PDA
View Full Version : Hitec/MultiPlex Radios- Ask Hitec Customer Service
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. HS-80 servo specs
  2. Optic 6 elevon programming
  3. HPP-21 PLUS Will not Update
  4. Timing the Flap/Elevator mix
  5. ***Aurora 9 coupon promo info***
  6. If Hitec would make it, I'd buy it.
  7. Hitec Spectra 2.4 module upgrade
  8. HS-5485HB Deadband
  9. Aurora 9 Specifications
  10. Optima 9
  11. Hitec Lynx 3D and RX crystal help.
  12. Dual Rudder Servos - Optic 6
  13. Royal Evo 9 update to software 3.3
  14. A9 throttle issue??
  15. how to mixing flaps and elevator?
  16. Aurora use around the world
  17. HFS03MT & HFS03MM Voltage
  18. JR12X and Spectra 2.4J
  19. Does Optic 6 2.4 Ghz work with 72Mhz rx's
  20. Brendan, Mike, help with a HPP-21
  21. Hitec 82 MG servo problems
  22. Hitec Multiplex on Facebook
  23. hitec flash 5x motor speed
  24. Hitec HP-2RNB - 27
  25. HS-5985MG Replacement
  26. Is a new Hitec 7 ch radio expected?
  27. Buddy box for an Aurora
  28. Aurora Range CheckPower Down Problem
  29. Aurora 7CH RX Antenna Configuration
  30. HS-7775MG Servo
  31. Hitec Eclipse using Li-Po batteries
  32. Hitec HFP-10 programmer-What am I doing wrong?
  33. Hitec throttle servo application
  34. RCD/HiTec "MOM"
  35. sex life in the car
  36. Auro 9 shipping ?
  37. R6014FS
  38. Optima reciever with Carbon
  39. Spectra 2.4GHz Module & 2-Optima 7Ch
  40. Disabling BEC to switch to battery
  41. Hitec Optic 6 2.4GHz
  42. RX offer
  43. Aurora 9 electric current A/mAh sensors for electric flyers
  44. Prism 7 transmitter question.
  45. Metal Gears for 5475
  46. Digital Hitec Servo for CMP 120 Hellcat set-up?
  47. HS 225 MG stopped working
  48. HS-7955TG High Voltage
  49. HS-7775MG Servo
  50. HS-225MG for Sundowner 50 Ailerons
  51. Karbonite gear servo's
  52. Spectra 2.4GHz DSSS Module
  53. Aurora 9 TX charger
  54. Hitec 2.4ghz conversion for my Eclipse7
  55. HPD-07RH Antenna
  56. Hitec servo's for pattern airplanes
  57. One way trainer cord
  58. HPP-21
  59. optima 7/optic 6/2.4 problems
  60. Can Optic 6 converted to 2.4 still use 72?
  61. Question on Hitec 645MG Servo
  62. hitec aggressor esc?
  63. Hitec Aurora 9 Question
  64. Message << Older Topic Newer Topic >>
  65. Q-PCM update
  66. HFP 10 VS HFP 20 difference?
  67. Hitec Eclipse 7 Q-PCM Dual Rates in Flight mode
  68. XL control arms for HS 81 were to find
  69. Optima 7 problem?
  70. Hitec Aurora 9 Conditions Question
  71. Electron 6 Rx not responding?
  72. Hitec Optic 6 with Assan 2,4 Module
  73. Aurora 9 Question
  74. The Next Series of "Whens it?"
  75. Aurora 9 and Bind n fly products
  76. Where To Buy - 2.4 Spectra Module For Optic 6
  77. Aurora 9 charge it before turning on
  78. HPP-21 Plus Software Windows 7 - NOT!
  79. Hs-5645 and 5625 help!
  80. Ecclipse 7 Glitching on (2) Futaba Receivers
  81. HS-7995TG Programming with HPP-21
  82. Aurora 9 with 2 receivers in parallel
  83. Aurora 9 flaperon set up
  84. Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
  85. Eclipse 7 - latest sw version?
  86. Pretty Upset at Hitec at this moment.
  87. ? for Mike M - Optic 6 Spectra Module
  88. Hitec Eclipse 7 toast
  89. HPP-21 Digital Servo Programmer not working
  90. HS-55 Servos
  91. A9 Trim Question
  92. MPX 12 DS IPD Rx programming
  93. HS-5625 / HS-5645 signalinput voltage requirements?
  94. Airtronics Infinity 660
  95. Eclipse 7 and Canard mixing
  96. Probably a basic question but....
  97. rx turns on and severe chatter
  98. evo 12 problem
  99. When will the A9 be available
  100. Individual Servo Gears....??
  101. HMA-24FI with otima 9 ch receiver
  102. Multiplex EVO
  103. Hitec Optic 2.4 specs?
  104. Evo programming help
  105. Flash 5X - Double beep
  106. Aurora 9 Battery Question
  107. Hitec Prism 7
  108. Range
  109. EVO Pro update
  110. hs 5084 gear kit ?
