 Afterburner rings/light set >
Old 06-20-2013 | 03:29 AM
Default Afterburner rings/light set
Gday Fellas, after some advice on getting some afterburner lights and nav/landing lights for my F15.
What is the best/reliable around, and where would one obtain these little gems?
Ive seen the ones that Dreamworks offer, and some from HK ...yuk, but not much in between.
Cheers
Matt
Old 06-20-2013 | 03:36 AM
Default RE: Afterburner rings/light set
As far as I'm concerned the best is Detail 4 Scale.
Ivan
Old 06-20-2013 | 03:44 AM
Give Peter from Intairco a call and he can get them for you from Detail 4 Scale. I can assure you you will be very happy with quality of these lights.
Old 06-20-2013 | 11:05 AM
The best system is from airfighter.eu in Germany. Take a look at the Big Afterburner its a three ring set up, or they will make you one for your size tube, with as many rings as you can fit.
David
Old 06-20-2013 | 10:28 PM
Thanks fellas, I've sent Pete an email, will have a look at the german jobbies.
Any other suggestions?
MH
Old 06-21-2013 | 04:22 PM
757Driver's Avatar
My Feedback: (90)
I've been very happy with the Dreamworks units. Actually had a gentleman comment on how good hey look even in full summer sun.
Old 06-21-2013 | 04:44 PM
smchale's Avatar
My Feedback: (67)
ORIGINAL: Justflying1
Ivan
+1. I've been very happy with mine, and Dan has stood behind the product.
Old 06-21-2013 | 06:24 PM
sysiek's Avatar
My Feedback: (176)
I have mine from rc lander two sets 70mm for rafale jet,and two sets 90mm for eurofighter under $20 ea + the navy lights nothing bids the price and work perfect ,use one controller for two rings works the best with small 350mah 4s lipo.
Old 06-23-2013 | 05:50 AM
jason's Avatar
Xicoy do a good range of afterburner lights along with a controller and seem to be priced right too.
http://www.xicoy.com/catalog/index.p...vvp3an1307rph7
Old 06-23-2013 | 11:02 AM
+1 for the Xicoy :-)
http://www.youtube.com/watch?v=vP2aIyzddSc
http://youtu.be/SD6YUDCcrxE
Bye
Stephan
Old 06-23-2013 | 06:25 PM
Ron101's Avatar
My Feedback: (22)
I got a chance to see the Electro Dynamics system a few years back at a meet... it was installed in a yellow F-15
It was nice and bright even in summer sunny conditions..... I need a system for my F-18. I was thinking this system
But want to look into the dreamworks system a bit more, I want them as bright as I can get
http://www.electrodynam.com/rc/EDR-117/index.shtml
Old 06-24-2013 | 02:48 AM
smchale's Avatar
My Feedback: (67)
Ron, I suspect your exit size will be quite large, how much difference do you have between you Mylar duct and the nozzle?
Old 06-24-2013 | 06:12 AM
Ron101's Avatar
My Feedback: (22)
Hey Sean,
I don't plan on running afterburner rings
just wanted nav and landing lights.... so I really just need a simple light setup....
the Dream Works system might be all I need, and if I want to add afterburner I can... I think my thrust tube will be 90 to 100mm leaving about 5mm around the tube... so the 110mm ring would be perfect
