PDA
View Full Version : Batteries & Chargers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. Alkaline much better than heavy duty?
  2. Selecting Batteries for a 30-size Nitro Heli?
  3. THE MEN AUTOMATIC RC SYSTEM CHARGER C-50/4
  4. trickle charge all winter?
  5. 6volt vs. 4.8volt
  6. Nicad charging
  7. NiCad battery capacity for 1/4 scale models
  8. Charger max 700 mA Batteries?
  9. Unexpected results with Triton
  10. Top of the line
  11. 6 volt battery lead extension
  12. Discharging receiver batteries-lowest voltage
  13. Batteries
  14. accu-cycle plus
  15. anyone who has made thier own DIY field charger?
  16. LIPO STORAGE TEMERATURE QUESTION
  17. Charging 2 Gell Cells at once
  18. Li Po Swelling Up!
  19. Duralite Charger on Powerflite batteries?
  20. Ultra Sport Battery
  21. Hitec TX charge rate
  22. Help understanding batteries
  23. Who sells receiver battery packs?
  24. AccelRate - new co. w/unlikely claims
  25. fiberglass lipos
  26. AccuCycle Elite timer question
  27. Simple Rx/Tx Charger, discharger
  28. A REALLY Stupid Accu-Cycle Question
  29. best RX battery?
  30. Transmitter making charger glitch
  31. Trouble charging JR Extra 1400
  32. charging loose cells?
  33. Reading a Matched Pack Label
  34. Battery ?????
  35. Battery (NiCad) capacity question
  36. Lightest and highest Capacity Ni-Mh
  37. Hovering Voltage
  38. How old is to old?
  39. True/False - Stuck on a Mi MH Question
  40. Charger wiring question
  41. Starter battery charging, part 2
  42. Pro tech 706 Charger
  43. Battery status during the winter
  44. Red, Your Valued Opinion Please
  45. Schulze 330d - What do you use the 2nd port for ?
  46. 6-volt flight packs and odd Servo action ? UPDATE
  47. Hanger 9 Sure Cycle question
  48. New TX Pack Has The Best Of Me
  49. Another Battery Charger Question
  50. REWORK BATTERY CONNECTION
  51. New Battery, No Connectors
  52. Fromeco Products Question
  53. Any chance of saving my batteries?
  54. Accu-Cycle Elite & Lead Acid?
  55. Battery University
  56. Polyquest lipoly wire length for BL
  57. Alpha 4 question
  58. How many batteries do I need?
  59. Voltwatch and Remaining capacity
  60. Dual Battery System
  61. What kind of power supply?
  62. Starter battery charging ?
  63. NiHM RX Packs
  64. Hobbico's Quick Field Charger MkII for DURALITE Batteries??
  65. Transformer x 2
  66. Planning on gettingt triton, however....
  67. "Flat Limited" - Eh?
  68. power supplies
  69. Battery Selection for Heli Setup...
  70. How to I keep track of my pack's vital signs?
  71. Larger Bat. for Futaba Tx?
  72. Overcharge
  73. eagle racing 1796 cdc charger version 6b help
  74. C/10=2xC/20?
  75. 'Suggested' charge and discharge rates
  76. shulze charger problem
  77. Will a Futaba charger charge NiMH?
  78. Any Suggestions In Need of a Charger
  79. Runtime
  80. Triton charging Kokam LiPo
  81. If you had the choice?????
  82. Redundent Battery System
  83. Thunder power 2 cell 2100mAh
  84. Growing out of NiMH. Wich charger to get?
  85. Ultimate Charger Design
  86. alkaline or heavy duty
  87. Triton charging 12V Pb
  88. Battery/Charger Problem
  89. ACE Super Digipulse Question
  90. Sweet Scent from Lipo and Dented lipo
  91. Discharging without a cycler? And increasing Tx/Rx bat capacities?
  92. Total electric newbie! need help!
  93. How many chargers do you have?/Whats your favorite?
  94. 12v dc converter 3 amp
  95. Field Charger Suggestions?
  96. New li-po for power box
  97. duratrax ice charger
  98. Duratrax ice adaptors
  99. Who got cheapest batteries for homemade packs?
  100. 5000mah 1.2v powerized batteries?
  101. Question on Accu Cycle Elite
  102. charging my 12v field gear battery
  103. Super Brain
  104. Accucycle VS. Triton
  105. Duratrax Ice-Tritons big brother
  106. triton or duratrax ice
  107. Triton or SuperBrain 969 Pro
  108. got some questions about li-po battery
  109. MRC 969 Product Hazard Alert
  110. Finally Affordable Li-poly's
  111. Charge LiPO in parallel?
  112. Duralite Power Box SC-12 review now online with videos
  113. Using VoltWatch with NiMH GP3300
  114. Have you purchased from MaxxAmps?
  115. Emcotec dpsi question
  116. alpha 4 / sirius super test which 1 to trust?
  117. Another Lead Acid question.....
  118. sr-9 giant power ?
