Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9C Case Cleaning
Old 08-27-2003 | 11:20 PM
Default 9C Case Cleaning
I was wondering what to use to clean the case. I used computer case cleaner on the black portion and that works fine but I cannot get sweat stains off the front of the case, it appears to have stained (it was hot that day, 114' ) What do you recommend for cleaning the case? TIA
Old 08-29-2003 | 01:34 AM
Shortman's Avatar
My Feedback: (21)
I would also be very interested to know, what I do use is Alocohol Swabs from my dads work (the local hospital). Its what they wipe on you right before you get a shot, its not a cotton ball but a very fine material thats soaked in alcohol.
Old 08-30-2003 | 01:39 PM
Thanks for the info but I have tried alcohol with no luck. It did work on my old Super 7. I even carried the swabs in my fight box. This is some kind of stain, not fuel or dirt, and it has discolored the plastic. I hoping for Futaba to have an answer as I can't be the only person with this problem and I don't want to destroy the front of the case.
BTW It's the best radio I've ever owned.
Old 09-05-2003 | 07:36 PM
Hi Bearair,
We would recommend a soft cloth and a mild window cleaner, such as Windex. This should take care of it for you.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Old 09-15-2003 | 09:21 AM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: 9C Case Cleaning
Yeah I have the same "spots" appearing on the silver coating of my 9C. It seems to occur near the corner areas. It's definitely not removable by alcohol. Looks like mild corrosion. I think it will get worse with time, and I expect that there will come a time when I will have to touch up with a little silver paint.
