9CHP Question?
OH
I have a 9CHP and would like to know if I can set it up to run Elevons and channel 4 and 5 for the rudder. What I am trying to do is have a servo on channel 5 to operate the steering gear and 4 for the rudder. Any help would be appreciated. Sounds crazy but doing a little experimenting.
Hi Blair61,
Yes, you would just need activate the Elevon function, then go into Aux Channel and make channel 5 Null. Next go into a blank Pmix, make channel 4 the master and channel 5 the slave, Link should be off, Trim should be On, and assign this to a switch. In the next screen make both percentages +100%, and this should be what you are looking for.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
