PDA
View Full Version : JetCat Turbine Direct Support
Pages : 1 2 3 4 5 6 7 [8] 9
  1. Winter storage
  2. GSU Question
  3. Jet cat P60
  4. Test smoke valve
  5. Air BP 2389 use with Jetcat?
  6. Fuel pump/ECU
  7. P-160 "Slow Acc"
  8. electrical noise reduction
  9. p-60's ?
  10. P-120 inverted start overheat ..
  11. P-120 shutting down again????
  12. P80 funny sound
  13. P120 start problem
  14. Kero Spool Problem
  15. D@mn fast shipping - thanks John!
  16. Set up and install for twin
  17. Charging ECU Battery - Harness
  18. P-120 ECU and ECU Battery
  19. P-120 & Pipe/bypass separation
  20. P120 Shutdown Problem
  21. P80 Acc. Slow
  22. P-120 intermittent start failure
  23. P-80 trouble
  24. 160 blinking red light
  25. Questions About Fail Safe Set Up
  26. Mk2
  27. P-80 High Temp Shutdown
  28. P160 eats plugs
  29. P-160 FLAMEOUTS
  30. No cool down P160
  31. plastic box ecu v.5.0
  32. P80 Shutdown
  33. Slow P120 throttle response
  34. P120 quites on the ground after flight
  35. A "dink" in a P-70 case
  36. P-60?
  37. P-70 FOD Screens?
  38. Bad fuel milage on P80
  39. P80 POSITION IN BYPASS
  40. Failsafe Setup on 10X with 4.9-5.0 software
  41. P120 Overtemp
  42. TME smoke pump
  43. P80 Questions
  44. quick disconnects on speed sensor lines ?
  45. New Nozzle
  46. JetCat USA has moved!
  47. Festo 6mm-4mm reducing fitting
  48. Pitot GSU settings?
  49. Filter orientation
  50. help
  51. P80 thrust increase to 19lb
  52. Starter / Glow Cable Shorten
  53. P80 temp going nuts
  54. Pitot questions
  55. HP5 overtemp
  56. Jetcat 160 swap
  57. ECU fuel consumption calculation ???
  58. P-120 throttle response problem.
  59. Fuel Fail ECU message
  60. GPS/ECU interface
  61. p-70 POWERFAIL
  62. P-120 Problems....
  63. P160
  64. P-160 I might have a problem
  65. More important stuff
  66. Important JetCat Information!
  67. P80 ecu Question
  68. turbine r/c car *update*
  69. 2.4 GHZ downlink system?
  70. Tail Pipe Question
  71. P-70 Spool Time
  72. HP5 Flames on start up
  73. P120 starter motor problem
  74. P-80..ECU 2.0? Would you fly with it?
  75. Sophia Jet Cat ECU noise
  76. P-120 solenoids
  77. P-60?
  78. Great service - THANKS!
  79. WooWoo pipe on a P120 ??
  80. P-120 placement in bypass
  81. Speed Sensor Question
  82. P80 in a R/C car
  83. P-80 Failsafe Operation
  84. starting fuel ??
  85. Turbine Oil
  86. P-120 Fuel Filter
  87. Hotspot on a P120 ??
  88. P80 ECU Software Versions
  89. P-70
  90. P-120 Troubleshooting
  91. P-70 FOD screens
  92. Polarity?
  93. Propane Tank question?
  94. Lithium ECU Batteries
  95. Component Pricing
  96. Hey Matt
  97. P-70 Power Increase
  98. jetcat canada?
  99. Newb thinking about getting into turbine aircraft.
  100. Engine history?
  101. P80 STICKING
  102. Noisy Starter Motor on P-80
  103. P-80 exhaust?
  104. How much do the instructions cost for your speed limiter ?
  105. 4 mm tubing
  106. speed limiter question
  107. Jetcat 12lb. turbine
  108. P-70
  109. question about p 70 or p80 engine
  110. 160
  111. Speed Limiter Housing
  112. Smoke at startup between main housing and nozzle
  113. P-80 start problem
  114. Connector
  115. Tail pipe sizing
  116. auto starts
  117. Learn R/C teach the ECU
  118. jet-tronic single action valve set up?
