PDA
View Full Version : Esky Helicopters
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16
  1. Lama 4, 4 in 1 motor control issue
  2. recommindations for servos on hbk2
  3. hbk2 to Trex feathering shaft upgrade question
  4. How long should a pinion last?
  5. which battery should i pick?
  6. Way too much negative pitch/hardly any positive..Q
  7. Have an uncommanded input!
  8. tail box part
  9. Esky controller and FMS HELP PLEASE!!!
  10. Help for a beginner, please
  11. battery recommendations
  12. Esky 3900KV 9Tor 10T Pinion
  13. i guess my batt is fried
  14. hbk2 problem
  15. hs-56hb on rudder
  16. Wrong post
  17. Belt cp tracking
  18. smoked motor after 1 ,6min flight
  19. New heli on the way
  20. king 2 upgraded head//one piece/help
  21. Esky receiver and gyro on a CP2
  22. esky 3100 and 25amp esc....good combo?
  23. foam blade holder
  24. how long do your blade cx2 batteries last?
  25. hbk2 tail upgrade
  26. Honey Bee FP.....seems really unstable in the air. Is that normal?
  27. question about the lama v4
  28. I needed help with installing gyro
  29. t rex blades on a belt cp
  30. Two different parts?
  31. Symptoms of a bad ESC ?
  32. hbk2 motor gear
  33. king 2 tail servo rod clips
  34. Belt-cp on Real Flight G4
  35. Sticky swash / Linkage
  36. Fixing the Xtreme Lama v3 upgrade boom!
  37. How to Mod Align 325mm Pros for Belt
  38. Recover Rotors?
  39. Honey Bee King V2 wobble and gear noise
  40. The Honeymoon is Over...First Crash
  41. HBK2 Hybrid
  42. hbk2 brushless motor question
  43. Phoenix Sim and the HBK2
  44. metal rotor head for HBKII
  45. brushless setup question
  46. To much play in feathering shaft
  47. King2 bent tail boom = tail belt drop
  48. Esky Small Tubing
  49. Belt cp cylic response
  50. Question on 0407A gyro and 0406A Transmitter
  51. HBK2 Thoughts
  52. Interesting quote
  53. **** EK2-0704A GYRO HELP****
  54. Whats the "Better" ESC?
  55. Tools to remove feathering shaft?
  56. King Bee V2 Blades
  57. glitch in esky dauphin still
  58. Replace carbon brushes?
  59. vertical tail on the HBK2
  60. The TRUE cost of learnin rotary on belt cps..200$?
  61. need help with reciever..
  62. trex main gear, belt cp?
  63. 43t belt upgrade
  64. A bone to pick with those Set Locking Screws
  65. First Crash Tonight
  66. Need help with swash plate setup - Belt CP
  67. The Esky EK1-0350 BL ESC, Fix?? I might of fixed it.
  68. esky hh gyro help please
  69. KingBee v2 Help
  70. belt cp gyro help
  71. Belt CP problem
  72. DX7 settings for telebee on King2...?
  73. DX6 & Belt CP Swash problems...
  74. new controller doing anything but controlling
  75. what causes this glitch on eskay co-ax
  76. Belt-CP - What am I doing wrong???
  77. Belt Cp Question about tail servo
  78. honey bee FP model for FMS?
  79. Help to align setup rce500x gyro
  80. SOS....
  81. My Belt CP caught on fire :(
  82. First steps with belt cp
  83. Can You See It Now?
  84. Is this Gyro drift?
  85. HBFP stock motor vs. Avionics Slow-Max
  86. I hope xheli never figures out....
  87. Best CF Blades for Belt CP? Also battery security and antenna placement.
  88. Belt cp or HDX 450 SE RTF
  89. Belt cp pic's
  90. can you get colco lama...
  91. charge rate for 7.4 Li-Po
  92. am i being overly sensitive to noises
  93. E-Sky Belt Cp won't fly longer than 2 minutes
  94. E-Skt Belt CP problem
  95. New esky co-axial body
  96. herky-jerky HB CP2
  97. Blue Bird Brand Servo
  98. Best CNC upgrade for HBK2
  99. thinking about a belt cp
  100. HBK2 Crash Analysis
  101. Helicopter - Fly By Wire
  102. Honey Bee FP and Lama IV Blades
  103. hbk2 foam blade holder
  104. HBFP tail motor fade
  105. Honey Bee King RX Crystal
  106. canopies for the Belt CP
  107. How to control pendulum effect?
  108. Inner Shaft length,need measured !!!
  109. servo gears HBK2
  110. Another Qusetion about the Belt CP
  111. HBK2 w/ BladeCP Pro Canopy
  112. (swiss lama) or (colco lama)?which is better?
