View Full Version : E-Flite Helicopters
- Got my mSR and Greaser today!!!!!!!!
- What happened to Strathmore Hobby
- Blade 400 Dampers
- Blade CX2 Forward Flight problems
- Blade CX3 & aluminum swahplate
- Converting the cx2
- need some help
- Cant unscrew inner shaft collar
- Curiousity with Cusker 19mm
- ZERO BLADE STRIKE CORE 2.0
- CPP2 tail motor trim problem
- mSR flyin- 2 weeks into it!!!
- E-Freak
- Flying in the snow
- New Blades Are On Their Way To Me!!!
- Temporary Skid Reinforcement, Need Input!
- Can any 2.4 system work on my MSR?
- BLADE MCX & MSR NEW UPGRADE!! flyrcrivesud.com
- Blade MSR Left and Right Issue
- $20 for a picture blade cx cx2 cx3
- cx3 left only HELP!!
- MSR Main Motor Connection Fault
- Free Heli Video
- Blade cx battery charging.
- blade cp tail upgrade?
- msr tail twitch
- MCX drifts backwards
- Track and confirm - USPS????
- brushless motors
- Blade CP Pro 2 Super Skids?? Main Rotor Pitch??
- Heli shoots up a few feet...
- MSR Question
- CP Pro - JR9303 - 704A Gyro - Please Help
- eflite CP HELP
- Cx2 loss of power and status led goes red at full throttle
- Does CX2 4 in1 gain shift with transmitter?
- MSR/DX6i question
- Scale fuse for Blade 400
- New to Heli, Bought mSR, have question
- MSR occasionally jittery... like a nervous puppy
- Dallas area help with Blade 400
- CX3 Wiring HELP!!
- Blade 400 Main gear replacement
- About ready to give up on the mSR
- MSR & MCX Swash plate
- Broken AR6100e on CX2
- Sat.airHogs> Mon. new MSR !!!!
- MCX flown in 717
- MSR Going back and forth?
- first crash with Blade 400
- DAMMNIT!!
- MSR not turning left
- Upgrading Blade CP FM to 2.4Ghz?
- help with cx2
- TBE on mSR?
- mSR Aftermarket Upgrades
- CX3 trimming troubles!
- Spares for Blade mSR
- Blade CP Pro 2 Aluminum Head Installation
- Wouldn't it be awesome if they had a conversion kit to convert...
- EC3 to DEANS adapter/conversion
- Servicng stock bearings on Blade 400
- Charging never ending...
- Wooden or Carbon Fiber Main Blades?
- Main shaft bent? MSR
- My review: E-flite 150mAh Lipo
- Yaw way left after awhile?
- First Crash!
- Spinning to the left
- Surviving a crash...
- About to buy DX7 quick question
- First flight; tail wag
- Attaching the Blade 400 Canopy
- Blade mSR beginners video!
- mSR + outdoors = whata blast!
- Which HS-65 ?
- Instructions to get you DX6i to work with Clearview
- Blade msr transmitter reverse on gas?
- Can someone explain D\R and EXPO?
- Blade 400 first flight attempts....
- msr flyers !! Please help
- Blade 400 110HL Gyro settings
- were back !!
- My first heli, E-flite Blade MSR! Questions.....
- Rudder servo does not return to center
- MSR Wobbly Pirouettes
- An MCX Question...
- Vids and pics of you MSR posts them here
- Blade 400 swash setup with Futaba TX
- Trimming a heli question.
- What do I need to know about the Blade MSR?
- mSR blade grips upgrade mod
- What is the Best Flight Sim to learn on?
- World's fastest mCX?
- World's Fastest mCX?
- Whats your setting for MSR on a dx6i
- Blade CX3 Tail Boom and landing gear upgrade - Advice
- MSR rocks forward after flying backwards
- Silly heli control question.....
- Blade Grips (for the Blade CX2)
- RPC Electronics/E-Heli Update
- MCXs300 Control Issue
- just got my blade
- $6.99 for Feathering shaft at LHS? Not for me...
- Blade MSR Tricks
- Blade MSR blade grips replacement
- What is the Soloboss Mod for MCX???
- Best way to sell used CP
- blade 400 top speed
- Stock blade 400 gyro problems
- PROBLEM SOLVED - REPORTBACK ADDED...... Strange noise on Blade 400
- heli no control
- Armor the mSR
- 1st crash Blade 400 - got ugly really quickly
- blade 400 test flight
- MSR out of balance...
- MSR won't trim out.
- Strange servo glitching on Blade 400
- Need help Identifying A Part
- Blackhawk (blade400) down
- Blade 400 rear rotor
- Airtronics RD6000 settings for BLADE 400
- MCX Mod in Progress
- E-Flite 120mAh V Flightmax 138mAh flight times.
- MSR DX7 must bind in ACRO!!!
