PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. hysteresis or other effect
  2. Park 450 outrunner - 12 amp or 14 amp continous?
  3. 3.7 mm prop adapter?
  4. HELP WITH ELECTRICAL SYSTEM OF PLANE
  5. Brushless Motor Cross Reference??
  6. What makes brushless better than brushed?
  7. Jeti ESC -77Opto - Programming - Help
  8. Some usable data
  9. motor prop battery combo?
  10. Cross reference from glow to brushless
  11. prob with programming Eflite esc
  12. Four bladed electric prop needed.
  13. Ultrafly brushless upgrade
  14. finding radio and drive components
  15. BRUSHED ECS
  16. Motor for flapping wing
  17. Tiny Airplane Power Setup
  18. Sig Little Something Extra
  19. Why is Distributed LRK the mode of our madness?
  20. Power for Guillow 172
  21. RC smart 30A ESC
  22. Jeti 'OPTO' ESC
  23. Brushed vs. Brushless
  24. Phoenix 60 cuts off when throttle reduced
  25. Question about Motors
  26. 2408-21 pusher
  27. Brushed motor life?
  28. Programming the Aero-nuts BLC-30A ESC - few questions(cut-off V and brake)
  29. Ultrafly B/12/10 Amp Draw
  30. Trick R/C Zagi 20 cutoff voltage??
  31. Hacker A20-20L Prop ?
  32. gws esc motor stops at full throttle
  33. TMM 2512-3s ESC Manual
  34. EP 42 E-flite upgrade?
  35. Great Planes ElectriCub brushless conversion?
  36. Please Tell Me if this is a Good Motor!
  37. How to tell motor size?
  38. brushed or brushless esc
  39. the sound of to much prop???????
  40. brushedesc or electric
  41. Need help with prop selection.
  42. motor help
  43. Which ESC?
  44. 4:1 gearbox
  45. calling all electric gurus
  46. brushed motors
  47. Motor Shaft Replacement?
  48. How hot is too hot? Brushless outrunner/esc
  49. Wattage Inline Gearboxes, Anyone??
  50. Brushless Motor and ESC's...
  51. Geared 480 to AXI Conversion Mount Question
  52. ESC only works on certain recievers
  53. Multipex easy star speed control swap
  54. 3500 RPM per volt motor ?
  55. Castle Creations Esc only emits one beep - HELP!
  56. Newbie Speed Controller Question - Does it have trim?
  57. Is there a 2808/24 Axi stick mount?
  58. Need help!
  59. X-16 ESC HELP
  60. Two motors: How?
  61. LV Alert...a device showing low voltage?
  62. Hacker C50 15L Gear box?
  63. Cogs on Gearbox keep stripping
  64. Pusher motor converted to puller - How?
  65. Brushless or brushed motor as generator?
  66. what is a great speed controller to buy?
  67. brushless Esc in a boat
  68. Inrunner or Outrunner - E-Flite Min. Ultra Stick
  69. GWS Products
  70. Motor for slow stick
  71. Jeti Jes 25 ESC / 500 Brushed Motor / 1500 AMH LiPo
  72. Help with old ESC
  73. Folding Propeller, please help.
  74. need advice with MGM compro easy25
  75. RC Smart Brushless Outrunner motors
  76. G2 TOWER PRO 30A & 15A brushless controller
  77. Brand name and source for motor needed
  78. Graupner Tipsy Speed 280 motor upgrage
  79. Aveox 1817/4Y
  80. Motor Running Rough (Ventura)
  81. cant start walkera 60 dragonfly
  82. Bad brushless motor?
  83. best brushless set up
  84. Brushless Setup Advise Needed
  85. problem with GS ICS-300 speed control??
  86. A Bad Day :( Is this an ESC problem?
  87. Prop/ Gearing way to much heat. HELP!!
  88. Mega 22/30/2 PROP RPM AMP data needed
  89. speed controller problems
  90. hi guys need some help with this
  91. Dymond-RC Gunther 16/15/3 BL MTR??
  92. What is brand name of ESC A60 ( forbrush motor)
  93. problems with esc and computer radio
  94. Brushless meltdown?
  95. Ultrafly brushless
  96. Hummingbird motor
  97. Brushed vs. Brushless esc???
  98. Brushed esc with Lipo battery?
  99. Has anyone heard of Dynam Brushless motors
  100. Brushed Motor Size Conversion to Brushless Motor Help Needed.
  101. Sharing my source for cheap brushless motors and controllers
  102. New PZ Stryker 27C or Upgrade?
  103. Programming Castle Phoenix-10 with DX6 radio
  104. Typhoon 6 motor with lose magnets
  105. Littlescreamer PP
  106. Brushless On HZ Firebird Freedom
  107. BP21 prop
  108. any harm in under-propping an outrunner ?
  109. 3 cell lipo for GP EP Corsair?
  110. Now that's Hot!!!
  111. Brushless Motor Timing ?
  112. the kv rating on engines
  113. tower pro esc help
  114. tower pro with boat?
