PDA
View Full Version : E-Flite Helicopters
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32
  1. Dead Servo?
  2. E-flight
  3. Need Futaba 9C setup for CP Pro
  4. BCPP grip mixer mod!
  5. Better BladeCX2 Charger?
  6. Help
  7. lift problem with cp
  8. blade cx2
  9. preflite blade cx-cp flight sim. for sale
  10. BCPP wiring???? help
  11. E-FLITE CNC HEAD W/ HORNET 3D??
  12. Throttle trim hover advise
  13. esky 11.1v lithium charger safe?
  14. CX 2 WHAT SPARE PARTS TO KEEP ON HAND
  15. pictures finally up
  16. post pics of your DarthDrk bodies
  17. CX2 stock charger ???
  18. Tail rotor question on Blade CP
  19. CP cents
  20. Blade CX spinning out of control
  21. Help got a drifter!
  22. Upgraded Blade CX2
  23. outer shaft bearing
  24. lipo battery resistance vs charge amount
  25. CX2 Blades UN-balanced?
  26. CX2 4 in 1 failure. Just Me or are these just junk?
  27. new to heli new to cx2, questions...
  28. Upgrade your Blade CX2
  29. Installing seperates in CP
  30. Autorotation Set up
  31. Will these batteries work for BCPP?
  32. POSSIBLE? Wiring a li-po or Nimh battery in TX
  33. The best Blade upgrade is a programmable TX!
  34. CX2 Buzzing Sound
  35. Help with my raptor
  36. does upgraded tail esc make difference
  37. real flight 3.5 problems
  38. Almost gave up on CX
  39. CX2 4 IN 1 UNIT TOUCHY? DELICATE?
  40. CX2 FLIGHT TIME FIXED!
  41. wobble?
  42. is my retaining pin gone?
  43. LiPo + 10T experience
  44. Is my receiver bad?
  45. spektrum DX7 and blade CP PRO
  46. John Adams Setup/Smoother Collective BCPP
  47. what pinion?
  48. Move up from CX to CP?
  49. Lama V4 vs. Blade cx2
  50. tail rotor control on cp pro?
  51. returning from a break... blade vs zoom/shogun
  52. what kind of battery for cx2
  53. Do You Believe OUT of the BOX SUCCESS ?
  54. cp rx favorites
  55. help cp pro will not arm!
  56. CX2 battery life? HELP!
  57. Spinning BCX2
  58. upgrade to bl, now tail's not holding... :'(
  59. Is my NEW CP PRO broken? HELP!
  60. brushless set up and question
  61. Upgraded Blade CX2
  62. Brushless Motor Wiring Question
  63. upgrading to brushless on the Blade Cpp how easy/hard?
  64. fuselage for blade cx
  65. like new..aluminum modified cx2 for sale !!
  66. brushless and crash damages?
  67. CP vs CP pro Blades
  68. From the BOX to a CRASH in 2 minutes
  69. Blade CP Pro - Tail Boom Removal
  70. flight time ?
  71. HeliHobby Upgrades
  72. Servo list and experiences
  73. What Next....Looking Ahead!
  74. CX2 Forward Flight ?
  75. Walkera 60 canopy fits great on CP pro... photo incl
  76. cp pro questions
  77. CX2 Vibration Problem
  78. Blade CP problem..
  79. preliminary break-in motor post is up
  80. Brushless questions, lets get em all in one thread.
  81. cx2 battery not charging
  82. Fuselage
  83. Charger question
  84. Night Flyin'
  85. Gyro for blade cp pro???
  86. CX-2-installed alloy parts now pulls violently to right on takeoff
  87. Motor improvement for Blade
  88. Blade CX2 Gyro?
  89. ESC and Motor Question
  90. CX 2 Charger Issues Smoke?
  91. CP OR CP PRO TRAINING GEAR SET INSTALATION?
  92. blade cx2 air vented motors
  93. Blade CP Pro Flight Time
  94. 3 in 1 unit, ¿death?
  95. Grr... damn batteries
  96. Blade CP Pro Tail Question
  97. Heli simulator
  98. my blade cx won't sit still
  99. best new motors for cx2 ?
  100. blade tail setup
  101. CX2 Clack of Death
  102. Lower Rotor Head Repair
  103. 3in1 cooked
  104. ok which one do i need cp or cp pro
  105. Blade CX2 5th Channel
  106. no throttle !!
  107. direct drive tail question?
  108. BCP Loose the 4+1
  109. CX2 transmitter LP5DSM with CCPM
  110. Microheli head and vortex parts
  111. DD tail going?
  112. Sorry another newbie question
  113. Newbie question
  114. someone help me please before i smash this heli
  115. cx2 was perfect
  116. ignore
  117. All you need to know about the blade cp pro
  118. blade cp pro, removing swash plate
  119. Quick cable alignment question
  120. CPP, DX6 and G90
  121. replacement bearing!!
