Futuba T3PDF - 3 Channels
Hi All
I am trying to install my my dicsbrakes om my FG car. I am trying to get the 3. channel servo to control the front discbrake. Do anyone know how the get the Futuba Controller to use the 3. channel for my frontdics.
According to the manual is should be possible, but i thought that I would be able to activate the 3. channel by using the gas/Brake throttle on the controller. I can only get the servo to work partly with the 3. channel lever and not the throttle...... PLEASE HELP!!!!
Hi carlsenjesper,
Unfortunatley the 3PDF does not have the capabilities of having the 3rd channel assignability as does on other Futaba radios.
You may want to try setting this up with the 1P, which will move the brake servo as long as you hold the switch in the up position, or you can try 2P or 3P to see if this better fits your needs.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
