View Full Version : Tips & Techniques
- soldering landing gear
- Table plans
- Ultrastick .60 w/airtronics rd8000
- Matt finish on iron on film
- Cleaning color smears after monokote covering
- splicing balsa fuselage stringers
- Disposable epoxy mixing palets
- Learning Aerobatics
- Improvisational Monokote Field Repairs
- Decals - What's best
- threadlock plastic compatible
- Removing bearings from small electric motor
- Recover exhaust soaked balsa?
- aircraft 3 views
- Prather engine drill jig
- Fiberglass Cowls, How do you fix 'em?
- MODE 1 TO MODE 2 ON SKYSPORT 4 ????
- Solartex trim
- What is the best way to put on stickers/decals???
- Bending tube
- epoxy finishing resin with sig koveral?
- Filing a flat surface on L/G
- Need to reverse a brushed motor
- No more messy planes
- music wire?
- Using servo extensions.. tips needed
- DYI RC workshop project
- Making Spring coil L/G
- can I mix 5 min with 30 min?
- mounting mini retracts
- vinyl graphis like "rapid Tack" from home stuff?
- Servo Setup on Elevator Halves
- SOLARTEX USER - HOW TO APPLY DECALS?
- Using Ambroid
- Aerial Video
- ys engine
- Paint
- How to locate an engine on firewall with built in offset angle?
- How to Secure Nyrod in Firewall?
- CA glue removal
- Dubro pinned nylon hinges
- TURBINE
- Trailer Question
- need help on tail wheel
- PAINTING WITH KRYLON
- Removing "Spray Foam Insulation" on Plastic
- YS 140 DZ fuel problem
- 6V Battery Setup
- Fuel Proof Paint
- Need tips for making cowl blisters
- Which Covering to use?
- starting an inverted 4 stroke engine.
- Take-off dollys
- Floating Undercarriage Mounting Plate
- Repairing Nylon Pinned Hinges?
- Easy way to fiberglass
- Avistar taildragger & other mods help please
- Laser Level to align wings and stab
- Saito 125A - 3 bladed prop?
- Carbon fiber pushrods
- Elevator servo
- reparing foam core/fiberglassed wing
- Balsa Skinning Help
- Removing Epoxy
- CA all over my new bird...HELP!
- Monokote attachment to wing saddle
- keeping four stroke muffler on
- Glo plug connector
- Alarms in trailers
- Landing gear problem related to landing gear block in wing
- Rubber bands to bolt on wings
- Finding airleaks in retracts, check the tank
- Your muffler ever fell off ?
- Help scaling up from plastic kit
- Prop Stuck on shaft--Help!
- Another way to hold those muffler extention pipes on
- Applying Monokote/ Ultra kote
- Fuel tank upgrade
- Elevator halves & prop.
- Is there easy way to remove ailerons, elevator and rudder??
- Paint match?
- Covering repair
- LED MARS light
- .40 P-51 retracts
- Flying Fields In North Of Englandy
- Building From Plans :'(
- How to polish Rustoleum Metallic Paint?
- Teather Lines
- Using Light Balsa filler
- Drilling out the holes in servo arms
- parting agent
- STRUTS & LG FAIRING
- How to cut out monokote from the airplane?
- Repairing Fiberglass Cowl...
- Rustoleum paint over plastic film.
- Weathering.
- Engine Test Stand
- 45gx2 install help on a h9 extra 260
- Getting Ultracote to stay down?
- Fuel proofing flight/field box question
- servo mount bushing
- Tinting Plastic Windows
- Magnetic Board HELP?!?
- Terminating Antenna Wire
- 4* 60 CG help.
- Finding CG on Biplane
- Videos
- Can micro-swithes sequence gears & doors? HEP ME!
- Getting your spinner to shine
- Make your own Incidence meter from cheap laser
- Make your own Clamps
- Bomb drop and fuel proof materials?
- Plane Transportation in Open Bed Truck
- How To Grind a Flat Spot on a Landing Gear Wire
- Horizontal Stabilizer strut
- Will PPG Clear Coat Eat Model Paint?
- Detail Airbrush Needed
- Saito 30s bearing removal
- Canopy Painting??
