Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9z Wc2 Problem
Old 08-31-2003 | 05:11 PM
Default 9z Wc2 Problem
I just buy 9Z Wc and everything intalled correctly.
I have mode 2 transmitter. But when I move the elevator stick, the throttle servo is worked (mixed with elevator command). I read all the manual but not found anything to solve this problem.
My heli is CCPM 120 degree.
Please help.
Albertus
Old 09-02-2003 | 11:07 AM
Go to PMX in the Condition menu; number two default mix is ELE/THR. See if it is active in any of your flight modes.
Remember that conditions rule on the 9Z. You always have to check every enabled condition when you change something.
Steve
Old 09-02-2003 | 02:23 PM
Thanks Steve, It's worked
Albertus
