View Full Version : E-Flite Helicopters
- Walkera #52
- Plastic / Wood / CF .. but now FRP?
- CP Blade...fishing for an answer
- Blade CP Using Esky Main Gear HELP
- Charge time?
- Feigao Brushless Tail Motor
- my lipo packs toast?
- tp balancer
- battery pack 1000mAh
- CX-2 .. meltdown in the 4-in-1.. literally
- CX Pro upgrades... experiences?
- alternative to e flites brushless motor...
- stupid crash :(
- Toilet Bowl Effect on CX2 "Help Needed"
- bcx2 take off problem
- E-Flite's new CNC aluminum rotor hub for CX
- newbie
- Thank you B. Davidson!
- TAIL CONTROL???
- BCX2 Did they fix it?
- Proper linkage setup on blade CX?
- 2 Blade CPPs ???
- Blade CP dual tail Motors?
- is there a link for cheaper lipos for cx cx2?? cant locate it again..
- Blade CX2 problems
- New boom and skids
- blade cx2 alum flybar head failure
- CP plastic-blade
- CX lower head won't take screws
- Li-Po Question
- bcx2 4in1 5th channel question
- Will JR R790 receiver fit in a Blade CP Pro?
- BCPP charger question. . .
- BCX2 main frame change?
- Blade CP unstable hover after upgrade: Help needed
- Reversible tail motor for cp?
- Blade CX2 flying in the house vid
- Discovery! a slight twist in CX blades provides more lift, lower motor rpm.
- Heavy duty skids for CX2
- So, you think your day was bad??? cpp destroyed
- new to forum with a question
- need help with CPP problem
- BCPP Separate Tail ESC - Wag Wag Wag
- Eflight CP power
- Blade CX2 upper bearing
- E-Flite Blade CX2 lower blade tracking problems
- What is th ebest way to convert to tail brushless
- BCX2 - Radio Trimming
- Housefly 2 drive gear question
- CX2 - Parts
- CX2
- NEW BCX2 QUESTION!!!
- CX flies fast then slows like a stall then speeds up again.
- Cleaning CX2 Bearings
- Sim Model files for download BCPP? I'm New
- Servo Wire broken
- cx2 problem
- Blade CP Pro eye candy....
- CX2 fuselage question
- Wheeeeeeee.......... Blade CP!
- Lama XRB electronic help
- CPP Tail boom measurement, please help me with a quick measure
- CX2 - Am I the only one ...
- I need help with G90 Gyro
- clack of death question
- Lower rotor head
- Ducted Fan Mod
- CX2 Help
- cx2 charger question
- CX2 to CPP
- Blade CPP JetRanger Body
- new guy with a cx2
- CX2 - Kicked it up a notch ...
- CX2 Servo
- blade cx2 broken lower rotor head
- cp pro pinion.
- Blade CP being a *****
- Tail Supporter for Cp Pro
- LED on 3 in one unit turning red during flight
- BCX2 Blade tracking help!
- LED lighting question
- The HH gyro, how does it DO it?
- a quick and simple question - gyro's
- Flybar question
- Blade CP and CP Pro stories Here!!
- Super 8 in a blade pro.....NEED HELP
- Blade CX-2 for airplanes..
- Blade CP HELP
- Blade CX2 RTF Elec Coaxial Heli and suggested upgrades??
- Cp Pro Help
- Blade CP...now what?
- Blade Cx Pro on ebay
- Blade CP Gyro adjustment
- New use for dead Tail Motor
- charging 6 cell lippo with 3 cell charger
- CX2 yaw faster....
- Need help, for Tx to computer
- removing 3in1....need tail ESC advice
- CX and CX2 parts interchange
- BCPP problem. . . and responce to Rob
- Another newbie question...Bear with me guys LOL
- Blade CX2 Video
- CX Gyro gain adjust? what does this mean?
- Extension Cable - Battery to Charger
- Blade CP Pitch range with Park 370 (4100)
- Blade CP all figured out!
- Anyone Convert Their CP Pro to Beltdrive?
- blade cp pro dx7 and hs55 setup
- CX transmitter recharge port question.
- Recommended Settings For BCP & Futaba 8U Super?
- OK I give up, I need help. setting up my DX7 on my CX2
- Blade CX2 High Performance motor upgrade
- Lift problems on heli
- sparrowhawk
- Who sells hop-up/replacement parts for the CX2?
- advice im New to Cx, is mode 1 conversion possible?
- BCPP and DX7 for a heli newbie... problems
- Hacker motor
- Need any advice you all can spare...BCX2
- JST or Mini Dean ?
- Blade CP wobble - bad Center Hub?
- Blade CP 4 in 1 question
- Blade CP assistance if you would...