  119. What Size Bypass and Tailpipe
  120. P120 powered go cart
  121. One switch operation ?
  122. Jetcat ECU 4.9 and 5.0 Question
  123. A few questions.-
  124. JetCat ECU vs. 2.0
  125. Jetcat Plumbing
  126. P-160 Fuel Pump
  127. Jettronic software for CE ??
  128. P-120 flame out
  129. Propane Valve
  130. HP5 load limit ?
  131. p120 ques
  132. P120 Spool up time excessive
  133. Startup procedure - pls fill in the blanks
  134. Oil for the p120
  135. P-80 4.9 ECU FAILED STARTS?
  136. P-120 IDLE FLUCTUATIONS
  137. Start up problem on my new P-120
  138. ref JetCat UK
  139. Jet Cat 120 Crashed
  140. Hey Matt
  141. FOD SCREEN FOR P-70
  142. We are back.
  143. P-120 PowerFail
  144. Failed Starts
  145. P-70 THRUST vs RPM CHART
  146. TEACHING THE ECU ON THE P-70
  147. CALIBRATING THE TEMP PROP ON P-7O
  148. P70 or P80 (for Roo II)
  149. RS232 computer interface
  150. Clarification on P-160 measurement
  151. New P-160 Upgrade Info!
  152. Current draw of Jetcat P-120?
  153. Resetting v4.0 Ecu, P120
  154. P-160 Upgrade Program
  155. Jetcat G-70
  156. Jet-tronics for windows
  157. Fuel & Turbine Temps
  158. Cool Down Timer?
  159. Mr. Matt...
  160. Smoke warning during fail safe
  161. Startup problem
  162. Version 4.9 ECU
  163. P70
  164. P-120 smoke question channel
  165. P80 & SS pipe
  166. Kerosene start turbines
  167. does my engine need service ?
  168. Spool Up Time P80
  169. P160 question
  170. Smoke connection on ECU
  171. I keep calling JetCat and there isn't any answer. Are they still in business?
  172. P120 not gernerating max RPM
  173. P 120 has inconsistent max rpm's
  174. Anyone in Alaska flying Turbines ???
  175. Charging jetcat ecu battery with Schulze charger?
  176. ECU 4.9S version
  177. JetCat Internet Support
  178. I need help to program my Futaba T9CAP to run my P80
  179. P-120 Thermocouple Trouble
  180. P-120 ECU/Battery Switch?
  181. Why did it flame out?
  182. P-80 shuts down
  183. HP5 exhaust pipe size
  184. Life of a turbin
  185. Starter motor runs when battery is plugged in
  186. rpm - thrust chart for P-80 and other ?'s
  187. 160's
  188. Setting max rpm for P 120
  189. P160 starting
  190. Single Channel Operation
  191. Emergency shutoff
  192. Product Alert!! Please Read!
  193. Mobil Jet Oil II
  194. weird temp. readings
  195. Warning...Warning
  196. Idle speed p-80
  197. Transfer to RC control
  198. Jet A
  199. recalibrate with single channel
  200. Safety wire on fittings
  201. How old is this P-80
  202. order update
  203. ? about price increase
  204. Need Jet Cat Help!!!!!!!!
  205. Airspeed Sensor
  206. Exahust Tube
  207. Need a P-80 owners manual (2.01 ECU)
  208. P-120 do not start after ECU upgrade.
  209. Jet Cat Service
  210. Turbine placement in bypass
  211. 160 shipping delays?
  212. which starting gas?
  213. Propane start
  214. Fuel consumption question
  215. Motor mount bolt pattern
  216. Air pressure tap from a 120
  217. JetCat GPS Unit
  218. P-70 & Old BVM F-86
  219. HP5 Gearing Upgrade
  220. P-120 under cover gas Festo fitting sealing?
  221. Connecting ECU to custom datalogging MCU
  222. Jetcat p70?
  223. Jetcat software question
  224. HP5 Max Rotor RPM'S
  225. Turbine Oil
  226. o ring
  227. Fail Safe Setup
  228. HP5 Manuel
  229. Jetronics for Windows
  230. JetCat ECU Failsafe V4L Instructions
  231. ECU Question
  232. Use of new gen BP 2197 turbine oil
  233. Starter Motor Assembly
  234. Jet Cat P-120 Low RPM Shutdowns
  235. flight data readout
  236. JetCat Turbine Support Equipment
  237. throttle curve
  238. p160
  239. When to send in an engine on a boo boo
  240. P120-Source of RPM signal.
  241. Algae
  242. ground school..etc..
  243. Some trouble getting it to 'light off'
  244. flame out
  245. Cat Scratch Fever
  246. Question for Mr. Matt
  247. P-80
  248. Pre-purchase Inspection P-80
  249. are older ECU's upgradeable?
  250. aborted start ...
