Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Standard switch current capacity?
Old 08-28-2003 | 05:58 PM
RightThrust's Avatar
Default Standard switch current capacity?
I'm running a standard Futaba switch in my sport airplane with 3 9001's, a 9202, and a 3004. These are being powered through a 1020 mah Kokam Li-Poly battery and a 5-6V regulator, which i havn't decided on yet. My question is, will the switch be able to handle the current okay or do I need something different. I don't want my airplane to crash because of a weak switch. Thanks loads for your help in advance.
-Kelly
Old 08-29-2003 | 06:28 PM
Hi Kelly,
We do not have ratings on our switches, but with the information you have listed, we see no problem with the any of our standard switches.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
