- using a Futaba module in a Hitec transmitter?
- 6985 Metal Gear upgrade
- hello hi-tec lynx 3d transmitter
- Is this servo dead? Solved!
- Fusion 9
- Servo Arms Supplied With 5955 Servos??
- Optic 6 Programming
- What gauge wire do the 5985 servos use?
- ECLIPS 7
- Difference between HS-6965HB and HSC-6965HB
- Buddy boxing an eclipse 7 to an optic 6
- Fusion 9
- 2007 Catalog now available on-line
- Is there a Fusion 12 in the works?
- 5955TG Servo Screw Size
- New HFP-10 Programmer will not Reset 5645
- EVO 9 Slider Gone
- Can Not Change Model Selection
- Revered trim on elevator
- Karbonite for metal gear swaps
- Whats the best throtle servo Mr Glavin?
- Optic 6-Flash 4 trainer cord problem.
- Dummy conversion question
- Transmitter Batteries
- *5645 Digital Servos**
- Optic Sport?
- MOVED: beginner servo problems
- Eclipse version update
- Evo 12 synth.
- Optic Trainer Cord Problem
- Hitec 5955 Deadband/Resolution
- 5985 Overvoltage
- Hitec Micro 555 antenna length
- dual elevator servos
- Multiplex Profi 3030 Output power
- Charging Optic 6
- Optic6 E-Heli tail rotor issues!
- New 5945 vs. "old" 5945 Question
- royal evo 9channel synth RX
- Hs 65 hb
- Hitec 5645 Issues
- 5955TG plastic arm rated 333oz?
- OPTIC 6 /SPECTRUM MODULE
- replacing 5945 servo case
- Hitec 6S Reciever - Rainge comped with JR R700
- 5955 Jittering Problem
- 635 servos gears
- eclips 7
- Hitech 05S Micro Recv.
- 5955 TG and Ver 1.03 programmer
- Hitec str. servo for T- Maxx racing
- Digital servo buzz
- Hitec Servo Arms
- QPCM acting funny
- Eclipse channel 7 Mod?
- Hitec servo programmer
- Can engine fuel or smoke damage the evo tx case?
- programing 5925mg with hfp-10
- Hitec Spread Spectrum
- Crow Programming in Optic 6
- Any problems with Hitec HS-635HB servos
- E7 need help!!
- How can my Eclipse comeback
- Servo Deadband Programming?
- multiplex receiver
- 5985
- HS545 hi torque servo ?
- Optic 6 and digital servos.
- multiplex question
- HFS-05MS + Optic 6 + retracts?
- EVO12 Purchasing stick extensions ?
- Fusion 9 Remote Programming
- Hitec RX for gas engines
- lock out (hit) on optic 6 ?
- New HS-6975HB servo's ?
- SMOKY 5955TG
- Dual RX batt on HPD-07RH QPCM RX
- Pairing 5955 and 5645 on same surface?
- Is 2nd "landing" switch possible?
- Spektrum and 645/625 servos
- Corona 9 Information
- What is in the Hitec Pipeline
- Substitute for HS5925MG
- Optic6 throttle cut w/twin?
- 5475 question
- Hitec/RCD crystals
- Hitec and JR Servo's - same factory??
- Is This Normal?
- Machined Servo Horns
- Hitec servos with 6 Volts
- 5645 mg or 5925mg and servo programmer?
- Digital micro
- Cockpit SX
- I have a T-Maxx 2.5 and want more powerfull servos
- HiTec HS5955 TG Version?
- Optic 6 questions
- Shopping for a transmitter
- HS81MG Jittering at starting
- HFP-10 Programmer Version?
- New Multiplex??
- Rotating Servo Gears 180°
- HS-125 MG
- Source for Mg servo output shaft screws?
- Programming 5955's
- Programming Question
- Did I fry my 5955?
- Multiplex Manual!
- Hitec Rx DSC compatibility
- What is a left hander suppose to do?
- LN5014 Charger Woes
- 5945 Servo Problem
- servo recommendation
- Max servo degree's HELP!
- servo repair
- Servo repair
- Fusion 9 Availability?
- Single conversion receiver with Optic 6 Transmitter
- restoring 5645s to default
- please tell about theese servos
- Servo Service
- how good is hs77bb?