  111. Aurora 9 Manual Please make it available
  112. Multiplex Leaving the US Market?
  113. Servo programmers and other brands of servos.
  114. 2.4 module questions
  115. Hangar 9 Spitfire 60 recommends JR servos - Looking for Hi-tec alternative
  116. 2.4GHz Product Delay
  117. Hitec Optic 6 2.4 compatible convertion modules
  118. hitec servos & 2 cell lipos
  119. WILL I NEED SHIELDING?
  120. Royal Evo 12 ... please clarify
  121. HS-7985 concern
  122. Multiplex servo 65086 , 65005
  123. HS 5000 gyro problem/ ?
  124. CAN I USE AN RX
  125. HS-82MG servos causing glitching
  126. WHAT CRYSTAL DO I USE
  127. Canadian Evo12
  128. Mike, With All Due Respect Where is the A9
  129. HS-65HB in Blizzard Tail
  130. HS 7985 MG
  131. Eclipse 7 Problem ?
  132. older eclips 7 2.4 update
  133. New Radio/reciever/servo compatability
  134. EPA adjustment problem on Prism 7
  135. Problem wih Hitec 985MG on E-revo
  136. Did the Aurora 9 arrive on August 14th?
  137. 7950TH release
  138. 7955 programming
  139. Hitec HS-485HD servo
  140. Hitec in Canada question???
  141. Digital Servo End Point Adjustment
  142. Voltage
  143. Strange digital servo problem
  144. Hitec 2.4 module in 9C
  145. Hitec computer radio
  146. Gas throttle servo, plastic, karonite or metal gears?
  147. HiTec Optic 6
  148. FUSION 9 RECEIVER WEIRD BEHAVIOUR
  149. HITEC 2.4GHz Delivery Delays ???
  150. Eclipse 7 Spectra smoke
  151. Hitec HS5245MG/5485HB
  152. 2.4 module/rx for mpx4000
  153. Hitec radio defect warning
  154. HS5245MG gear slop
  155. HiTec HS-77BB question..need your help
  156. HG 5000 gyro questions
  157. overload protection
  158. max voltage Hitec servos
  159. Servo spec comparison and where does a 1/8 scale truggy driver draw the line?
  160. Eclipse 7 Spectra question
  161. Optic 6 - How to mix Chs 5 & 6?
  162. Optic6 - Operating with frequency module removed.
  163. 5945 question
  164. Could a bad crystal cause THIS...?
  165. Hitec 805
  166. No support from Hitec
  167. Receiver Antenna / Bobbin
  168. glitch with dig servos
  169. Micro 05S
  170. what do you reccomend?
  171. hs-5245mg went bad
  172. Hitech Focus 6 TX Crystal
  173. HFP-20 help
  174. Wire damage
  175. HS-7955 Has the Jitters
  176. Aurora 9 Video Walkthough now w/Heli
  177. Eclipse problem
  178. Estimated Arrival of the Aurora 9
  179. HPD-07RH QPCM voltage
  180. Aurora TX battery question
  181. trim
  182. Programming problems with 7955
  183. Challenger 550 Receiver Pin Configuration?
  184. Hitec 6965 Gear set Question, please help
  185. HITEC 605 SERVO PROBLEM AND QUESTION
  186. HS-81 on 6 Volts
  187. Recievers for 75 mhz spetra based Optic/Prism/Eclipse
  188. Multiplex Profi Car 403 compatibility
  189. HS 75BB Retract servo failures:
  190. help 3 hs-5645mg melted in my plane
  191. Hitec HS-77BB Low profile servo for elevators
  192. Single Conversion channel 38 crystal needed
  193. Royal EVO 9 Firmware Upgrade to V2.0
  194. Multiplex Evo Update
  195. Spectra 2.4 Ghz Module compatible with Futaba Transmitters?
  196. HFS-04MG
  197. Which Optima for Eclipse 7?
  198. HS 475 HB
  199. Aurora 12?
  200. Aurora 9 Flight Mode Question
  201. HS-125MG changes center
  202. spectra module and DSM2
  203. 7.4Volts on Hitec 645
  204. Eclipse 7
  205. HP21 and Vista SP1
  206. hi tech and airtronics
  207. Hitec 5995TG/HobbicoCS170
  208. Servos buzzing
  209. venom mg servos, a good servo?
  210. HS-5485 & HPP 21 plus question
  211. 5945 gear replacement
  212. Futaba 9C & Hytec Eclipse 7 as trainier
  213. New Hitec 7950 TG servo hit the markets yet?
  214. HPF-20. Is it the latest?
  215. Programming 7955 TG servos with a HFP-10?
  216. about new 2,4 ghz rx
  217. Hitec Focus 4 ch radio
  218. Optic 6 - Unwanter Aileron Differential
  219. HS-475HB and A123?
  220. 7955 and JR receiver
  221. Aurora 9 dual rx?
  222. Hitec Optic 6 with spectra modual
  223. buddy cords
  224. Hitec 2.4 conversion
  225. Optic 6 Tx with minimal range (30 metres at best)
  226. buddy box
  227. Receiver crystals - X-TAL Guard - Where Available?
  228. Different Optima 9 ch 2.4 RX's - question
  229. Qustions: HiTech HFD-08RO RX
  230. Programing issue with my 5945
  231. 7940TG or 7940TH???
  232. HPP-21 Servo programmer. Help Hitec!
  233. Aurora 9 in flight mix trim change?
  234. Aurora 9 Pkg Rcvr Batt question
  235. HPP-21 progammer and MS Vista
  236. Request for two more Aurora 9 screen shots
  237. Hitec servo centering problems
  238. New Hitec HS 7950 TH servo Price?
  239. HFP-20 Programmer Problem
  240. Hitek 2.4 GHz
  241. 985MG with AR9000
  242. Eclipse 7 Flap Function
  243. Non US/Canada customers please read
  244. Hitec Freedom 9S w/ JR Synth TX Mod
  245. HS-5955TG a great servo
  246. Hitec Eclipse 7 throttle glitch
  247. Hitec CG340 Flashing light NiMH in Mode?
  248. HS-645MG Centering with FUTABA RX/TX
  249. Hitec Spectra 2.4GHz Module in my EVO and JR
  250. Hitec Neon-SS FM
