- p120 sx low rpm
- Jetcat P120SE
- Turbine start during flight
- Correct FOD Screen for P-70?
- ECU ???
- ECU battery
- Twin Turbine Setup - 2 Channel Question?
- P160SE Temperature Error.
- Dry bearing pre-lube
- Jetcat stops responding and flames out.
- P 80 Kero / Case problem
- Help for a french student project
- Question about max Kerosene with Turbine Oil (Method)
- Help identifying Jetcat part
- P-70 Case Screw
- Just got my Titan SE back from JETCAT. Won't start.
- Teach ecu to the rc system
- P160 temp probe acting up
- Fuse able Link
- JetCat Customers!!!
- Solenoids
- LiPo power pack2S 7.4 3300
- lazy P-160
- Titan starter question
- Turbine oil
- 25hr service
- Titan Flame - out ...??
- acceleration slow on a kyrostart p120se
- P-120 Hung Start
- P80 RPM
- Serial numbers have been lost!!!
- Using the I/O board with built-in charge plug
- P-200 kero start question....
- Titan Starting gas ?
- p 200 take of flame out
- Kero start plug..
- Kero start rundown..
- P-80SE putting out little flames
- 120 SX
- Oil leaking from tail cone
- P80 Front shroud
- Ject Cat instal kit battery..
- P-120 Inverted Mount
- Kerostart accesories..
- futaba P60se fail safe
- Titan general questions..
- edit
- P160SE - Is it safe????
- Jetcat serial numbers
- p60se limits menu
- help with 160SX thermocouple/temp?
- Suppressing electric "noise" from fuel pump?
- P-80 RPM for 17# thrust
- Titan SE max rpm 109000.
- SPT5 troubles
- use of aviation fuel in P120
- P80SE blowing glow plugs
- P-120SX battery question
- Jetnet's P200 FOD screen
- P-200SX
- LOW IDLE RPM vs MINIMUM RPM?
- A123 again
- 120SX running temp
- P80 ECU V2.0 manual
- fuselage
- P70 GSU Reading
- P80 - where to see total runtime hours?
- Warranty info
- Starter P80
- P-120 ECU Problem
- Any news on a new small JetCat?
- P-70
- P120SX start temperature
- ECU compatability
- Fried My ECU
- P-180 and P-200 SE?
- P80 problem
- P80 problem
- Propane start question
- P-120SX
- P-70 Kerostart intermittent ignition
- P60SE hunting at idle
- Turning up a P-60
- P60SE flames out on throttle advance..
- p-60-se
- serial numbers
- Noo start, ignition timeout
- JETCAT SERVICE
- Starter O-ring on P-80
- FTE 500 solenoid issue?
- P-60 pipe gap JL F16 1/8
- new P80 SE start failed and pump issue
- P-200 pipe gap
- Futaba 12Z P-80 SE fail Safe question
- bearing of JetCentral SuperBee
- P70 position
- JetCat RPM surging, popping, flameout if accel too hard
- Idle up
- Old P-80 Specs.
- ECU & A123
- V5 vs V6 ECUs...?
- P-80 will not turn
- P120 Service problem
- P-60 starting problem
- P70 smokes on startup
- P80 Ecu wiring identification
- P-60 with possibly ingested some fine sand
- P160sx & P180 true weight, fuel burn & accell?
- Need advice on a P120 SE
- P 80 OVER RPM LIMIT SHUT DOWN
- P160 serial 0521
- P-60 first run. Questions..
- I didn't sound good... P-70
- P-60 ecu question..
- titan se wont start
- Need help with a new P-60
- More power from P60 ?
- Jetcat P60
- Old P120 Upgrade
- P70 startup issue
- new 160sx - instructions?
- Quick question about the starter...
- P-200
- starting problems at 7000 fts ASL
- P70 - Battery Warning???
- P-80SE start issue
- P 80 RPM
- P80
- P-80 Start-up Troubleshooting :(
- help help asap
- Titan SE and hi temp?
