- Vintage SupreTigre motor identification/info
- ENGINE LEAN BY IT SELF WITH LOW FUEL HELP
- Turning the spraybar EITHER direction to lean the midrange.....
- What is the best glow plug for the ST .51
- ST 2300 Compression
- start 20/23 cc ST !
- .61
- GS-40 no start
- 3250 mid-range problem
- GS-40 runs lean no matter what?!!!???
- 3250 and pump
- 51 Muffler bolts
- Spun Rod on G-27CX on Warhead after 3 tanks of fuel..
- 2300 0r 3250
- G90 muffler question
- G-90 Won't pull fuel into carb
- 91 power
- Need Bearings for S75
- What is the weight of econo muffler
- Super Tigre G 21 .46
- Can a ST75 carb be installed reversed???
- Prop recommendations
- ST3250 Starts Backwards
- Gasket Set for ST3000
- G75 Idle Stop Screw and Vibration
- Super Tigre S29 Ring
- replacing the bearings on st
- No More 4500
- ST3000
- New ST 75 Neecle Valve Problem
- need muffler for .75
- G90 needle valve O-ring
- New ST .90 and Old Muffler
- ST 75 Break In Discovery
- ST 3250?
- Super Tigre 2300 or 3250 ??
- GS2300 Noise
- G2300 / G.20-.23 Muffler
- distace head-crankcase
- Super Tigre 3000 questions
- Super Tigre Saturno 60 carb
- Exhaust deflectors on G2300 ?
- Fuel Tank Size for G-2300
- ST-45 Carb Sticking
- ST X45 RE ABC Ring break in procedure
- Super Tiger mufflers
- Remote needle on a 2300
- SuperTigre mid-range mixture adjustment
- Super Tiger .90 prop sizes:
- SuperTigre S90
- ST2300 new buyer
- ST S-29 Problems
- What to expect from an early S 45
- Chinese ST's history and redesign
- General Spraybar question
- G51 won't run consistently
- ST G90 transition
- 3250 idle problems
- *G-2300 Question*
- bullring 46
- G2300 question (muffler fuel pressure)
- G90, I got a bad one :-(
- 2300 Runs great, but still stumbles occassionally!
- ST4500 thrust
- Italian made ST .40s
- g-51 question
- GS.40 spraybar
- Any Info on the 3750 Yet??
- st200/25
- G500 Parts! Where can I get them? What fits from other Supertigres?
- g2300 carb question
- G-90 is giving me FITS!!!!!
- 3250 Air Bleed?
- G-51 Fuel Leaking Around Head
- Super Tigre 90 Made in China
- Will Muffler Choice Affect Break-In?
- ST 2300 carb barrel
- *G90 Tweaking*
- OLD super tiger
- Spacer for 2300 exhaust
- ST 2000
- ST 90 sputtering sound
- *G-2300 Prop Size*
- Need Help Tuning ST 2300...Please!!!
- Fuel Line Size For 2300?
- ST 2000
- an OLD
- SUPERTIGER 3250 FUEL LINES.
- 2300 Head (Machining Issue)
- st45 muffler
- g51 compression problem
- 2300 drive washer
- G2300 exhaust bolt spacing ?
- G90 over heated
- G2300 problem...
- G-90 break in.
- G 90 Vibration Problem
- G90
- Having break-in troubles with Super Tigre GS-45 ABC
- St G-2300 questions...
- G-90 break in
- G75 won't stop
- ST 2300 too lean with pitts?
- ST 4500 Carb
- Super Tigre Muffler problem
- ST 91 X?
- 2300 and 4500 questions
- ST 3750 info
- Exhaust Extension For ST2300???
- 1980 G20 SuperTigre Engine Help
- ST 75 Muffler Spewing Aluminum
- GS45 help get it started again
- Super Tigre 3000 G & S?
- super s 90
- .90 supertiger heli engine
- Fuel for G90
- SUPERTIGRE .40
- 2300 Carb sticking
- Super Tigre G45 w/pitts muffler what Prop to use on Aeroworks Edge 540T .40
- MOVED: G90 for speed?