  122. Best way to increase flight times!
  123. CPP Skid
  124. Blade CX help
  125. would this work on a cx2
  126. throttle problem on blade cx2
  127. CP PRO Canopy
  128. how do I make a sticky?
  129. factory settings help
  130. Blade cp pro, what bearing is in the tail?
  131. CX2 - Motor Break In
  132. blade cp pro parts
  133. Blade CX2 Lower & Upper Rotors - Grinding Noise, Same Direction
  134. brushless set up
  135. balancing charger problems
  136. New guy here!
  137. Blade cx Twitchy After Crash
  138. CP mods
  139. Why does
  140. test message only , ignore
  141. cppro and cp questions
  142. CP Pro main rotor Runaway
  143. Servo Swapping
  144. CP PRO
  145. BCX2 Flybar Frustrations
  146. 4 in 1 Chips inside came apart
  147. Problem with Brand New CPP
  148. CNC head question.
  149. Esky Lama Blades
  150. led lighting systems
  151. It's just not my thing...I am a car guy.
  152. i need help daul tail motor and the fuse
  153. vortex motors exp
  154. cx2 in light wind
  155. How do I align servo arms on CX2?
  156. Hello and Thankyou all
  157. best and Worst Vendors for Blade Parts
  158. Heli Direct/Helihobby
  159. A great tip for CP and CP Pro users
  160. Heli - Wiki
  161. E-Flight 2 in 1
  162. What fireproof box do you use to charger your lipo's in
  163. reliable venders
  164. cnc center hub
  165. i want this
  166. Need help putting blade cx back together please
  167. CX2 SHORT FLYBAR WHY NEEDED?
  168. gyro and 3n1 4n1 2n1
  169. Blade CP Center Hub Wobble?
  170. Best charger for Blade CX2
  171. What's in your field repair box?
  172. homemade duel tail mount
  173. blade cp pro tail rotor alignment
  174. Headspeed, mix, and computerized tx information for Blade CP and Pro
  175. can I learn the cppro easier with these mods?
  176. DX7 settings for Eflite Blades
  177. Microheli swashplate for Blade CX2
  178. BCPP upgraded tail speed controller
  179. Okay...now I'm annoyed
  180. Got test results?
  181. VNR3d with blade stuff
  182. G90
  183. Blade CP Pro jump
  184. Curious! Blade CX2 and Dynam Vortex?
  185. CX2 ORIGINAL LAND GEAR FIX! GLUE???
  186. A new owner of a CP pro
  187. how do blades stack up against Heli-Max Axe helis?
  188. blade cx pro
  189. bcx tail wagging
  190. Battery disposal????
  191. What does everyone think?
  192. CX2 CONTROLLER 5TH CHANNEL????????
  193. 11.1v lipo on CX2?
  194. Eagle 50 new here
  195. TBE - YIKES!!
  196. It seems eflite is shipping lower heads!!
  197. red wire on esc
  198. 3in1 with BCP tx ?
  199. cx2 Battery charging
  200. Blade CX Trim Adjustment Question
  201. Woops
  202. won't fly
  203. Blades For the CP.
  204. Need Help Blade CP 4in1 Flashes Red Green
  205. Low price CX2 flybar mod ??
  206. OUCH...Blade CX2
  207. shogun before and after couple hours work
  208. CX2 and the Vortex outer and inner shafts
  209. does this motor suit blade cx/cx2??
  210. Blad Cp Pro balance charger overheats
  211. Pinions Gears Motors RPM changes
  212. Swash plate tight on CX2?
  213. Change mode on Blade CX2
  214. Install G90 on CPP
  215. Retractable landing gear prototype for CX2
  216. Blade CX2 Servo Chatter
  217. Indoor Fly Areas
  218. I thought this was Self Serve or Please Ma! I'd rather do it myself!
  219. My blue CX2
  220. CP Drifting to left????
  221. To CP or no to CP
  222. CX2 TRICKS? ARE TRICKS POSSIBLE?
  223. Ugh. Please help..
  224. Saved by the power lines...lol.
  225. main motor options
  226. Why 2.4 in CX but Not CP?
  227. opinions on flight sim programs
  228. charger question???
  229. Which tail system for the CP or Pro?
  230. Blade CX2 won't hover steady
  231. Optic 6...CX help on set up
  232. Upper Hub Blade Bind
  233. Long or Short flybars?
  234. Honeybee 2 problem
  235. New (Used CX)
  236. 2.4Ghz in a CP ??
  237. Blackhawk canopy for CP
  238. Pitch Gauge
  239. suspension on skids for CX-2
  240. WOW CX REVIVED!!!
  241. Blades don't spin
  242. Extreme Productions Motors in CX2
  243. CX2 Problems
  244. Kyle shows you how to fly a BCPro
  245. blinking lights on heli
  246. Can you upgrade battery in Blade CX???
  247. Any info?
  248. Interesting observation
  249. Noob w/ a question (I searched, didn't find it)
  250. what heli to get