- hinge glue?
- Cheap Depron reinforcing
- What type push rods
- Paperclay
- What covering should i use
- trike to taildragger conversion for LT40
- my wagon flight box/ catchall
- Flush Cutting Saw
- Orange peel
- Solvent for epoxy
- Dry-Rub Transfers?
- Watch out for that prop!
- Air compressor and paint gun
- How to remove hardened reszen
- filler
- Plane Stand with CG balancing tool
- Removing Thin cyanoacrylate (CA)
- Syncronizing servos
- .06 glass
- Hobbico Sealing Iron setting
- PIN-STRIPING .....whats best.....
- Loose your Muffler end
- Perfectly round cowl opening
- krylon painting/ fuel proofing?
- Strongest 1/4 20 nylon bolts
- clearcote over Lustercote???
- How to improve better paint adhesion on plastic covering?
- WARPED FOAM SHEET WING
- Cheap tools
- TIGHT WING TUBE FIX
- ultracote \oracover
- wet methanol
- Monocote puckering, help!!
- Monokote Trim solvent.
- Cricut for cutting monokote
- WD-40 - Removing sticker adhesive.
- installing tail groups accuratly ?
- Paint compatibility(what works over DOPE?)
- Glassing help
- The Amazing Scroll Saw Paint Shaker
- How to repair foam core wing
- How do you cut a Cowl?
- dual fuel tanks how do
- How do you make a scale hinge line?
- Airbrush Help
- "Glassing" firewalls
- Foam Glues
- sig koverall over balsa sheeting?
- Cowl Trimming...
- DZ 160
- STRYKER NATION
- Engine Mount drill holes
- Interior finishing
- Help Identifying Flight Box Parts
- Need Wing Saddle Help Please
- Spray Painting
- stop fluid filter leaks
- Threaded rod 4-40 Double
- Design New Shop AKA "The Spouse Avoidance Zone"
- Linkages, Horns, EZ-connectors, Z-bends Etc.
- DIY Nav Lights
- Gas Can
- What paint to use??
- YS Plumbing
- Plexyglass + epoxy = ?
- Cleaning for epoxy repair?
- Silk Covering
- cutout in glassfibercowling
- Sirius Charger glitch?
- How to clean varnish off a glow engine?
- Need PGP paint match
- wheel pant help needed
- CA Glue Building Tip
- great use for monokote iron!
- Lighted tape
- KlassKote over Latex
- Get a Grip
- New Building Table
- Building flight box
- what removes residue from balsa
- How To Make a Plan Transparent
- Vinyl trim sheets
- lost muffler pieces
- Re-Covering Question
- Balsa Storage Please Help
- Dust collector
- how to stabilizer guy? Help?
- MonoKote checkerboards
- Fiberglassing Techniques
- JR VS Futaba
- Free plan - starter
- Finishing TF P-47 fuselage, how to sand.....
- oil question
- transfering piece shapes from plans
- Airplane setup tip on JR 10X Heli Radio...
- Sanding table/hood
- MPI On-board Glow System
- ARF Repair
- great planes 1/3 pitts, radio?
- styrofoam safe gold color paint
- REPAIR CA SOAKED STYROFOAM
- Models with ligths
- Help, covering Guillows P-47
- Question on props
- Attaching Giant scale Windshield...?
- Insulation?
- Keeping connectors together?
- Extending the battery wire
- looking to make prop for fun
- How to make N numbers?
- Which paint to use?
- Is there a system for using lasers to align parts during construction?
- Laser printing on Monokote Trim?
- sheeting foam wings.......
- Tightening props on cheap plasic spinners
- covering the holes
- Hoerner tips
- What paint for polyurethane over glass finish?
- Plane and Wing Storage in Minnesota
- cheap retractable landing gear
- how to install a remote glow plug adapter ??
- Preserving Gorilla Glue?
- Bending landing gear wire
- help on installing canopy windows
- How do I install dual aileron servos???
- Rubber -Seal RS-588 Clearcoat
- Camouflage Painting
- T Pin Parts Holddown
- Gear doors?
- Sig AeroKote problems
- Hidden Hinges Made Easy
