Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Reversed polarity?
Old 10-09-2003 | 06:27 PM
Default Reversed polarity?
I have accidentally touched with a screwdriver pins from the battery connector on the mainboard of my T6Xs. The transmitter was turned-off.
The small spark appeared. I know it is not good for a battery pack, but could it damaged the transmitter in any way?
I have checked the full range and it is OK.
Regards.
Old 10-10-2003 | 02:18 PM
Default RE: Reversed polarity?
Hi Marian,
This should not have damaged your transmitter at all, and having given you a good range check, you should be fine.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