  119. Li Ion Capacity Determination
  120. BEWARE EBAY BATTERIES..........
  121. ALL IN ONE CHARGER?
  122. Battery Storage Question
  123. Kokam Lipo-402 Charger Warning!!!!!!
  124. Can Lipo's be used as receiver battery?
  125. What to buy after Accu Cycle +
  126. Odd battery size 1/2A needed (17mm x 27mm)
  127. Looking for a Two Channel Charger/Discharger
  128. Proper Setting for Hobbico Quick Field Charger MKII?
  129. DuraTrax Charger (Digital Pulse Charger)
  130. Triton Newbie needs help.
  131. Parallel Charging LiPo?
  132. Dynamite Vision Peak Ultra
  133. Voltmeter??
  134. Questions for upgraded tx batt
  135. Ni-cads - NiHMs - Li-POs
  136. accu-cycle problems?
  137. Battery charger Circuits
  138. PowerfLite market?
  139. WILL THIS CHARGE NIMH HITEC CG335
  140. 2000 mah Ni-Mh battery Charging Question
  141. New Accu-cycle elite...
  142. wieght diffrence between nimh &nicad
  143. Li-Poly Cells, A National Problem??
  144. Hi-Tec Eclipse needs a battery
  145. Regulator failures?
  146. mAh Upgrade question
  147. How do you make your own Lithium Ion packs?
  148. Newbie and his Triton
  149. CAN ANYONE GIVE ME ANY INFO ON THIS CHARGER
  150. Which Soldering iron/solder to use?????
  151. Sanyo KR-1500 AUL Nicad Cells
  152. Help - Hobbic Accu Cycle Elite
  153. How long will a 12V lead acid field battery last?
  154. Sirius vs. Accu Cycle?
  155. C-Volt
  156. Dumb Question - Charging 12V Motorcycle Battery???
  157. Charging Sullivan Head-Lite
  158. nikkon 9.6 pack for TQ3 radio
  159. Thank You Fromeco
  160. Accu-Cycle won't cycle single cells?
  161. Charging car batteries
  162. Power Supply for Triton.
  163. LiPoly Question
  164. Possible Accu-Cycle Elite Problem
  165. Hobbico Multi-Charger
  166. joining cells...
  167. Triton or Accu-Cycle ?????? newbie post
  168. Ripmax Pro-Peak Charger
  169. PC based power supply problem?
  170. Li-ion batteries on ebay Anyone used them?
  171. Best charger for $100?
  172. Charging GP3300 with MRC 959
  173. DuraTrax IntelliPeak Charger Questions
  174. NiMH DISCHARGING?
  175. Battery Tray/Holder for Charging 8 AA's
  176. Rookie Battery Question
  177. My charger says 7.2 volts and my battery is 6v
  178. what charger for 2700mah battery? Any help pleaseeeee.
  179. Determining mAh Capacity of a Cell?
  180. Huges + Charger
  181. ? For Red Re: Wall Wart Charging
  182. Charging/discharging basics...
  183. Alpha 4 charge harness
  184. too much mhA?
  185. Charging a 6 Volt flight pack ?
  186. Discharging with a single bulb
  187. Triton....9Volt batts
  188. Triton charger/Kokam Li 3 cell 1500.
  189. NEWBIE
  190. Chraging NiMH With NiCad Charger?
  191. Robbe power peak infinity 2
  192. looking for best value on charger
  193. MAT Gell cell
  194. Sirius having bad day??
  195. Wire for jumping diode on a 9Z
  196. charger leads for schulze
  197. Why can't GP make a 2 in 1 Triton ?
  198. Cycling Futaba (TX) Battery (6EXA)
  199. Hi powered D-cells. Worth it?
  200. what type of charger?
  201. GRAUPNER CHARGER REPAIR
  202. E-Tec 11.1v Li Po's 1200 mah battery
  203. TBM, 2350ma Li-ion
  204. Reciver Battery Question
  205. Charging Partially Discharged Packs
  206. Another Lipo Newbie?
  207. Triton Charger mounting screw size?
  208. help me learn! mAh/time??
  209. Dumb Charging Question
  210. Recommend a discharge rate
  211. Triton cutoff voltage FIXED at 0.8V???
  212. Triton cutoff voltage FIXED at 0.8V???
  213. AccuCycle Elite or Triton
  214. FORMATION? what is it and how to do it
  215. Estimating Ni-Mh remaining charge with Ni-cd checker?
  216. Poly Quest batteries
  217. What is point in overcooking during formation charge?
  218. triton charger
  219. Charge Rate/Duration Question
  220. RX batteries
  221. Discharger?
  222. Difference between 7.2v and .cell batteries
  223. How do I make an E-maxx's runtime longer?
  224. Lipo for Rx pack ? I need some help
  225. Still Trying to Get Charging Right
  226. Converting AA to 9.6 V TX battery.
  227. Li poly charger
  228. Will the MRC 959 charge above 3.0amps for 6 cell batteries?
  229. voltmeter required
  230. Pack design question
  231. Glow Power for 5 Cylinder Radial on Test bench
  232. Best Batteries
  233. unsafe battery voltage?
  234. Widebody 60 lost
  235. Lithium/no regulator to RX
  236. Please help.......
  237. Lipo vs. Nicad?
  238. How to charge Li-Poly
  239. Proof that Lithium users should be careful
  240. charger
  241. Quick Charging NiMh
  242. Will this charger work?
  243. GOOD Deal on Hobbico MKII Quick Charger
  244. Lithium polymer cells
  245. WHICH BATTERY?
  246. Reedy Ni-mH charging
  247. Discharging to .9v/cell
  248. Need a battery for 12 Hitec 5645's unique application tho!!
  249. Charge a rechargable Alkaline with my charger
  250. Triton questions
