Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Radio tuned for channel 38
Old 10-13-2003 | 06:55 PM
Default Radio tuned for channel 38
I was at the field 10/13/03 and one of the guys started getting hits and the plane was doing wild things and finally after a while it went in the ground. He said when he purchased the plane[RTf] it had a receiver for ch42 so he put 42 crystal in the radio, which was tuned for 38,how much problem would this cause. I know it is against FCC rules to do this. what does it do to the freq. when you change crystals in the transmitter.
Old 10-15-2003 | 10:55 AM
Bax
Default RE: Radio tuned for channel 38
With transmitters, they are tuned to their specific channel. If you change the channel, it's possible that the transmitter's output is off-channel slightly, or even "splattering" across several channels. The only way to check is to use a spectrum analyzer to see the actual output spread. The farther apart the two channels are, the greater the potential difficulty.
That's why the FCC has the prohibition.