- Degassing/Ventilation of a P200 - with strainer mounted !
- P80SE FOD Screen installation
- P70 SE Anytime Soon!
- ECU Compatability.
- 120SX Start up
- P80SE acceleration time
- Surging during throttle up.
- JetCat GPS
- Fuel Pump Question
- f16
- What Type of ECU Battery Do You Use?
- P-80 Won't auto-off.
- P120sx + FEJ F-16
- Mr. Matt.....help!!
- P80se Help
- P80 "HiTempOff" problem
- P80 Smoke on throttle up
- Thrust # on P-80
- Calibrating EGT on P80?
- I replaced the thermocouple
- 160SX engine mount / false plug problem
- P70 Temp eror
- Titan with 11.1V LiPo
- thrust tube for P-80se vs P-70
- p80 question?
- 120 SX - possible issue??
- Fuel flow direction on fuel pump...
- Bob Wilcox's email address wanted.
- Gas mixture setup
- P80 Won't throttle up
- Jetcat 120
- P-180 SX
- p60-lazy yellow flame at startup
- P70 temp sensor
- Starting problem on P70
- P-70 Questions / Bypass Installation
- P-70 specs on JetcatUSA vs JetcatGermany
- Battery Setting
- p160sx smoke setup
- Important Note regarding used P-200s for sale in SoCal
- P70 cool down problem
- A123 with ECU V6.0
- P120 non SE
- P-120 SX question
- Hi Temp Starts in Airplane - P-80
- Problem with P60SE
- Titan conversion
- P 160sx start issue
- P-180 pump voltage
- SE Serial Number Information
- First 120-SE serial number
- thrust tube collapse
- P70 motor starter in auto off problem
- Cal Jets question for Bob or Matt
- Temp recalibration?
- Fuel pump
- Low revving P80
- Fuel purge on 160 SX
- Switching to 2,4 ghz Fasst
- SX plumbing question
- 60SE sticking bendix
- Li-ion 2 cell for ECU
- solenoids
- PHT 3 problem
- A123 ECU
- New LED I/O Board
- JetCat P-80 Aceleration help
- kangaroo queston
- P120sx problem - no heater?
- JetCat P160SX only starts if model is inverted
- Inertia of rotating parts
- Something really weird happen ( Jetcat Titan)
- High start temperature
- Is it time for new bearings. In P120??
- P180 FOD guard
- Jetcat thrust pipe??
- Increased fule consumption?
- Jet Cat 120 SX
- Kangaroo mount availability
- P-60 upgrade
- JetCAT LCU (Light Control Unit) Manual ???
- ECU voltage
- P70 Error code and subsequent self destruction
- P-180 Kero conversion problems
- JetCat new LiPo Battery
- AWESOME JETCAT SERVICE
- Starter Motors
- P120 SE no screen
- New P60 FOD installed photo
- THR/AUX on ECU wtih dual RX's and Batteries
- P60 converted to kerostart, problem starting it
- A123-1100 MAH 3S ECU battery packs ?
- 9303 DSM failsafe
- Is my temp sensor knackered?
- P-70 missing screw
- P-70 to pipe gap
- Kerosene ignitor orientation, all models
- Air gap between nozzle and bellmouth
- p60se question
- P-160 SE SX
- JL Snowbird with P70
- P200 starts funny or not at all with Ver 6.0o
- spool up sputtering- cold weather?
- SMOKIN FUEL PUMP
- Twin Turbine Operation
- Jetcat P70 Dimensions
- ecu 160SX
- P-60 w/ ECU V.5.0 and 2 cell Lipo
- P70 will not start
- P-70 Kero different battery booster pack
- P70 data cables
- p-60
- Lipo balancer connector
- Different with 120se and 120sx
- Help, my JetCat P200 is leaking
- JetCat P-60 Question
- How red hot is your tailpipe
