P-20 Pipe Distance
My Feedback: (7)
Any P-20 guru's out there can tell me the distance needed/recommended between engine exhaust nozzle and bellmouth of pipe for proper thrust/cooling performance ?? My first experience with this little guy. It's cuter than a bug though !!!
TIA,
Danno
TIA,
Danno
On the small engines its even more important to get it right. You can easily waste 30% of the power if doing it wrong. I always test before installing to really know. Static thrust is the most important with these small engines as when airborne you can fly anything on very little thrust :-P
[youtube]http://www.youtube.com/watch?v=adO9NiI7edA[/youtube]
Yep...L1 take away 20mm = 15mm
Depends on the pipe like I say. JC's measurement on the bell which vary is misleading. Its the tail pipe to hot tube that is critical
Dw
Dw
ORIGINAL: Chris Pyrah
Hi
20mm from end of turbine to lip of thrust pipe is where I have mine and works very well
Hi
