View Full Version : Esky Helicopters
Pages :
1
2
3
4
5
6
7
8
9]
10
11
12
13
14
15
16
- A couple Lama V4 questions
- time to sell
- critical find in Radio
- Fresh Belt cp video from Norway
- Will this Work on the Belt CP
- Final radio decision?
- ITS HERE, my Belt CP vid, lol
- Upgrade yet? Also need help for flybar
- Metal head upgrade guestions for the honeybee king 2
- help please
- Ok this will be good enough
- Slow Down Heli
- What about these servos?
- HBFP v004 w Lipos - Some Questions
- esky servo on futaba receiver
- Belt Cp tuning help
- HBK2 Tail Blades
- Battery Charging
- esky chargers
- Flying my Co Comanche Pretty Hard
- HBKII Crash kit...what do I need for first order?
- Something like dihedral for heli?
- Intermittent wobble
- is my charger bad or is my batt bad? technical help needed?
- Could I use these servos all around?
- new HBFP has no power
- Help my secret mission!
- Canadian orders!!!
- simple tail fix for hbk2
- esc question
- HBK2 43 teeth belt Pulley Upgrade
- Motor Question
- Belt Cp Flybar Casing
- gyro on Lama V3
- Frequency-hopping HBK2
- Belt pulley gear
- Honey Bee King 2 Simulator for sale?
- New Lama V3 tail frame by Esky
- HBKII Gyro.
- belt cp wont turn nose right
- KEEP BELT CP or SELL AND GET BLADE 400
- My BeltCP is here!
- beltcp question
- Now I'm torn
- HBK2 cnc metal upgrades I didn't know about
- Lama v3 new owner questions
- thanks guys
- Belt Lubricant and More for HBK2
- Place you bets
- Repaired?
- HBK2 smoking,battery overload
- CNC Blade Grips HBK2
- what sims are compatible Esky remote controller
- HBK2 Metal Rotor Head
- Ordering Lama v3 with specific channel?
- HBK2 spins clockwise
- LOCKING HEAD GYRO FOR BELT CP
- Shielding wires.
- hbk2 what might be wrong
- ESKY charger
- STUNTS !!!
- throttle trim
- Battery Belt CP
- You guys seen this mod?
- HBK II Carbon Fiber Version
- Honeybee FP - essential spare parts?
- Brushless motor and ESC help needed
- hbk2 fire
- Indoor electric choper
- DX6i or DX7?
- Wikipedia on the HB FP!
- E-sky honey Bee CP2 issues
- eccpm and ccpm Belt CP?
- Good supplier
- hbfp wobbles
- HBFP rotating anticlockwise
- Belt-Cp Canopy and Fuselage
- LI-PO BATTERIES
- hbk2 canopys
- weight of stock parts vs. upgrades
- 450 size power lifting
- Tail Servo, what is a good choice?
- When to upgrade
- HBK2 carbon frame only
- HBK2 CNC Tailbox,fit
- ZING!!!!!!.......threadlock needed!
- Does anyone know ???
- STROBE LIGHT PLACEMENT
- Robins 22 skids are horrible!!
- JR Servo on Belt CP
- does align parts work on belt cp?
- HBK2 head upgrade
- HB CP2 newbie help
- Chargers
- lost my xtreme lama / new bigger coaxial heli
- Xheli canceled my order??
- BELT CP UPGRADE.
- need help
- FMS with Esky 4ch Tx
- HBK2 Versus The Neighbors Clothesline
- main gear screw?
- Motor problem
- going forward in reverse
- GYRO ? or TAIL BOX ? Tail blowout !
- Anyone know belt cp payload?
- Easy Fly 2 Flight Simulator
- Will the Belt CP parts fit this?
- Brushless motor upgrade for HBK2
- HBFP, instock ARTF kits !!!!!!
- HBK2 tail bind
- tail rotor gear
- Belt CP parts crossovers
- main gear change out bearing question
- newbie battery question
- Thinking about a Honeybee belt cp
- New HBFP - Paddle defect...normal?
- honey bee
- E-Flite Blade 400 Main Gear w/One-Way Bearing (Would it fit my Belt CP?)
- Lama V4, Truly NRTF
- Belt in the wind
- Replacement/upgrade for Belt CP
- Blade tension
- The 400 sized Co-ax
- HBK2 upgrade, did I screw up?
- To upgrade or not to
- TRANSMITTER UPPGRADE
- Honeybee King 2 brushless upgrade,hint
- Training Gear Parts
- Lama V4 mode 2 vs 1
- Belt CP/ Honey bee king 2 Quality
- TX batteries and questions
- Belt cp transmitter doubt
- hbfp batt question
- HBK2, how many batteries could you use till stock motor died?
