PDA
View Full Version : Aerodynamics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16]
  1. Seduction Freestyle trim problems
  2. horizontal stabilizer dihedro
  3. Approximate payload for a Eagle 2
  4. Will shortening the original aileron length change flight charachteristics?
  5. Thickness tips section in relation to root section
  6. Giant Telemaster
  7. snap's out of loop
  8. Math problem calculating Wing Length to wing area!!
  9. DP 330 Ailerons Quick fix ? FOR fLutter
  10. Adding flaps to flaperons
  11. CAD Software for RC Models
  12. career Opportunity- Research and Development Technician
  13. Flat spin question
  14. Undercambered Airfoil
  15. Washout and wing incidence
  16. Wing loading
  17. Diameter VS Pitch
  18. Wng loading
  19. Propelers / Altitude
  20. Questionable C.G. Location
  21. finding neutral point and static margin
  22. Flapping Ailerons
  23. Delta's and CG via flight testing...
  24. Need help, I accidently lowered the engine almost 1/2"
  25. Designing for Stability in Knife Edge
  26. Kadet LT-25 modification
  27. pitching mixes with rudder
  28. H9 Cap Airfoil
  29. Location (vertical) of stabilo
  30. Giant trainer flies funny
  31. Flaperons
  32. Enlarging a wing, HELP!!!
  33. Swing-wing plane.
  34. Caps & Giles Bad Habits
  35. Counterbalanced Elevator
  36. basic parameters for a 'park flyer'
  37. aerobatic biplane incidence
  38. Goldberg Tiger 2 Rplls
  39. CG calculation and strip ailerons
  40. Incidence Question
  41. Airbrakes on underside of Wing
  42. Naca 0014 Vs S8035
  43. Blueprints??
  44. Drastic pitch towards belly when using rudder
  45. Washout with a tapered plank wing?
  46. wheres the CG?
  47. Stab Size
  48. Wing incidence
  49. NEED HELP!!! Scratch-building a V-22 Osprey
  50. Pusher vs pull prop designs
  51. E203 characteristics
  52. Leading "EDGE" shape
  53. Flap aerodynamics
  54. Northstar Elevons?
  55. Wing Loading
  56. Competition Aerobatic Airfoils
  57. Combine the aerodynamics forums?
  58. Can incorrect wing incidence be corrected with ail, elev, or eng thrust adjustments?
  59. ? for Aeronautical Eng.
  60. Cowl Air Routing and Possible Forces
  61. how to figure out how much thrust my engine/prop are putting out
  62. Center of gravity
  63. Biplane CG
  64. Thank you to Ollie and others!
  65. New site improvements and CAD tutorial
  66. Thrust angle on pusher wings (Zagi) -up=Down?
  67. Rough or Smooth?
  68. wing location on fuse
  69. Spoileron Question
  70. How much right thrust/ when to add right thrust/ rules of thumb?
  71. Left rudder causes dive and right roll.
  72. pitch coupling
  73. What causes snaps?
  74. Angles of incidence for Sig Astral Hog
  75. barn door ailerons
  76. Airfoiling stabs on a Dominator
  77. airfoil help - PLEASE!!??
  78. Possible adverse yaw?
  79. Flaperons and Spoilerons misbehaving
  80. Scratching a G-202
  81. Forward swept wing?
  82. ModelCad 3000 Help!
  83. Airfoil software
  84. Edge 540 vs. Extra 330
  85. fin area for deltas
  86. Long narrow wing vs short wide wing ?
  87. Boost Tabs for servo help
  88. Low-wing aircraft and knife-edge
  89. 3 and 4 blade props
  90. Horozontal stabs DO produce lift
  91. Prop Idea for a 100cc motor
  92. Aspect Ratio and Wing Loading
  93. Size of prop to balance?
  94. How do I set up flaperons?
  95. Engine thrust angles
  96. Wing chord vs. CG
  97. Wing Area Calculations
  98. Rudder hinge line
  99. need tips on adjustable props
  100. smap problems
  101. finding the c.g. of a biplane with both wings swept
  102. Total Lift
  103. no dihedral and no ailerons
  104. Greater lift; flat stab vs. airfoil stab?
  105. Balancing Props
  106. Low RE high lift
  107. Dura-Plane with Flaps?
  108. Engine offset thrust
  109. Center of mass on an airframe
  110. MiG-17
  111. Biplane Incidence ?
  112. Goldberg Extra mods
  113. Bearcat airfoil?
  114. Wing-Stabilizer incidence on Ultra Stick
  115. How many G's can I pull
  116. SPAD! What makes these coroplast things fly so well?
  117. Aeromaster II Spirals In When Engine Quits
  118. Flaperons: Up or Down?
  119. Engine placement question
  120. Going really fast
  121. Airfoil For Tailless Delta/flying Wing
  122. Reynolds number question.
  123. Need to improve flight performance
  124. undercambered vs flat bottomed wing
  125. 1st scratch bipe
  126. delta wing incidence?
  127. Force on Control Surfaces; Servo Torque Reqmts
  128. Low Dihedral, Polyhedral (gliders)
  129. Plates on the wing tips?
  130. 3-d elevator effectiveness
  131. What to expect when you thin down an airfoil
  132. Need Airfoil help
  133. ANHEDRAL angle effects
  134. Engine Thrust Angles
  135. Spitfire Tip Stall Problem
  136. Trailing Edges on Large Scale Aerobatic Planes
  137. Rounding Landing Gear Edges, Etc.
  138. ***** Seal This! *****
  139. Building A "hybrid" Will It Work?
  140. Power Determination
  141. Thrust angles: designed in or programmed?
  142. Destroyed wing. Reason: forehead
  143. Calculating CG
  144. Forward Swept Wings
  145. Compufoilers
  146. Trailing edge dilemma
  147. Wing tip design?
  148. Bending loads on aluminum tubes
  149. FA18 MAC Calculation
  150. Dihedral
  151. Hey Ollie, Here is the Curtiss S03C
  152. Wing and Stabilizer arrangement for aerobatics
  153. Shifting wing!
  154. Biplane incidence setting
  155. Canards-- what a canard!!!
  156. Flaperon
  157. Airplane design
  158. Can too much power be detrimental?
  159. Question about CG
  160. Airfoils