  115. HEEELLLLPlease: Thunderbird 18 Beeps
  116. Looking for replacement motor for Yak
  117. What is "Lipo"?
  118. Help with brushless controller
  119. Robbe RSC890 ESC Programing? HELP!!
  120. brushless speed controller for hacker a30/28
  121. question about c-20 ESC
  122. opinion on battery/esc/motor
  123. Static current draw
  124. AXI Shuts Down at 65% Throttle
  125. Help with skyscooter setup
  126. Help with capacitors, please
  127. Newbie - Confused about Amp Ratings!!
  128. Rimfire and Thunderbird ESC
  129. RXs ?
  130. Hyperion sales?
  131. Anything wrong with Aveox?
  132. Problem with Great Planes ESC
  133. Heli-max speed controller setup
  134. Gotha 229 help
  135. What BL Motor
  136. easystar help
  137. What motor, battery and esc do I need ?
  138. Which ESC for a 14.4v Lithium battery?
  139. BP-21 Motor shaft
  140. baja micro motor in a gws drive
  141. putting deans connectors on brushless motor
  142. Multi-Motor Brushed to Brushless Conversion- PBY
  143. I was wondering if I might be smarter to by a 35 amp or even a 45 amp ESC
  144. I think I need a gearbox for my 550-600 motor
  145. e flight mini ultra stik
  146. Kontronik Maxi Dancer
  147. Lancair going brushless?
  148. Most power for 1 1/2 ounces.
  149. Which Propeller
  150. Electrics, HELP needed...!
  151. Going Brushless
  152. ESC price/ESC amp rating
  153. CC Phoenix-25
  154. Hacker A20-20L has rough spot
  155. Jeti JE 180
  156. Guillows F6F
  157. AXI 2820/10 HOW MUCH CAN YOU PUSH THEM ????
  158. e-flite ESC won't program. Help me troubleshooot.
  159. Battery help
  160. Broken Brushless Motor- Salvageable?
  161. RC SMART Brushless ESC Programming HELP
  162. Take apart MEGA 16/15/3
  163. Flying Styro P-38 lightning twin brushless setup
  164. Electrifly ESC
  165. ESCx with on/off switch?
  166. New to brushless motors/ESC, where to start?
  167. difference between brushless esc and sensorless brushless esc ???
  168. Zagi Tazz Brushless motor problem
  169. Motor Cutting off Problem
  170. GWS ICS600 and Motor Shutdown
  171. 550 Brushed to brushless
  172. Gearbox for park 380 motor???
  173. Prop Suggestions for Cessna and Brushless
  174. Tornado ESC.
  175. Ultrs RC brushless motor fix do these come apart?
  176. Need Brushless/LiPo suggestion for Hacker Helio Courier
  177. Brushed motor with li-po's...what ESC??
  178. jeti advance problem
  179. Tower Pro Esc
  180. Which motor for a fast small warbird ?
  181. FW-190 Motor Problem
  182. What propellor should i use for a 1530KV brushless?
  183. Hacker noise
  184. Bench testing - max ampage being pulled?
  185. brushless burnout
  186. R/C technology in a powered paraglider
  187. Top Creations contact #
  188. ESC PROGRAMMING
  189. Who Sells NUE Brushless motors...
  190. BL-8 ESC by Great Planes
  191. motor calculator numbers???
  192. E-Flite J-3 Cub ARF
  193. Help, ESC confussion
  194. Sensorless Motors and Compatible ESC's?
  195. esc
  196. two escs in parallel? P38 lightening
  197. Polks and Nippy 1608/160 brushless motor?
  198. 430L keeps freezing. help
  199. pz decathlon..brushless conversion
  200. Walkera 36 Heli motor problems
  201. T600r motor
  202. CC Phoenix 25 vs Thunderbird 18???
  203. Hi Discharge Battery damage Motor or ESP?
  204. BL Powerhouse for Multiplex FunJet wanted
  205. RC Smart 30A Brushless Speed Controller
  206. Anyone know the specs on these?
  207. Align ESC fried
  208. Maxi motor
  209. AXI Silver 2208/20 prop?
  210. DuraPlane CONVERSION TO ELECTRIC
  211. esc problem
  212. MS119 controller---Jeti Opto 77 Advance
  213. Quick question on 430L
  214. Futaba 4YF Radio System - is ESC compitable
  215. best plane for park 450 bl outrunner
  216. HANGAR 9 Piper J-3 Cub 40 Conversion
  217. AXI magnets glue-mount weak?
  218. help. need information about pinions
  219. Deans Micro Plug: Max current?
  220. Is it ok to use a 35A ESC when all I need is a 25A ESC
  221. Everything was working fine and then . . .
  222. Getting noise interference or hits??
  223. esc great planes red light
  224. Anyone using the 3D Hotwind motors?
  225. break in on a brushless
  226. Electric motor power ratings
  227. Hyperion motor etc. setup enquiries for two e-sailplanes
  228. First Brushless Setup Question-Help
  229. prop question for 430 brushless
  230. What does KV stand for?
  231. BL-8 or SS-8 ??
  232. Astro brushless motors ??
  233. ebay outrunner
  234. What gearbox for my Mega 16/15/3???
  235. Hacker newb questions
  236. gas to electric ?
  237. Which MEGA motor do you recommend?
  238. 1/4 scale edge 540
  239. Prop savers and larger electric motors
  240. Sermos / Anderson Powerpole?
  241. Castle Creations Pheonix 35 Issue...
  242. Castle Creations Pheonix 35 Issue...
  243. hacker b40 8s on 11.1v lipo?
  244. Mine will be bigger than your !!!
  245. How many cells for an Astro 15 geared?
  246. Wiring a Mega 16/15/4
  247. Brushless for Kadet EP-42
  248. Great Planes Spectra ARF Sailplane
  249. HELP. Problem with my BM2408-21
  250. question about ESC specs and servos...looking for sugestions as well
