Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
battery
Old 10-02-2003 | 03:02 PM
Aero-Junkie's Avatar
Default battery
I have a 9c fm radio and I want to run 7 futaba 3010 high torqe 6volt servo's in the new christen eagle. What mah battery or batteries and wire configurations should I use
Old 10-06-2003 | 10:20 PM
Default RE: battery
well its a couple days later and no reply. But I found out on my own. IMMA General Recommendations call for On board batteries shall be a minimum of 1000mAh up to 20 lbs,1200mAh for 30 lbs, 1800mAh to 40 lbs and 2000mAh for over 40 lbs . Batteries should be able to sustain operating power for a minimum of one hour! Second battery packs are highly recommended for larger aircraft!
