PDA
View Full Version : Esky Helicopters
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16
  1. Are my new LiPo's DOA?
  2. Help, Bad short circuit
  3. batwing blades
  4. 2008 King V2 Belt
  5. Binding DX6i toa 2.4Ghz Esky 4-in-1 controller
  6. Honey Bee King V2 Servos
  7. Lama V4 shaft B
  8. HBKII 43t tail pulley and belt size
  9. HBK2 problem installing 3900kv motor
  10. HBK2 headspeed ?
  11. frame rebuild time
  12. HBK2 sloppy head fix
  13. Strugglying to fit HS-65's on my K2
  14. Crazy esky battery help XD
  15. Lipos do catch fire or "It can never happen to me"
  16. modded HBFP
  17. General battery selection & quality ?
  18. Help Newbie mount Battery on Belt CP
  19. new transmitter, which one?
  20. Want to upgrade from blade cp, Belt CP or hbk2?
  21. Right way to wire up the receiver?
  22. aluminum bearing blocks and motor mount.
  23. wall unit
  24. esky stock gyro blinks
  25. Help on BEC
  26. cheapest and best place to buy?
  27. My Tail setup jig
  28. Help on Motor COnnector
  29. Tower Pros all the way arround....
  30. Esky Llama v6
  31. Discussion - lama v3 crazy throttle
  32. Futaba 6EX 2.4gh fasst & HBK2
  33. BELT CP
  34. removed
  35. HPKCP2 clockwise
  36. Is this the real Esky CNC ????
  37. Look a, No '0' linkages
  38. lama v3 battery connection modification
  39. e-sky lama v3 gain / proport. adjustment
  40. e-sky lama v3 4in1 wiring
  41. HB FP Nose down
  42. Fuselage weight
  43. Will this work on the King 2?
  44. how do you remove a wobbled out grub screw?
  45. Lama V4 Proportion Problem
  46. What is easier?
  47. DX7 + Danlion 3200
  48. Explaination of common heli grades of aluminum
  49. My Rant About HBKII !!!
  50. CopterX head on King 2
  51. CF Pigeons
  52. Extra twist in tail belt?
  53. HBFP frame upgrade?
  54. Compatible Crystals for ESky CCPM 6ch 0402a Transmitter
  55. Wobble around mainshaft after liftoff
  56. esky honey bee king 2 battery back
  57. Blade grips too tight
  58. belt cp tail boom
  59. Heli servo question
  60. FP Fibre frame + tail rotor conversion kit.
  61. Honey Bee CP2
  62. what would u reccomend out of the two?
  63. REAL Skids For Lama v3
  64. hbk2
  65. Got rid of the TBE with my Lama v4
  66. Problem Installing Xtreme 43T Tail Drive Pulley on HBK2
  67. Align Main gear & feathering shaft on Belt cp
  68. Futaba 3114 servos for HBK2?
  69. About to buy Belt CP??? Please Help
  70. Brushless Motor for Esky Helicopter
  71. new servos for belt cp
  72. new rotor blades. w counter weight
  73. DX6i and HBFP
  74. RC heli Rocket launcher
  75. HB FP no lift
  76. Danlion + too hot...
  77. xtream frame stiffener for King Vll
  78. which battery... with this set-up?
  79. Reliable Online Store
  80. Interesting Blade Tracking Problem - Suggestions or Help Appreciated
  81. Video: First flights of my Super FP
  82. No Counterbalance in HB M3 FP...
  83. Xtreme CF frame for the HBK2
  84. Terrible vibration belt CP
  85. What would you get for 450 size?
  86. Balance Charger Question - Chargery 1010B
  87. ESKY MOTOR connectors
  88. Help with gain...HB Mark3 FP
  89. Upgrades?
  90. My experience with knock-off upgrades
  91. Triton 2 vs. Triton Jr. LIPO charger
  92. a cobra landed 200 feet from the jobsite today!!!
  93. Bad luck Please help!
  94. Rubber tubing
  95. E-Sky Dauphin Thread
  96. Long charge time
  97. HELP- esky battery
  98. Battery Size for HBK2 w/3900kv Motor?
  99. Junk to one is useful tool to another
  100. gyro which one?
  101. K2 feathering shaft.
  102. New 4in1 for HBFP ?
  103. DX6i 2.4Ghz give away Rxs
  104. servos hh gyro or barebone??
  105. New Gear - Need some advice
  106. good battery?? hbk2
  107. New Esky servo EK2-0500 or EK2-0508 ?
  108. Im sure i may have askt this before but oh well
  109. HBK2 + HS56hb for tail problem
  110. Logitech 2100T Position?
  111. Removing the Main Gear on HBK2?
  112. belt cp?
  113. search all morning..can someone help a guy out??
  114. Air Scooter
  115. which one should i buy?
  116. Battery packs
  117. FP blades on a belt CP?.....possible?
  118. Cannot get rudder servo to work
  119. Esky Belt-CP Battery Charge Time
  120. K2 is spins in circles and I've tried almost everything.
  121. Belt CP Wont Lift Off
  122. Servo torque strength to hold HBK2 tail
  123. Turbo Shaft for Esky Lama V4
  124. ESKY ESC
  125. Deal extreme hbk 2 aluminum upgrades
  126. Need Help with Part!!!
  127. Belt CP question
  128. HBK 2 3D
  129. feathering shaft
  130. here is a cheap way to get some extra flights out of your plastic bell control links....
