View Full Version : T-Rex heli
Pages :
1
2
3
4
5
6
7]
8
9
10
11
12
13
14
15
16
17
18
- Cheaper alternative for trex600 batteries.
- A123 4s battery in my T-Rex
- t600 nitro v t600 electric
- CF Blades required for basic 3D ?
- ordered a copterx450se v2
- HS-81 Cyclic Servos for Trex 450?
- Trex 600e
- One way bearing shaft stuck - CX450SEV2...
- Align battery issue-puffed?
- Align Trex 600 Nitro Pro. Combo Version Kit help please
- Help... Trex 450 SE with Esky HH gyro?
- question on trex se v2 main gear assembly...
- need to replace 450 se v2 tail blades.....
- trex 600 elec & nitro
- align RCE-BL35X ESC trouble
- Help...new 430xl motor will not turn
- Trex 450X on Ebay
- Battery Question...Align 22c 2100mah
- Trex 450S Question
- First inverted hover
- Servo Speeds for T-Rex 600
- Help with soft start JR Tx
- Trex 450 identifiers
- 325mm CF & FG blades, check these prices
- New Trex 450SE Owner - What Accessories?
- Questions
- Trex V2 - C rating question
- Anyone trim the long wire on the G401 Gyro?
- Batteries
- DX6 and 401 Gyro
- Do they make servo savers?
- Trex 600 Swash mix
- 450 s
- Trex 450SE V2 + Trex 600CF Twins Combo
- batt. /ESC. Question
- Trex 500 blades hard to find, here's a source
- tail pitch slider linkage ?
- New T-REX 450 SE V2.Need help.
- Tx
- Align RCE 35 ESC Problem
- sloppy 450 Swash
- Feigao 80 amp on t-rex 600
- Is the SE V2 heavy?
- New unhappy T-rex owner
- Battery ?
- hot battery
- SE V2 comes in silver or black: Where exactly are they talking about?
- What's best online deal on on a T-Rex 450 V2 SE?
- Servo wrap for my Trex 500
- GY401
- stripped all four servos!!!
- swash plate position
- What's the diff. between these 2 Align blades?
- clutch question
- Need help finding a alum main rotor head assy or parts
- autorotation question...
- battery tray.....
- new trex 500 boom problem
- Need Recommendations - TREX 450SE V2
- R/C Heli Blade Lubricant?!
- My Modded 450 cde Flying Around
- Choices
- Choices
- Benefit of multi rotor head (3, 4 & 5 blades)
- 500 swash mix question
- Tail drift and no wag question
- quick reciever question
- What's a fair price for this Trex package?
- trex 450 download
- I need a walk-through please....
- tail boom question....
- need help please....
- Tail mechanism question
- What is the diff in a SA or SE?
- T REX 450 SE suggestions
- Need to Replace 2 HS65-HB servos...What should I buy?
- HeliHobby has the Trex 600N Super Pro!
- Fitting out a 600e
- Fuse
- Gain setting with a DX-7?
- First crash! TreX450 v2 Help!
- My first flight of the season!
- Max payload for a T-Rex heli?
- Travel Adjust Question
- Cant get the motor to spin up =(
- Shopping for new batts
- No more tail strikes
- Recieved my Trex 600N Pro today!!
- New Bling For my T-Rex 500
- T-Rex 450SE, or T-Rex 450SE V2?
- Logitech 2100T gyro issues
- Align esc problem??
- Strange electronics question
- Scorpion electric motors
- 450V2 Mods
- Finally had a chance to try my tach: Video
- Swash Plate Question!!
- Logictech 2100 gyro is really nice
- is this possible or it's just my sight????
- LHS in Las Vegas
- new ESC smell?
- what would you buy,,this or this
- How to install servos?
- It appears the 450 has been "Cloned" to death,...But..??
- T-Rex 450SE Case
- Wherre to get (true) custom canopies for TREX 450 - DON'T say RCHOVER.COM!!!!
- rex 700? for real?
- Last try to get rid of tail wag, 450 SE V2, ?'s/help
- Trex 600 canopy
- How much should I expect to pay for this configuration?
- Need help bad..Trex 450xl ccpm.
- Flybar question
- tail spins out of control anti-clockwise? help please
- Nuts & bolts supply for helicopters?
- Fuselage
- Whats the best battery for Trex 450?
- Just got my Trex 500. Need opinions on......
- gyro under main shaft
- Chargers
- Trex 450s sticky collective ???
- JR 500T gyro problems in T-REX
- Anyone tried these blades for their 500?
- Main/Tail gear compatability
- trex 450 headspeed with this set up...
- eagle tree logging system
- swash plate
- ESC's.........
- lipo maintenance
- Need help with pitch
- power/esc glich
- Trex 450 V2 Blades for stable flight
- Where can I get this Align Belt HT1003T?
