Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9Z ATV Limit on CH5-8
Old 10-07-2003 | 06:21 AM
Scott Smith's Avatar
Default 9Z ATV Limit on CH5-8
I have 'ATV Limit' set up on CH 1 and 6, flaperon enabled.
Enable Airbrake and Right Aileron input (CH1 - up), the limit works fine, Left Aileron input (CH6 - up) overdrives the left servo...there's no limit. Did I do something wrong?
Scott
Old 10-10-2003 | 03:09 PM
Default RE: 9Z ATV Limit on CH5-8
Hi Scott,
Go into the FUNC Menu, select Flap (FLP) then select control (CTR) and select J1. Now your "limits" will work for both aileron and flap.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Old 10-19-2003 | 03:24 PM
Didn't work. CH6 still overdrove. Guess it's a software bug [&o]
