower RimFire motors
  72. How To Balance The Bell On An Outrunner
  73. Jeti 70advance opto
  74. Pageing Doctor Kiwi.
  75. Hyperion Opto 80A ESC question?
  76. Phoenix 85 HV and Plettenberg
  77. gear or direct
  78. Brushless motor suggestions please
  79. Castlelink USB Problem
  80. ESC Trouble (inexperienced) Please Help!
  81. GWS EPS350 - Shaft Size?
  82. 2 Outrunners on 1 ESC
  83. Motor trouble with Parkzone esc/receiver
  84. Hacker A20 / Phoenix 25 / Thunderbird 11.1v 2100 maH?
  85. Axi 2820\10
  86. Castle-PHX-LINK
  87. Castle-PHX-LINK
  88. Controlling Throttle
  89. P-38 Electric ?
  90. brushless easystar advice please
  91. 2 EFlight 400s on 1 phinix 60?
  92. Jeti Opto 77 versus Phoenix 80
  93. Pushing the Limits?
  94. motor controller w/out reciever?
  95. Gear/prop ratios
  96. eBay brushless combo ANY GOOD? Help
  97. ESC switch question.
  98. motor wire lenght
  99. Easy way to set thrust angles?
  100. Views and advice for first Brushless and Lipo set up..
  101. hacker b40 8 L pole number ?
  102. Long(er) 3mm prop adapter??
  103. Can someone help in brushless motor?
  104. How to hook up my ESC to my brushless motor?
  105. New to electric: Questions
  106. Thunderbird ESC Brakes
  107. thunderbird 9 NiMH/NiCD Cutoffs
  108. 3 cell or 2 cell
  109. P51 D PARKZONE
  110. WOW-RC 30A esc
  111. measuring AMPS on brushless motor?
  112. Alternative twin wire winding scheme
  113. Eglet 50
  114. HOW DO I MODIFY electric motor
  115. NIPPY Brushless Motor Wiring <HELP>
  116. PJS brushless motors
  117. DMZ cherokee 400 brushless convertion
  118. Jeti controler plug
  119. Eflite Power 46 BL
  120. P-38 conversion: Need 14*10 or 14*11 3-Blade prop
  121. phoenix 10 firmware !
  122. Gluing magnets back on the can on an outrunner? UPDATE!!
  123. Standard versus Electric Props?
  124. .46 size Outrunner! FROZE 2 of THEM!! Help!!
  125. pinion gear question
  126. Goldberg Electra
  127. hacker , astroflight or mega
  128. NOVAK BOYS
  129. Slow Stick Crash and Burn ECS up in Flames
  130. brushless vs nitro
  131. Water Ingestion & Brushless Motors
  132. need manual for brushless controler form alpha
  133. Little Screamer and E-flite brushless ESC
  134. PArk 480 Spinner....
  135. Electrifly larger brushless motors
  136. Phoenix 35 toasted --- but why?
  137. hobbyzone supercub brushless /lipo suggestions please.
  138. motor for airfoilZ Edge 540
  139. Goldberg Electra ESC recommendation
  140. Recommend system for 1/2A Shrike?
  141. Byp Yak: Switching Around the Shaft in the 370 motor
  142. What Brand is this ESC?? help Please
  143. need a list of 28mm can brushless motors
  144. Motor/esc/Prop
  145. Brushless setup for Great Planes Yak 55
  146. SlowStick AP Build up Questions
  147. Help finding a small motor
  148. no motor power help
  149. x power esc
  150. Brushless ESC questions......
  151. ParkZOne brushless power suggestions ?
  152. Waypoint ESC's - anyone tried?
  153. Hacker end play
  154. newb Himark b2025
  155. Need For Speed?????
  156. What's a BEC
  157. E-Flite Park 25 Motor shaft replacement
  158. pull to push
  159. ESC advice
  160. Running two brushless motors from one ESC
  161. Great Planes Tutor power system question!
  162. motor battery gearing question.