- How to replace belt in T rex 450. Belt coming off why???
- E-Flite Blade 400 or Pigeon 450?????
- Align charger
- Need good source for Trex 500 blades
- battery connector
- how do you know when a tail belt is slipping????
- Best price on a Trex 500?
- Casatle Creations Phoenix 35A ESC Issues - Please Help
- Balance plugs????
- Tail up/down
- I have a problem
- Gyro for T-Rex 450SA
- MaxAmps Batts
- Trex 600 differences.....
- Quad Blade Head.
- T-rex 450SE GF + DX6i
- Just finished second TREX V2 Build - Pix of My Fleet
- Ready to make the jump! Axe Cp to T-Rex
- Problem with RCE-500 Gyro Set up
- TRex 500 losing power - opinions?
- question about gain in GY401
- Need help with tail wag......
- digital servo on a gy401
- T-Rex SE V2 batteries?
- T-Rex 450 se v2 stock flight times?
- T-Rex 450 SE V2 pack for biginer (what do you think?)
- Outstanding service from CY Model!
- Tail wag problem
- Flting the T-Rex 450 in the house?
- question about balance in t-rex
- Crooked main gear ?
- Difference Between T-rex 450 SE and SE V2
- Help with blade tension
- Charger - DN G2 or FMA/CMS
- Stripped threads on aluminum tubes in Boom Block
- Lifted Tail For T-Rex 600?
- Tail wagging at a hover......
- swash plate won't rise or fall on mainshaft
- Trex 450 tail drive gear
- 500 and 450 hover question
- T-Rex 600 CF Landing Gear Info Needed Please!
- 450SE V2 and S Tail Belt Drive Gear
- Trex 450...today...
- To lube or not to lube that is the question
- Tail drift in HH mode on TREX V2
- Radio gear for 450 v2 se
- What batteries is everyone using on their TRex 500's?
- Help DX7 setting end point adjust tail servo
- FMA charger power supply?
- soft start or problem? 450 SE V2?
- Common parts in T-Rex 450XL and SE V2?
- How to get my battery ready for spring flight
- CHARGER ADVICE NEEDED
- My TREX 600 Maiden!
- does anyone know the HDX 450 V3???
- what is the advantage of the CF tail boom??
- Cable to run two batteries for Trex 500
- Purchase of Main Rotor Bladesfor T-Rex 500
- best electronics and setup for 600 Electric...
- just finished my build again
- DS-285 servos on T-rex 450 SEV2
- T-Rex 450 V2 Question
- longer trex shafts
- T-REX 450 electric layout
- Setting up Futaba 9CHP for 3D???
- different length t-rex main shafts for belt cp
- 450 xl canopy rubbing issues? maybe this could help
- help with t rex 450 sa
- T-REX 500 - Awesome video!
- SE vs S
- How important are tail boom braces for light flying
- protek batteries?
- Main Rotors, POP, Detachment from Head......
- A place to find Trex manual (kit version)
- Good TREX Heli Sim that works with DX7??
- Consistent Glitch
- TRex 500 or TRex 600?
- Looking to get a Trex 450, this a good price
- +/- Pitch
- Head Button Function? How to re-attach?
- T-rex 450se v2 & 14.8v 4s ???
- Trex tail servo and gyro help
- need some advice is this a good buy?
- T-rex 500 and Sim
- Fresh Paint
- New T rex 450v2 need simulator bent main shaft first fly
- ESC or motor?
- Best motor for scale t-rex 450 using MD500 fuselage
- New video - garage hover again
- Trex 450 or Trex 500
- TREX450 for good price..............
- Question about tail system's compatibility
- Just rebuilt the head and ?
- 450 se V2 or 500cf?
- Product Bulletin: Spektrum QuickConnect Voltage Recovery System for DSM2 Air receivers
- Which Complete Tail Assy. Do You Like Best
- Swashplate levelling and setting
- Amps?
- Metal Tail Drive Gear Assembly Blue
- gyro ?
- T-Rex 500 batteries
- Throttle/Pitch Curves for 450sev2 with Fuselage
- TREX 500 QUESTION
- Advice
- strange attitude while hovering
- rcmachine, Anyone have experience w/ this company?
- A123 bettery for a Trex 450?
- New MD500 Fuselage installed and Flying on TRex450
- E-Flite Charger 2-3 Cell 7.4-11.1 with T rex 450 battery
- Align Charger, Align blades
- T-Rex I built for my brother-in-law
- New buddy with T Rex 450 v2
- Rex 500 swash problem
- Looking for Bell 222 Scale Fuselage for 450 Size
- MegaPower and Deans connector Help...
- Cheep batteries for trex600e
- Crash and problem
- Soft Start option in ESC No governor
