Good epoxy
My Feedback: (251)
HI all, as a lot of you guys know, I do a lot of building/ repairs, and i have found a really good epoxy. Always flows easily, sets up in five minutes, but is more expensive, not really when you have to throw out , that cheaper stuff, because it will not come out of the bottle.
See pic.
Also I use West System Epoxy, Milled carbon fiber and cabosil n-20 (anti-sag) mix.
I need help in finding a supplier of the milled carbon fiber ( not chopped carbon fiber, but milled), my original supplier Composite Canada, can't get it anymore.
Rcpete
http://www.cstsales.com/West-System-Adhesives.html
See pic.
Rcpete
Hi Rcpete,
Here you will find your happiness, but in Germany:
[link]http://shop1.r-g.de/4DCGI/ezshop?action=suchemultisb&ButtonName=&Beschriftun g=&WorldNr=1&sKontaktID=2798446&sKontaktKEY=xNs1Om 3kMULaKIjyogM70ogF4jMtAp&sTICKCOUNT=34339708&suchb egriff_1=Fillers&suchbegriff_2=Fibers&suchbegriff_ 3=&suchbegriff_4=&suchbegriff_5=&suchbegriff_6=&su chbegriff_7=&suchbegriff_8=&suchbegriff_9=&suchbeg riff_10=&clearlevel=3[/link]
FL
Pete,
Here you go:
http://www.aircraftspruce.com/pages/...lledfibers.php
Aircraft Spruce and Specialty has anything you might need.
Much closer than Germany.
Here you go:
My Feedback: (251)
HI, thats milled CARBON fiber, that I"m after.
Rcpete
<div class="picture">
</div><div class="prices">from <span class="price">76,04€</span> <span class="old_price" style="display: none">76,04€</span> <span class="no_tax">(63,90€plus VAT)</span></div><div class="permalink">Permanent link</div><style type="text/css">.iframes > .fancybox-skin { BACKGROUND-IMAGE: none; BACKGROUND-COLOR: white}</style><div class="note">Artikel merken </div><form id="form_herst_suche" method="post" action="/4DCGI/ezshop"> <input type="hidden" name="sKontaktKEY" value="xNs1Om3kMULaKIjyogM70ogF4jMtAp" /> <input type="hidden" name="sKontaktID" value="2798446" /> <input type="hidden" name="action" value="suchehersteller" /> <input type="hidden" name="ButtonName" value="Suche" /> <input type="hidden" name="pagetype" value="warengruppen" /> <input type="hidden" name="artikelhersteller" value="R&G" /></form><div class="manufacturer"><! Include: shop_manufacturer_logo ><span class="manufacturer_image">
</span> <! /Include: shop_manufacturer_logo ></div><div class="more_products">more products by R&G</div><div class="more_images"><! Include: artikeldetail_image ><! /Include: artikeldetail_image ></div><div class="properties"><h2></h2><div id="properties_content" class="content">
Fibre length: 0.1 mm
• Yields lightweight, hard filling compouds
• For epoxy, polyester, and vinyl ester resins
Milled carbon fibers are made from recycled fibers. The Carbon fibres used therefore are equipped largely with PU-sizing. Most of the sizing evaporates due heat generated at the milling process though.
When dry the milled fibers form fiber balls, which dissolveand spread out evenlyin the resin.
Application:
Manufacture of electric conductor coatings and adhesives, reinforcement of moulding and fillings.
</p></div></div>
Rcpete
</span> <! /Include: shop_manufacturer_logo ></div><div class="more_products">more products by R&G</div><div class="more_images"><! Include: artikeldetail_image ><! /Include: artikeldetail_image ></div><div class="properties"><h2></h2><div id="properties_content" class="content">Fibre length: 0.1 mm
Application:
</p></div></div>