- CX2 Battery
- CX2 swash plate
- Help! My CX2 doesnt move :(
- help cant figure out whats wrong
- CX2 Transmitter change to Mode 1
- BCP Pro Stock TX setup-How?
- CX vs. CX2
- Confused...need help BCCP yaw
- Wow... range on CX2 is HORRIBLE... <CRASH!>
- what frequency channel is available
- No steering control on BCX
- Just finished minor upgrades to my BCX2
- Help to choose my heli please ...thanks
- Blade CX2 Lift Problem
- Idle up configuration for Futaba 9c/blade cp pro question
- BLADE CX GEAR PROBLEM
- New Owner of CX2 -- Looking For Advice (Advancement)
- bearing lubrication
- Inner shaft on cx2
- Newbie - First Heli - Blade CP
- CP Pro Autorotate gear?
- Help adjusting the pitch control
- cx2 receiver
- CP Pro and DX7 from the beginning
- Blade CX - help if you can
- I fixed my BCX2 corkscrew/toilet bowl problem.
- lipo with a dead cell
- Blade CPX 2 battery ?
- DX6 and G90
- BCP Pro glitches after crash
- Two New Micro Fuselages
- Blade CPPro, Rudder problem
- cx2 dx7 setup
- Blade CX2 & DX-7
- Hopped up CX2 Problem?
- Please HELP!! Blade CP PRO
- Idle up for new flyer?
- Blade CX problem!
- Blade CX2 Onboard Video Cam!
- BCX2 2.4 Gig to Trainer Radio BCC 72mhz radio?
- newbie cx2 question
- Blade CP Radio used for fixed wing?
- JR XP 7202 Vs. Spektrum DX7
- First flight with the Blade CP!
- hitech hs55 servos help
- Anyone get rid of the 3 in 1?
- tail motor
- blade cp upgrade
- Son puts old man to shame with BCX2
- How to install training gear on CPPro
- CX2 Help (Inner Shaft)
- ChoppersRule, I have a box!
- Happy Holiday Everybody!
- Blade CX2CX2.
- My X-Mas Bonus!!
- Blade CP Pro for new fliers
- zoom goes in circles
- Blade CP Pro Problem!
- Cp Pro & DX6 Owners listen up!
- Voltage limit curcuit for tail motor
- Blade CP CNC Complete Head
- Tail Motor pulses
- Just flew my Blade CP Pro, questions
- Dealing with boomstrikes
- brushless/gear mesh problem..
- Santa came early
- UPGRADED CPPro FEELS HEAVY
- CX2 upper head question
- The best setup for Blade CP
- CX2 making circle, need help!
- zoom heading hold gyro, PLEASE HELP!!!
- Paper clip mod, revisited! CP PRO
- It's so nice....
- My Pro is in.
- Help Choosing Heli
- Carbon Fiber main blades on CP PRO!
- CP Blade question... for the pros
- Swashplate geometry
- New Event Videos - w t f, over?
- cp pro pitch and head tracking issue
- Is it worth it?
- Broken TX antenna
- Look at the latest from www.bladecxpro.com???
- CP PRO/ TREX TAIL ROTOR
- Not enough power.
- CP Pro ugrade issue
- Wierd head pop
- Telebee HH Gyro Questions
- HHgyro problems on CP Pro
- blade cx question....PLEASE HELP
- CP Pro Battery upgrade
- Blade Cx/2 Cheap$$ Aluminum Carying Case *pict*
- CP2 Computer radio setup
- Need help with cx2 controler and FMS.
- Blade CX2 Bomber
- Lipo batteries/ how often to charg when being stored
- How hard is the CP, compared to the CX?
- BLADE CX2 WONT ARM!!HELP PLEASE!
- Is the Blade CX & Blade CX2 Battery the same? If so....
- bade cp hovering problems
- Fixed the heat! Pitch is everything...
- CP collective problem
- New CX2 colors
- Tale Spinner on third motor??
- BCP getting some competition...new Helimax Axe
- CP Pro inverted
- CX2 at night!
- Real quick lipo ?
- Dual tail motor TIP!
- How to replace blades on CX2?
- anyone tried an upgrade BRUSHED motor?
- which aftermarket servos turn in the correct direction for BCP?
- Brushless Wiring
- Cloaking Device Revealed
- Shogun 400
- Main motor temperature
- what happened to Psikelly?
- Ok, so some BCP guys going Trex...anyone going nitro?
- winter project...
- i got a new heli!!!!!!!!!!!!
- how do I level my swashplate??
- Where can I get a Barebones Blade CP or CP Pro?
- CP Pro Belt / Adj Pitch Tail?
- I need serious help!
- CP Pro and EF Helicopters HH gyro
- Recommended CX spare parts?
