futaba 3010 bearings
Hi easysport,
The S3010 has just a standard bearing preinstalled onto the output gear.
No, there is not an "upgrade" gear set available for it, only the stock gear set is available (FUTM3328).
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