- ST 2300 Dead Stick
- SuperTigre G90 15x4 Prop
- G51 drive washer assembly, how to?
- Cant get a ST???
- ST2300
- "BluePrinting" a Siertigre 40 ringed.
- Is there something wrong with my ST 75??
- ST 2300 in a 3D craft
- ST 2300
- G 75 4*60 prop
- Shaft size question
- G 20?
- St G 90
- Perry Pump on a ST2300
- Running Problem with ST engine
- Tigre 6000 and others
- ST2500 info
- Fuel for ST G2300?
- st 90 difference
- ST 3000 Bearing Change
- "Sweet Spot"
- Oil for G90
- g-45
- G75 Top Flight Header
- High speed Needle valve
- g 2300 problems...
- My ST-S90K stops only on the ground??
- S.T. 4500 slop
- S-2000 Muffler help
- G-75 Glow Plug
- Super Tigre 2000/3000
- Hangar 9 150 P-51 engine recommendations
- Broken piston on my G90
- GS45
- Why buying a G51 instead of a GS45?
- Where's the 4500?
- ST g-90 Ring inverted???
- Top Flite header for g75
- GS40 glow plug. which one?
- G.90 performance
- G-51 disassembly
- Super TIgre parts needed'''''
- ST .90 Questions
- G75 for speed use
- G2300 prop for 3D
- G 90 3 or 4 blade prop
- SuperTiger 46
- Detailed Dimensions for ST-G75 Ring
- Supertigre needle too short to exend past cowl
- PERRY PUMP on ST 4500?
- Supertiger 2000 2.5 Manual
- Low End Screw
- 2300 lean top end
- G4500 performance?
- G51 ring and UCANDO.46
- G90 Question
- ST-3000 Head
- ST34
- 2300 Running Backwards
- Removing liner on GS 40
- ST 3000 Compression
- G 90
- *ST G51*
- G 90
- High speed needle
- after info on the 2300
- G3000
- Supertigre 75
- G2300 Liner Position
- ST G90
- G4500 for T/F Giant Corsair?
- ST .61 rpms
- G500 mimipipe
- Tigre Bluehead question
- G4500
- ST 3250 carb
- Carburetor Parts compatibility
- G 90
- What prop for a ST G51.
- Spray Bar adjustment on ST 3250
- ST G-90 midrange
- S 29 Glow plug recommendations
- ST 2300 Fuel
- The carb barrel on my newly purchased G90 will not stay set.
- supertiger 2000
- Supertiger S-90 gaskets
- air bleed screw on ST 2300 ???
- G-3250 Crankshaft split/cracked?
- ST 2300 Pipe recommendations
- SuperTigre Tuned Pipe model?
- Vintage ST G60 Serie X
- G-2300 Engine Mount?
- break - in G90
- 3-Bladed Prop
- Carb spraybar update?
- G90 Muffler
- G90 port timing
- G-2300 Prop size
- S40K ABC carb question
- Super Tigre .90 Ring, first Impressions.....
- Supertigre rings
- ST 2300 high end won't richen
- Super Tigre Carb Question
- Bearings for S-61K
- 2300 Drive washer removal
- Stalls
- Super Tigre x.45 parts
- ST 75 Exhaust
- Super Tigre G-3750
- 3000, K, 3250 pump for remote tank
- Super Tigre .25
- Super tigre 2300
- ST .40 (blue head)
- Can I run a 3250 on alky/oil without nitro
- Super Tigre 90 status.....
- ST G75 2 stroke- Ideal WOT RPM?
- The right Prop for ST 2300
- Old Super Tiger
- Super TIgre G90 has problems!!!
- G500 minipipe-rattle
- 3000 Carb insert
- Super tigre 90 overheating
- Muffler or header pipe for ST X25
- 2300 Carbs
- Super tigre 90
- cylinder & ring for older S.T. .29
- ST 2300 questions
- Parts for G 60 Bluehead ?
- super tigre 3250 ring gap