  163. Please help gearbox problems
  164. Obsolete Cub conversion
  165. NimH to Nicad
  166. Castle 80 Axi 4130 6s1p 3700 meltdown
  167. WHAT SIZE FOLDING PROP FOR E-FLITE 400 INRUNNER
  168. motor....battery.....prop
  169. motor....battery.....prop
  170. How can you limit voltage to a motor?
  171. motor upgrade foe edge 540t
  172. Brushed/ Brushless ESC
  173. Help! Does anyone know how to build a dynamo?
  174. Welgard Outrunners !
  175. Prop for AXI 2212/34 Brushless Motor
  176. Dualsky
  177. Axi repairs
  178. Disassembly of the Astro 020 Motor
  179. New to electrics, just a few questions.
  180. mystery 30a esc
  181. 28" Blasa Stearman Power Suggestions?
  182. Inexpensive ESC's?
  183. shock flyer on a park 370 1370kv outrunner
  184. cdrom motors
  185. Replacement Motor Help
  186. Brushless Motor For Glider
  187. prop saver
  188. New electric motor behaving erratically when playing with throttle
  189. Brushless Motor Dead ??? It just Beeps continuously
  190. Help with RX, ESC or Crystal??
  191. How to put a prop on a brushless motor?? PLEASE HELP NEWBIE TO ELECTRICS
  192. towerpro 30 amp esc
  193. prop pitch vs battery time
  194. 380-400 brushed = what brushless
  195. New to brushless, Could use some help picking the right battery
  196. PJS SFR question
  197. Help on aveox setup
  198. Torque 30t/980 Verces The Brushless Motor 400T
  199. GWESC35 amp problem
  200. need a prop and motor combo
  201. Brushed ESC
  202. twin himaxx 2816-0890/phoenix 25/tp 2100 advise
  203. need a gear box for slow stick help!!!!
  204. Need a 400 speed brushless replacement for direct drive
  205. tango 45-08
  206. I am CONFUSED!!!!!!
  207. Aero-Nuts (Tower Pro) 30 Amp Generation 2 ESC...How To Set It?
  208. Newbie needs some advice
  209. jeti esc problem
  210. What motor is this?
  211. Brushless??
  212. Electric Fly ESC
  213. HELP WITH POWER 10BL
  214. please give me some upgrade options....
  215. GWS brushless equipment?
  216. Running a brushless in reverse
  217. Help! I need a dimension for a E-flite Park 370 Outrunner Motor?
  218. I am new to Electrics
  219. Ultrafly b/06/15 grub screws
  220. air channel designed motor, very light, high efficiency
  221. To much or to little ESC????
  222. brand new esc,, i dont know how to set it...please help.. raiden-tech
  223. ESC problem, plz help!
  224. Question About Motor Gear Drive
  225. holes in LiPo after crash
  226. Will this work?
  227. Nippy 29S-7A172 vs. AXI 2204/54 Anyone?
  228. phoenix25 programmed ?
  229. Help with brushless
  230. How much will a standard 370 with 6.60:1 fly?
  231. [ELE EC28P]-A motor deserves to recommend.
  232. BP-21 outrunner, heats up with no prop on!
  233. quad mount 4 rimfire
  234. Mini Slinger ( Which brusless motor )
  235. Anyone know what ESC this is? Please?
  236. hysteresis or other effect
  237. Park 450 outrunner - 12 amp or 14 amp continous?
  238. 3.7 mm prop adapter?
  239. HELP WITH ELECTRICAL SYSTEM OF PLANE
  240. Brushless Motor Cross Reference??
  241. What makes brushless better than brushed?
  242. Jeti ESC -77Opto - Programming - Help
  243. Some usable data
  244. motor prop battery combo?
  245. Cross reference from glow to brushless
  246. prob with programming Eflite esc
  247. Four bladed electric prop needed.
  248. Ultrafly brushless upgrade
  249. finding radio and drive components
  250. BRUSHED ECS