- Eclipse Help
- Servo resolution with Fusion 9 Rx
- Hitec HFS- 05MS 5-Channel SC Micro Receiver
- Glitching HFS-05MS Micro Receiver 35Mhz
- Blue Arrow Compatibility
- presice hitec servos
- HS-5245MG question
- Tx, Rx and servo resolution question
- new Hitec radio?
- Ready to throw my Hitec Eclipse 7 out
- Memory Battery?
- 5645s with JR: servo extensions
- Hitec HS-475HB servos - Support
- Servo arms on 5955TG servos
- green sticker says 05.11 ? is this a older problem version?
- Transmitter range with collapsed antenna ?
- titanium gear set for 5945
- HiTec servo problem
- hs5925 use hs5945 gears?
- centering problem with my 5945
- 5645 servos vs 5845 servos.
- Hitec Reciever Compatibility
- Servo General question
- 555 for Electrics Only?
- Flap servo over travelling
- Programmer Software Version?
- Problems with Carbon Booms
- Hitec setting expo
- Optic 6 Model memory loss
- Digital Mini 5245 and 6V
- Extending servo wires
- Fusion 9 w/ Saito .82 4 stroke
- HS5645MG Gear Play
- elevator trim on flash 5
- HFP 10
- hfp 10
- 5955, 5995 "lock-up" during operation??!!
- Optic 6, 3-D Heli Throttle Setup?
- HITEC Options
- Fusion 9 glitches...
- trading gear sets
- Electron 6 v/v Futaba 9C with syn module
- I Have A Problem
- I Have A Problem
- HFP-10
- Optic 6 Low Battery Warning Voltage?
- Discontinued Servos
- Connecting 5955 Aileron Servos via Double Link?
- Spectra Modules Cases
- rang of a the hitech micro reciver ?
- hitech hs81 mg
- HFD-08RD
- 5955 question
- Servo Warning label
- What size of servo
- Multiplex mini IPD 9channel problems
- Any talk of an Optic 8?
- Not enough throw
- Why will multiplex radios not work with my device?
- Karbonite Limitations???
- royal evo 7
- Hitec HFP-10 Servo Tester
- HS55 Problem child
- Hitec w/ spectra
- Optic6 and Expo function on CH6
- Can't charge thru TX port with my charger
- Q-PCM
- optic 6 Q-pcm
- Eclipse 7 split elevator ?
- Michael Glavin & Mike Mayberry ???
- 6 Meter modules??
- HFS-03mm Glitch Out
- hitec eclipse 7 problem
- Futaba RX verses Hitec digitals.
- Royal EVO Charging question
- 5997TG question
- 5955's and Loctite?
- SPLIT ELEVATOR SETUP?
- Hitec 5645
- Hitec 645 MG Servo's
- power off- locked digital servo??
- Optic 6 charging problems
- HS-225MG servos Will not center
- Optic 6 inhibit trim levers?
- Hitec eclipse pro car
- Question on Smoke Pump set up
- Optic 6 timer alarm too soft
- 5925 dead band
- Eclipse Question
- Hitec Optic 6 with a JR R610M Rx (35Mhz)
- IPD 9ch Synth Current Capability
- Hitec Eclipse 7 TX suspect
- Multiplex PCM?
- 5955
- HS 5945
- hs 81 as retract servo???
- Copilot and Hitec
- HPD-07RH receiver question
- More Flap travel for Optic 6
- Hitec 5625 Servos
- Variable exponential not possible with Evo 12
- Help Please Evo 9 Just quit
- BEC Bypass & ganging 3 servos
- HFS 04MG & servo ganging and/or BEC Bypass?
- Eclipse 7 QPCM
- Optic/Spectra Glitching
- Optic 6 TX Battery Connector
- Optic 6 Heli Trim
- Recommended servo for gas throttle
- Eclipse7 or Optic6
- HFP-10 Programmer
- Hitec digital servos have horrible resolution
- Crystal for Laser 4 transmitter
- Hitec 5945 servo gear replacement: when
- profi 4000 dual rate switch
- 5955 factory default servo speed?
- Feather light
- Eclipse 7-channel - User Preliminary Tests
- Hitec RCD web site --down?
- HS 5645 servo ganging?
- Cockpit MM-Reverse Polarity protection?
- Range with ant collapsed?
- Which Servo?
- Failed Spectra module!
- Optic 6
- servo question
- HS225 servo arm??
- programer EP question
- Hitec HFD-08RD Reciever with a JR 2610 Tran
