 Evsd-5u-evo Gear Door Close Delay >
Old 05-28-2013 | 01:30 PM
DiscoWings's Avatar
My Feedback: (76)
Default Evsd-5u-evo Gear Door Close Delay
How do you set the Gear Door Close delay on Mode 2 on the EVSD 5 U EVO unit?
I'm having a problem where the Gear Doors are closing before the gear can close and changing the time settings on A and B are not making any difference. They only delay the gear from deploying and closing but do not make any difference between the time it takes the doors to close.
Any help?
Old 05-28-2013 | 04:31 PM
spaceman 01's Avatar
My Feedback: (44)
Default RE: Evsd-5u-evo Gear Door Close Delay
Hi there,
Try this . Switch the gear with the doors around, just put the door tubing to the gear fitting and gear tubing to the door fitting and it should work.
I had this problem with one of mine.
Good Luck.
Nick<br type="_moz" />
