- CP pro Help
- Who makes the smallest ball link pliers?
- Direct Drive CPP Setup
- BLADE CP ALUMINUM
- Maryland Get-Together
- Blade CX2 - Lower Head - Microheli or E-Flite?
- Should I?
- New addict
- I hate this hobby !
- Blade CX - Electronic Mixing ?
- Help 3in 1 ???????????
- CX2 Optional Features
- cx-2 swashplate question
- Sorry wrong forum
- proportional adjustment - CX2
- Blade CPP to CP conversion
- CX2 TRIM adjustment???
- New guy here, this is cool!
- Blade CP motor question
- cx-2 problem
- DD tail gets very hot
- CX2 controller ratchet adjustment possible???
- Need help with my cp pro it goes crazy
- Esky:HB FP2 vs Venon:Night Ranger II
- Blade CP, Thunder Power battery question
- Why no heli races?
- CX/2 Mod... which hole is best?
- Gain
- LipoSack
- Lower Head Repair
- My blade cx to CP pro experience
- Installing Blade CX2 Battery?
- 10a ESC w/ Brushless?
- sudden problems with cx2
- Problems with a CX2
- CX2 Huey body
- Blade CX2 Batteries
- 3-in-1 flashes red and green after brushless
- Heat Sink Compound???
- Pitch problem
- aluminum tail boom
- DX6 problem
- Those Darn Heli Gods!
- Post your pics of Fuselages
- Converting CP Pro
- CX Vibration issue
- Lightweight flybar with CF boom
- Lipo Fires
- CX2 TOP ALUMINUM HUB INNER SHAFT TBE !
- Bad Servo
- Swashplate???
- CX2 Vibration and TBE After Crash
- CX2 battery - TP205 Balancer
- WHICH FIXED PITCH HELI IS BETTER????
- can you use CPP radio with a flight simulator.
- CCD Color Micro Camera...
- blade cx jumpy
- 1st flight with T-Rex
- CP pro brushless ESC setup
- Blade CX Repair guide?
- Help with lift off ??
- My BLADE CP 4-1 stays red at Full throttle and wont lift?
- CX-2 Transmitter-Use with simulator?
- My new upgraded BLADE CX2
- Ebay Blades feedback/experiences
- How Can I Make Retracts work for a Blade CP
- Brushless question
- repair question CP PRO
- CX2 Motors
- Finger tip Or Thumbs
- Blade cp pro
- CX2 BLADE CHANGING? PAIRS?
- plastic blade ??????
- CX2 Crash Troubleshoot
- RX cyrstal change to differnt channel?
- Good time for brushless????
- Spectrum Radio and Blade CP Pro?
- cx fun stuff?
- REALFLIGHT TRAINING? BEST WAY?
- Aluminum tail boom
- Shogun help
- cx2 4-n-1 flashes red/green
- CX2 wants to go forward with full trim down
- Blade CP PRO Aluminum Head
- Blade cx 2 controller with Realflight
- brushless or brushed
- Carbon fiber blade patch tip
- CX2 TO CP PRO How Long???
- blade cp+A.E. kit...what Lipo?
- Microheli CNC Head for Blade CP Pro
- BCPP main frame options?
- CX2 won't fly straight
- CX2 Charger is dead - Whats a good replacement
- Radds School.
- CX 2 spinning on the ground after upper rotor head replacement
- CX-2 Toilet Bowl Swish... What's wrong?
- Better flying On CX2
- Tail Motor Burnt Out?
- Screws for: Park 370 Brushless Inrunner Motor, 4100Kv
- CX gets no lift....
- carbon fiber blades yeah or nay
- Hard Landings? your call
- tail boom removal (how to get the ca out?)
- Quick question
- need some advice
- eflite pitch gage????
- Correct swashplate configuration on CX2
- CX2 unstable after boom/ tail mod
- How many people with servo problems?
- CX2 Flight Times?
- NEED HELP WITH BRUSHLESS SETUP!
- Taming the beast: Blade CP Pro
- CX2 Flying brick out of the box!
- no one else seems to know why my heli is doing this, so if your a bit of an expert then read in...
- LiPo fires and extinquishers
- Blade CX Part Interchange
- Modified stock tailboom!!!
- CX2 How long to basically fly in house???
- Ok so whats next? Re-build from Scratch?
- Any pictures of your CX2
- Chargers for the Ni-MH?
- side in tips
- $$$$$155.00 CX2 EXCELLENT CONDITION(PLEASE LOOK)$$$$$$$$$$
- trimming prob. with CX2
- Battery chargers for CX-2 lipos
- Controlling the CX2 USING CONTROLLER Help Newbie!