  131. Telebee gyro blinking?
  132. Shaft too thick?
  133. Lama V4 Stabilizer Hit Blade
  134. Finally, upping RX and TX
  135. Esky Belt CP wants to fly straight backwards!
  136. Spektrum DX6i Gyro Settings
  137. DYNAM ESC 30A
  138. HELP WITH RECEIVER CHOICE
  139. Angled Battery tray for K2
  140. HBK2 BLING solid and flashing leds
  141. Larger 450 size woodies on the HBK2 ?
  142. Second RC Flight!
  143. DX6i / G110 gyro heading hold problem ... help!
  144. Rotortech.ca
  145. Are darths fuselages fiberglass?
  146. Video - Modified HBFP calm evening flying
  147. First RC Heli Flight!
  148. Graveyard for dead Esky 8G servos
  149. Honey Bee tail holding problem
  150. HBK2 CF Frame
  151. Honey Bee King 2 help
  152. servo problem??
  153. Someone please explain.......
  154. what servo to use in belt cp?
  155. Futaba gy401 - How to adjust the gain? Belt CP
  156. Where should I be buying things?
  157. Lama V4-Maingear A moves
  158. Don't know what's wrong. Need help
  159. Question on Lipo
  160. Lama 4 - can not trim out pivoting
  161. Windy HBFP backyard flying
  162. V4 mainshaft replacement.
  163. FYI...Extreme turnbuckle Ball link replacements.
  164. My Helis
  165. HBK2 Xtreme Blades
  166. anyone with an HBK2 try this? pic's included
  167. Frame of Belt CP help
  168. Wall charger included?
  169. Just a quick question
  170. DO NOT USE ESKY SERVOS for a flight over 10 feet.
  171. Can i use stock transmitter?
  172. search function???..what the heck?
  173. Got my new batteries..
  174. Xtreme Frame for HBK2 is out
  175. Problems Replacing HBK2 Tail Boom
  176. tighten blades
  177. Esky Head Holding Gyro
  178. Lama V4 outside flying.
  179. HBK2 mysterious clicking noise
  180. Which fuselage
  181. New King 2 Owner
  182. Futaba 240 Gyro Help for HBK2
  183. Which heli suits me the best?
  184. 43T Pulley bearings HELP, PLEASE!
  185. I got the telebee gyro.. anyone could help me set it up?
  186. HONEYBEE FP HBFP LIPO BATTERY SETUP
  187. What's a good mid-priced Head Lock Gyro
  188. Blade tracking
  189. BRUSHED motor
  190. Did I smoke my hbk2's stock esc after one battery?!?!?!?!
  191. lama v4 - 4 in 1 controller
  192. Esky Lama V4 or Co-Comanche
  193. Belt-CP upgrades...
  194. Extreme 380X brushed motor for HBFP
  195. Blade holder bearing failure
  196. Esky BeltCP Gyro Tail Issue
  197. extreme 43 tooth pulley problem
  198. Spektrum 6200 Receiver Channels
  199. Which HBFP Landing skids do you use ?
  200. esky 900
  201. HBK2 Autorotations
  202. Lama v3 charger/balancer ???
  203. My new record hovering time on HBK2?
  204. HBK2 battery tray mod....why have I not seen this done???
  205. Setting the swash plate level...
  206. LOOK the Belt Cp
  207. brushless motor wiring
  208. Lama V4 calibration
  209. A more classic canopy for the HBK2
  210. Telebee Gyro Question
  211. Lama 3, any good?
  212. Honeybee FP motor question
  213. Tail shack with xtreme rotor blades
  214. Esky Belt-CP Questions
  215. HBK2 Tail Control Issues
  216. questions about esky lama v4?
  217. where to get 2.5mm x 10mm screws.
  218. Rookie question on Esky HH setup
  219. Belt CP batter holder
  220. What tools may I have to purchase to change the skid?
  221. Dragonfly, Humblebee, or Hummingbird?
  222. belt cp feathering shaft
  223. King 2 CNC Head Coupon Code
  224. Will this honey bee CP tail kit fit and work on the honey bee king II??
  225. Bare Bones Honeybee FP
  226. Lama v4 repairs - help
  227. idle up caused striped main gear?
  228. Both helis back up and running.
  229. Is this battery good?
  230. Telebee Gyro
  231. missing the gear
  232. Honey Bee fixed pitch vs. HB King II vs. CX2
  233. E-Sky Dauphin blade tracking/vibration
  234. HBK2
  235. Fuses for HBFP
  236. Esky 25A ESC''s
  237. HBK2 batteries too HOT post flight
  238. Is it safe put a 1000mAh in HBFP?
  239. remove main shaft on belt cp??
  240. Swash leveling, coax, wont stay level??
  241. King 2 center fly-bar holder re-mod using Align feathering shaft!
  242. esky belt cp problems please help
  243. belt cp gyro not working
  244. Extreme Plastic blades + HBK2 :/
  245. brushless motor and esc
  246. Belt CP Suddenly loses power and lands.
  247. putting my HBK2 on the market
  248. CF blades are dangerous
  249. The new King2 head finally released....
  250. kewl thing with servos