  113. hbk2
  114. Belt CP custom vs. Blade 400 kit
  115. Belt CP Parts availability
  116. Petg filler
  117. Looking for R/C heli dvds
  118. Tail Upgrade for HBK2
  119. Esky quality - what's the truth?
  120. Training gear vibration at hover
  121. hbfp+esky 3in1+ar6100+dx7
  122. Question about Belt Cp
  123. Blade CX 2 Or Honeybee Mark 2 for first heli?
  124. Z-bend links on the HBK2 head
  125. for sale
  126. HBK2 Reciever Problem???
  127. Mildly modified HBK2 flight
  128. Quick will this battery fit Belt CP
  129. what is wrong with my servo (HBKII)
  130. Belt CP - About to buy, what else?
  131. Cutting foam to fit tx case
  132. is it the ESC or the receiver on a HBK2
  133. belt cp head vibration
  134. Servo starts too low.
  135. Mentor Needed
  136. damn usps
  137. Can this be done?
  138. resetting lama 4 "4 in 1" controller
  139. Art-Tech 400 Class, 300 Hughes heli
  140. brushless 3900
  141. straight vs. balance charging lipos
  142. Gyro?????
  143. BeltCP tail rotor tuning question
  144. Best way to replace main frame CP2?
  145. New anti rotation for my copterx head
  146. PROBLEM!!!!!!!lbelt always comes loose??
  147. Aluminum Landing Skid
  148. plug in battery and heli goes nuts
  149. Boom strick B/c of striped servo
  150. HoneyBee FP - 3 small lights
  151. New Canopy and finished heli
  152. tracking problem...
  153. Servo Creeping, Can it be ELIMINATED?
  154. spinning counter clock out of control :
  155. main bearing substitute
  156. esky airwolf canopy help
  157. For Sale
  158. Xtreme flower sticks
  159. Lama V4 A and B motors
  160. bent feather shaft
  161. is the esky 25A ESC any good?
  162. Xheli Scale Fuselage
  163. EK2-0704A esky gyro question.
  164. Best Lipo Battery for HBK2
  165. HBK2 43Tpulley&belt install
  166. Total Noob Belt CP question...
  167. Belt CP wanders all over the place trying to hover
  168. Another new HBFP pilot here
  169. most common prob for my tail
  170. Servo control arms
  171. Using CP radio to fly FP heli
  172. Is my 4 in 1 going out
  173. Xtreme Production blades
  174. UP Grade Parts List
  175. Main Blade Substitute ?
  176. Repair pics
  177. HBK2 CNC Tail
  178. HBK2 ACTING FUNNY
  179. tail problems
  180. What pinion for 3100kv?
  181. Deans Ultra Plug Connector for HBK2
  182. Bogus servo
  183. King II DX7 HH704A set up
  184. Lama V4 hard landings
  185. Some questions from a new FP pilot
  186. How do I set up my Dynam 30A esc?
  187. Replacement crystal sets
  188. heli wants to go backwards
  189. rod lengths
  190. Opinion On X Heli.com for Parts
  191. Lama V3 metal upgrade problem - -Help- -
  192. noobie needs flybar setup help
  193. ??? with idle up HBKII
  194. best blades for e lama
  195. Belt CP upgrade/sparepart kit
  196. HBK2 - Pinion for brushless motor
  197. A day of Flying
  198. Thanks to everyone
  199. Evolution of my Addiction
  200. update
  201. ESC range setting? Please HELP?
  202. upgraded head centre shaft.
  203. Esky Belt CP Receiver-Crystals?
  204. I SWEAR, THE FISH WAS THIS <----------------------------------------> BIG!!!
  205. HBK2
  206. HBK2 tail parts
  207. newbie needs advice
  208. hovering time
  209. honey be king v2 help
  210. Have you ever had this happen to you?
  211. King Bee V2 Help Question
  212. HBFP?
  213. Honey Bee King2 with DX7 help
  214. HB CP2 4-in-1 Red Light
  215. hobby shop
  216. HBK2 Essential Mods
  217. Massive tail spin after changing tail boom.
  218. JR Receiver NER-649S PCM Question
  219. Questions on life
  220. Tail unit on belt cp
  221. Headlock gyro sugestions
  222. Belt cp swashplate leveler
  223. Stock motor and speed controller
  224. ring around the rosie
  225. Belt CP battery question
  226. Belt CP - mainshafts slightly bent from factory
  227. HB Rocks!
  228. Futaba 6EXH for honey bee king
  229. Going Brushless with the Honey bee fp
  230. New HB CP2
  231. belt cp main blade clamp resassembly Q.
  232. esky canopy ?????????????
  233. blade and lift off question
  234. INSURGENT! The new game in my house.
  235. belt cp main shaft and gears
  236. stock esky reciever ??????
  237. Hello
  238. Can I use an Esky head lock gyro on a honey bee cp2
  239. Pics of my helis
  240. KingBee V2 Weight
  241. CopterX part compatible with Belt CP?
  242. Esky shutting down production (temporarily)
  243. next heli suggestions
  244. Black Hawk 450SE or Blade CP
  245. HBCP2 main shaft removal
  246. Belt-CP And Logictech 2100T + Digital Servo Question
  247. Belt CP with AR6000 and DX7 HELP!!
  248. Tail changing feel
  249. ESKY production shut down
  250. Probably stupid TX question
