 Composite Arf Mig 29 >
Old 06-09-2013 | 07:32 AM
My Feedback: (16)
Default Composite Arf Mig 29
Hello to all.
Recently purchased Mig 29.Does any one have a wrecked jet with good hydraulic valves.Old owner switched to air.
I want to use hydraulics as was intened for this jet.Contacted my,Composite arf rep.Said he would talk to Andreis
about parts I need.Been about a month.Have not heard back from no one.I also am looking for PST 1300R.I have one now.
But need another one to power this beast.Please feel free to pm. me.
I thank all in advance for your help.
Regards,
Walter
Old 06-09-2013 | 07:35 AM
DrScoles's Avatar
My Feedback: (18)
Default RE: Composite Arf Mig 29
Has down and locked done an electric conversion for this plane? They did my skymaster Mig, a little smaller plane. Everything I read about the hydraulics sounds like a nightmare.
Old 06-09-2013 | 07:57 AM
My Feedback: (16)
Yes I know.But need large hydraulic valve to operate scale functions.Have hydraulic pump.but need oil bag for it.Also
missing drogue chute assembly.
Old 06-09-2013 | 11:19 AM
LGM Graphix's Avatar
My Feedback: (22)
Lots of luck getting a response from Comp ARF about anything regarding the Mig. I built one over a 2 year period (should have been MUCH shorter) and trying to get parts that were missing, or even just answers was near impossible. It was absolutely horrific service. It's like they want NOTHING to do with the Mig, unless they're taking your 10K for the kit. I know everyone says that they get great service from Comp ARF, and what a great company they are, and I've had other comp arf products where sales and after sales service was good, but the way they dealt with their most expensive kit and what was at one time supposedly the flagship of their line was repulsive. I will personally never spend another penny with Composite ARF. I wish I had a better answer for you, but truthfully, if it's been changed to air and it's working, I'd just leave it alone. Are your gear the new generation at least with the locking mechanisms in the gear cylinders? I can't imagine having to deal with the original system at all.
As for the valves, I believe they has the Hausel label on them, same as the pump, perhaps try dealing directly?
Old 06-09-2013 | 11:54 AM
David Gladwin's Avatar
Walter , I don't post much on RCU these days, but, since I have built and flown and still have a Mig 29 , here goes:
I binned the original hydraulics, (pump , accumulator and electronic controller) they don't work reliably enough to be called airworthy, although Andreas blamed my lack of knowledge of hydraulic systems for my problems.
Mine flew with the South African ( they couldn't get the original system to work either ) Omega system but the pump output is such that actuation speeds of the gear is rather slower than I would like.
I now have a new Hausl pump and valves and this winter, I will get my Mig airworthy again, (using two PST 1300s, exceptionally reliable engines, with Weatronic radio which makes setup much easier) BUT using air for power except on the MLG. The hydraulic downlock on my Mig is achieved by closing Festo valves in the hyd line, actuated by the ECU. you don't absolutely NEED the latest, self locking, cylinders using this principle.
I have replaced the twin JR 8411 servos on each stab with a single JR 6301 servo which gives more than the torque of twin 8411s with half the chance of failure.
I concur with Graphix about CARF service on the Mig, I spent a huge amount of time, money and effort working out the bugs and getting mine airborne, but zero help from AG, never, ever again.
A shame really, it is a MOST impressive model and is a *****cat to fly and mine WILL fly again.
David Gladwin.
Old 06-09-2013 | 12:44 PM
storrie23's Avatar
Hi
I have all the hydrolic valves and parts, plus all the Omega valves and parts.
I switched to Matrix air, works great.
Call me at 289 362-1373
Regards
Chuck
Old 06-09-2013 | 02:13 PM
My Feedback: (16)
Thanks.I was following your thread.I know this jet has its problems.But for me.No other jet has it's prescence in the air.
I am determined to get this in the air.You are right about support.I bought a Kangaroo and Eurosport.Had no problems
then when you buy something.
well thanks again on your input.
Regards,
Walter
Old 06-09-2013 | 02:20 PM
My Feedback: (16)
Yes I was following your build.
you are right about their customer service.I bought a,Kangaroo and Eurosport from the.Every thing is fine when they take your money.
I know this jet is a pain in the a/////.But for me.No jet has the prescence in the air as this one does.This is my ultimate jet.Have many others.
Now I have this.I don't care about others.I am determined to get this jet in the air.Thank you guy's for your post.
Regards,
Walter
Old 06-09-2013 | 02:35 PM
My Feedback: (16)
Thank you David for your reply.
love my PST1300 R.Need another one.I will look into those servo's.
Regards,
Walter
