 JB-220 Turbine >
JB-220 Turbine
JB-220 Turbine
Old 05-29-2013 | 04:40 AM
My Feedback: (24)
Default JB-220 Turbine
Does anyone have experience with this turbine when operating in a hot and humid climate? I like the weight and size of the turbine compared to the thrust. I am not familiar with JB turbines and I do not want to buy anymore paper weights.
Old 05-29-2013 | 05:33 AM
PaulD's Avatar
My Feedback: (39)
Default RE: JB-220 Turbine
Check with Olnico. He has done extensive engine testing in some pretty extreme heat/humidity.
PaulD
Old 05-29-2013 | 09:26 AM
My Feedback: (15)
It dosn't get a whole lot hotter or humid than south Texas. I have seen Barry fly his 180 gold several times and it performes flawlessly. I currently have a 220 on order from ultimate jets. I'm confident in them.
Old 05-29-2013 | 09:47 AM
DiscoWings's Avatar
My Feedback: (76)
220 sounds very goo 50 lbs in a 120 size can.
Old 05-29-2013 | 03:59 PM
Aero65's Avatar
My friend in Las Vegas has one, it's an awesome powerplant. I was only able to run it in his driveway before I had to go home it was very impressive.
He has since flown it in his JL-F22 and he said it was awesome.
Old 05-29-2013 | 09:03 PM
olnico's Avatar
We have lots of 220s operating in the desert. Dusty, very hot and low pressure. Density altitude can be as high as 6000 ft with OAT typically around 100 to 115 F. The 220 performs as all the other Behotec/ BF engines in these conditions: extremely well.
Behotec have made a tour de force with this engine. First of all every unit is delivered with a thrust reading sheet that is coming from the pre-delivery engine test and made with a lab grade test bench. I have confronted my measurements with theirs and we are always within a few %. The test bench that I have been using for many years to do the RCJI engine tests is also lab grade and I calibrate it on a regular basis.
They managed to get that much thrust in a 160 form factor thanks to intensive CFD using one of the most famous software in that segment. The compressor, diffuser, NGV and turbine wheels have been very thoroughly digitally designed.
The thrust of 220N is achieved at a fairly low RPM of 123000 RPM. The engine is also running fairly cold at 750c TGT( not EGT as the tempreature reading is taken in front of the turbine wheel ).
Furthermore they have adopted a new very clever design for the fuel sticks that stabilizes the combustion cycle a lot and make them much more durable in time ( less hot spots on old engines ). The rear bearing also has several patents. It is self-centering and has a very specific cooling pattern that makes it run very cold.
Old 05-29-2013 | 11:26 PM
ORIGINAL: olnico
That is very good. I have seen this diameter engine size do 600N but that is an (expensive) expendable missile engine with ceramic turbine. Do you have any idea on massflow and pressure ratio?
Andre
Old 05-30-2013 | 06:30 AM
olnico's Avatar
ORIGINAL: Turbotronic
Andre
No, I need to ask Thomas.
Old 05-30-2013 | 07:56 AM
a 220 in a jl f22!!!! overkill I belive
Old 05-30-2013 | 09:38 AM
jason's Avatar
Just out of interest what diameter is the turbine wheel?
Old 05-30-2013 | 01:47 PM
My Feedback: (24)
Edgeflyer, what part of Texas do you live in? I live in New Orleans so I want to hear from some guys with high humidity. Our weather is similar to the Houston area.
Old 05-30-2013 | 06:44 PM
My Feedback: (15)
Houston, but I won't fly this plane until later in the year most likely. Like I said though Barry from ultimate jets fly's his stuff at Houston fields also. I believe his handle is u2fast. maybe he would put my 220 in his big hawk and give it a try if he hasn't flown a 220 yet.
Old 11-09-2013 | 03:50 PM
Thai Tiger's Avatar
I've ordered this magnificent engine yesterday, should be ready by January according to Thomas, sounds like its worth the wait.
Does anybody have any advise on the fuel tank/bubble trap set-up?
Old 11-10-2013 | 01:20 AM
Hi all,
I live in Yokohama Japan, and as you know summer season of Japan is famous for one of the area of super high humidity and high temp on the earth.
i enjoy turbine model with many friend of jet freacks, most of my friend declined to jet flight by turbine surging (sama as compressor stall)couse by super high humidity.
Old tipe of Jetcat(Ex:P80SE),JB(BF) and all of Kingtech can be used without any problems in japanese summer.
Best regards,
K.Tanabe
Old 11-10-2013 | 05:09 AM
My Feedback: (24)
I bought one of these JB220's for my Tomahawk Hawk. I guess I will find out how they like humidity in the spring.
Old 11-10-2013 | 08:34 AM
olnico's Avatar
http://www.ultimate-jets.net/blogs/f...ing-cavitation
Old 11-10-2013 | 07:33 PM
Thai Tiger's Avatar
Thank you Oliver.
Derek Middleton
Old 11-30-2013 | 12:33 AM
Thai Tiger's Avatar
GBR CAT 260 arrived today.
Standing by for the engine..........possibly late December, just in time for Christmas.