- Belt CP/Align 430L Help
- Newbi, HB King 2 belt & spin prob
- Installation of a Esky 3900 motor with a 10 tooth pinion.
- Need a favour from you guys for HBKv2, thanks
- Llama V4 right rudder
- Esky 2.4ghz out
- hbk2....no right rudder despite input!
- Got my Lama V4, quick question
- Belt-CP Glitching pretty bad..
- Honey BEE King 2
- New blancer/charger
- Head holding gyro
- Slo-Max and blade upgrade on HBFP?
- Belt Cp owner Qusetion abput walkera
- Help With my 4 in 1 on my co-comanche
- Help a HoneyBee FP newbie!
- one way bearing removal
- Servo Questions for HBK2 Again
- BLADES FOR BELT CP HELO
- Lama v3 upgrade problem
- Belt CP owner's please read!!!!
- The HoneyBee 4CH FP2 supports a 1200mAh 7.4V Li-Po?
- Belt CP with Trex Head ?
- Soft start up?
- Can i use the special shaft on my belt cp
- 8g Servo Gears
- HBK2 stock motor holds for 9 flights
- Lama V4 max battery voltage?
- Question about Co-Comanche
- Battery question
- Channel 5 gear channel on stock HBK2 ?
- HBK2 Main Blade Clamp Question
- Llama V4?
- problem with negative pitch
- placement of Collar on main shaft
- Ready for a new heli
- Lama V3 question
- Favorite HBK2 servos?
- CF Tail Boom
- Aftermarket transmitter USB cable?
- EMAX Brushless for Honey Bee King2?
- King 2 CNC blade grip question
- analog vs. digital servo for tail rudder
- OUT OF JAIL, OUT OF A JOB, AND STILL OUT OF PARTS.
- Tail going counter-clock -- servo is already maxed out
- Belt CP ESC thermel Cut off?
- New Belt Cp/BIG problem.
- Plastic Blades
- Best TX for the Belt CP
- carbon fiber paddles wont thread on flybar
- Lama V4 losing power and spinning to the right
- Blades for the belt cp
- Esky Belt-CP radio controller
- 500/600 Class Esky's
- Tail rotor gyro-servo combination
- What part will break first on the Honey Bee King 2
- Has anyone done a full Lama V4 upgrade
- Esky transmitter question
- "HELP" Hobbywing ESC for my Belt CP
- Something's wrong with ESKY chargers
- Outstanding service from CY Model!
- Hbk to trex spindle conversion question
- Battery Question
- need some guidance on tail control
- Rotor Blade Spacers
- LAMA V4 Main Shaft Replacement :(
- 2 ways to modify the 3800, which is best
- Durable Landing Skids for HBK2
- twin direction for pully?
- DX6, DX6i, DX7 thread
- Blade 400 Swashplate On Honey Bee King 2
- Flight Sim for HBK2
- "True" main shaft.
- CCPMixing by TX only?
- Replacements for Lama V4 skids
- Real Flight Simulator TX Calibration & Settings
- Great customer sevice- fast response
- HBK2 cyclic
- Esky electronics vrs my own?
- 43 tooth and antirotation
- Belt CP Electronics Suggestions
- Hey guys, anyone here try this brushless setup for their HBKII?
- How do you know when your belt is too tight?
- Tight or stiff auto-rotation bearing?
- question about upgrades for HBFP
- Tail rotor direction?
- HBK2 w/0704a
- Belt-CP Dead?
- Honey Bee King 2
- EC POWER 2200mAh 25C Hi Rate Lithium Polymer Battery 150Grams (What Charger?)
- Non-esky HBK2 tail?
- how much modifing needed to install 3800 on hbh2
- HBK2 Simulator
- Anyone own the Belt CP carbon edition?
- belt cp feathering shaft
- Parts, Parts, Parts??????
- installed new 3100 and 25esc...studdering
- HBK special shaft
- Horizontal & vertical fins
- stock motor runs for 10 secs..shuts down
- Readyheli.com
- Stock Belt-CP Gyro question
- Stripped Esky 8g servo on my Belt CP
- SALE, FUSELAGES THAT FIT HBFP
- HBKV2 and Hitec HS-55 servo wiring question.
- Anyone repaired a HBK1
- Belt cp very windy today.
- Video - My HBK2 Maiden Flight
- Futaba 9c super questions
- main blade question
- What does alternate flashing on an esky HH gyro mean?
- Eliminate the Z bends
- HBK2 battery holder
- honey bee cp2
- Keytech gyro without documentation
- Clear View Sim....more realistic acting Honey Bee FP?
