B-58 Hustler Resurrection
I've had the B-58 setting around here long enough. I didn't like several things about the way I had designed it in the past so I decided to redo everything and turn this in to a test bed for the new one I'm designing. Re-hinged the elevon's, moved the servo from using a torque rod to using a control arm. Hopefully that will prevent the possibility of flutter. Hooked the Drag Chute and release up and it works perfect. Now I need to start on the massive amounts of hanger rash. Wish they made Benadryl for this kind of RASH !
My Feedback: (102)
That thing is gorgeous. years ago I had a VHS tape of one ots flights when it was DF and I was always amazed thinking you had reached the pinnacle of the sport if you could do something of that magnitude. As corny as it may seem, your work was a ninspiration to some of us. Can't wait to see its revival.
Tommy
Tommy
So true! I remember staring in awe at this plane at a ducted fan fly-in somewhere in Texas long long ago. It was awesome back then and with turbines I'm sure even more so now. I would very much like to see it fly in person again. Very motivational. Keep us posted.
ORIGINAL: Corsair102
Butch
I would love to Fly it again
Lee
Butch
Lee
My Feedback: (57)
I'd go classy, a pair of small can VT80's should fit inside those two inboard nacelles just fine. They would act like a bypass tube.
I worry about the landing gear though. Looks like a delicate work of art.
Does the nose gear swing out like the real one?
David
David
Well I finally finished the drawings and started cutting. It was a long time coming but at least it is correct!
http://www.youtube.com/watch?v=0E3Ee...ature=youtu.be
MD
Hey Butch,
Whats the length and span of the one you're cutting now?
I was at Bergstrom AFB the year it flew at the Southwest Fan Fly. An epic memory for me and has always been on my "Bucket List"
Joe Grice
Joe Grice