- B400 battery help
- mcx mod question
- what are the differences?
- CX3 Keeps spinning around
- My mSR related woes
- B400 Part# EFLH1421 National Back Order
- EFlite 6 channel CCPM radio
- Scews on lower head MCX s300
- mSR Review
- seesaw holder part problem on blade 400
- Blade mSR in stock?!
- Blade CP Pro 2 Carbon Blades?
- no rudder input
- g3703d/3500g gyro
- DX7
- Blade 400 Speed-Up Tail Drive Gear
- B400 S75 servo burnouts
- Blade MCX Broken?
- E Flights Parts Supply
- Dead receiver...no worrys (ar 6100e)
- Blade 400 has brought me back in!
- Shrink wrap covering of stock Blade 400 rotor blades.
- Blade mCX and figure eights
- new heli
- been away
- Great deal on my Blade 400
- Anybody knows the KEDA ESC????
- CX3 body removing help?
- Swollen lipo for B400
- Need help badly with CX3
- change reciver in blade cp pro
- Hot August Nights Super Sale
- Tropical conversion for the Blade 400 Canopy
- Eflite Blade CP crash, need assistance for repair.
- Xheli Head and Tail CNC Upgrades
- Do Xtreme SE 180 motors ever spin freely?
- HELP Cx3 lower motor loses power!!
- REPORTBACK AND CONCLUSION.....Blade 400 cuts out while flying,what is wrong?
- MSR pricing
- Securing of Lipo batteries in Blade 400
- Next Step on my Blade 400
- Aluminum swash question on CX3
- Question on CX2's 3in1 unit
- FLYRCRIVESUD, ZERO BLADE STRIKE CORE?
- Order Updates from E-Heli
- Me ...... doing nervous hops!!!!!!
- Are Collective Pitch helis really this hard?
- Blade MCX will will only pirouette clockwise.....
- Blade mcx or Helimax Novis co-axial
- Eflite CX2 Aileron trim
- Blade CP tail rotor 'drift'
- which MCX mod for better forward speed?
- Blade CX Question
- Help with MCX s300 Shaking.
- Blade CPs
- Unexplained Wobble?
- New Blade 400 Binding Problems
- Help with a MCX S300 Problem
- flying my blade 400
- Which eflite model will fly a beer to my neighbor?
- blade 400 parts
- Blade 400 O-ring and bearing question
- Check out my blade mcx video on youtube
- Blade CP with Gremlins?
- CP Pro 2 - Tail motor or Gyro?
- Blade CX2/3 - 3in1 Malfunction
- Blade mSR avilable for Pre-Order
- BLADE mSR parts list
- Blade 400 reciever question
- Relative Humidity
- "Tamer" Blade 400 takes to the air again.....
- which scorpion esc for blade 400?
- Setup For DX6i And CX-2
- Blade 400 pitch and bind question?
- 400 tail wage and loss of control
- Repair shops
- Feathering Shaft
- BLADE CX3 FLYRCRIVESUD NEW BATTERY AND LANDING SKID V3
- FLYRCRIVESUD, ZERO BLADE STRIKE CORE PIC INFO
- lubrication / loctite
- How to get more response and speed on the blade mCX
- Best choice for single-rotor?
- 2n1 arming
- CPP2 BL conversion.. anybody done it??
- Can "tamer" setting hurt Blade 400 ESC?
- Titanium Upgrades
- CX2 battery plugged wrong now won't fly
- CP Pro 2 Tail boom
- battery charge question
- Blade 400: Slow main rotor?
- pitch curves on a dx6i for blade cpp2
- mCX & S300 Fast Flight
- New E-flite CX3 Landing Gear Upgrade
- blade cx2 upgrade question
- Great new upgrade for Blade CX/CP controller
- Buying Screws and Bearings in bulk
- MCX Question
- Need some parts advice
- B400 Shake
- spektrum dx6
- settting up the gyro/servo
- b400 main shaft brgs
- Blade Cx Help
- Blade MCX too slow in forward
- Correct Set Up for Idle Up (Pos 1 DX6i)
- Not Impressed with E-flight
- Read when your feeling a bit down
- DX7 and Blade CP Pro 2
- Reassembling Flybar: Paddle Accuracy
- E-flight starting to really make me mad...
- RC Electronics repair, ESC,Seros and 4 in 1 repair
- Blade 400 Problems
- Need help setting blade pitch with gauge.
- woo hoo- sim time helps!!!
- fixing my b400- superman continued
- 400 alum flybar seesaw
- Blade CP Pro 2 will not move
- I did it with your help. Thanx
- blade cx
- lift problem cx2
- Blade 400 cuts out/drops for a milisecond in flight.
- Blade MCX out of control
- Blade CP Pro 2 info
- blade 400 flybar sesaw #eflh1423 out of stock
- What's going on here?