- CX CX2 Outer shaft
- Noob with a question
- HELPFUL TIP!! JUMP-STARTING BCX2 LI-PO BELOW 6 VOLTS!!
- CX2 arrived today.
- Problems levelling the CX2s swashplate - help.
- Blade CX2 800mAh Charge time?
- Left Spin?
- Going to venture into a hemp store tomorrow
- CX to CX2 4-in-1 conversion
- DX7 and CX2 settings
- Anyone have this Boom installed ?
- CX2 Flybar Mod?
- Lessons in CP Inversion
- BLADE DAMAGE? REPLACE?? NEWBIE HELP!
- CX2 Blade Balancing and Other Radio
- different trims?
- I'd like to know..??
- CX2 and Computer Program???
- Blade CP Pro Throttle Dead Zone?
- Clearview Blade cp lag
- Conflicting pitch setting advise when using "search"
- What can a cx do?
- Cx wont hold a steady height
- CX2 Inner Shaft Question
- blade cx2 blades hitting durring hard turns.
- Blade CX2 Up Grade Parts Help
- cp controller simulator
- What to get after the CX2 ??
- hovering
- CX2 CNC parts?
- Turning right ?
- Wind took my Blade CX to the water :(
- WHAT DO YOU THINK OF THE E-FLITE SABRE HELICOPTER?
- EASY tail boom removel on Blade CP
- Yay learned how to use the idle up
- Excess Vibration On Main Upper Rotor Assembly On CP
- G90 and DD Tail
- Blade CP battery in a blade Cx
- gettin back into helis
- Radds
- Please Help Im Stuck On A Crash Re-build CP Pro
- Just got one !!!!
- CX2 servo and pushrod--HELP!!
- Blade CX2 First Flight and Questions
- how many CX2 owners are there
- I have a question about a part on the CX2
- i was wondering
- what to do ?
- setting up 3 in one reciever and G90 gyro
- ARGHHH! 3 Cell Li-Pos won't charge properly!
- G90 with 2 in 1
- broken lower rotor head help
- Anyone loop their CX or CX2 yet?
- TAKE OFF CRASHED BIG TIME!!!4in1 in question
- Newbie needs help - Blade CP Pro Crash
- Scale body for CX2
- lower rotor replacement
- WALMART FOR $29.95
- I flew my cx2 a couple weeks ago and
- cx2 not hovering right!!
- Cx2 CF tailbooms
- charge cx2 battery prematurely
- what does this mean
- blade cx2 help
- Blade CP Pro: Vibrations / not turning round at low head speed
- stock CPP lipo question
- Unpainted canopy for the blade cx 2
- Cx2 flight time?
- Pitch of the Main Blade
- CP Pro Defaults
- constant tail drift
- Resistants CX2 blades
- 9c settings for HDX300 3800v motor
- Head speed Blade cp
- Blade CX2 Parts
- heli battery charging question
- CX2 battery specifications question
- CP Pro - Alternating Green and Red LED
- LiPO Batteries Explained (For Newbies)
- BCX2:Cutting upper or lower blades.
- HDX300 brushless mounting screws ?
- Lower rotor head
- CX TEST PILOTS WANTED!!!
- blade cx questions
- Blade CP stock battery
- CX2 Scale Bodies
- CX2 Receiver and DX7
- eflight Alum. swash problem
- Linkage
- Blad CX2
- Blade CP Pro - Removing Flybar
- dual motor / CG issues
- Blade CX2 Flight Trouble
- Hitec Elipce 7 and blade cpp
- Using my airtronics controller
- is the blade CX2 a good heli for the money
- Battery Upgrade for Cx2
- CX radio glitches for sure. Will it affect my future CPP?
- Blade CP Pro Status LED Solid Red
- HELP!!!! BCX2 RANGE PROB!!!!
- Temperature related gyro drift?
- Is there a way to use a tethered power supply instead of a battery while learning to hover?
- Stock Charger Dead?!?
- cp pro won't go!
- How do I contact E-Flite Blade Manufacturer?
- Vortex Motors!!! Please Help!!!!!
- New to the forum!
- Heading hold/rate gyro newbie questions
- servo travel...
- Final approach tips
- help or hindrance?
- CP Pro on G3.5 Simulator
- cp blade pro question
- Buddy Cable for E-Flite CP/ CPP
- Update on CP Pro Comanche
- Fix or buy after hard crash?
- Losing all hope.
- Blade CX Relpacement Parts Poll
- CX Relpacement Parts Poll
- Cant find thread about HS-55....help
- Aluminum CX Boom and crash bars...
- Whats going on with my cp?
- XRB blades in BCX
