Could use some help with the Skymaster A4 Steering please
My Feedback: (58)
Looking for some help on the A4 hydraulic steering.
I have multiple air pockets in the lines and want to know the best way to get them out and ad fluid at the same time as its not setup like the oleo with nipple.
Any and all help is appreciated
Doug
Doug
Hello Doug:
Please take out master/slave cylinders out of airframe and disconnect tubes then bath whole cylinder in a cup of ATF and stroke it till there is no bubble out of nipples, keep one cyliner in max length and the other one in shortest length. Fill two tubes full of ATF then connect them with cylinders again. It's done.
There has been a thread on a similar setup here:
http://www.rcuniverse.com/forum/m_11...m.htm#11246140
Perhaps your can find an answer there. - John.
