Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Futaba ofst, what is it? Manual puts me to sleep
Old 10-18-2003 | 01:26 PM
Default Futaba ofst, what is it? Manual puts me to sleep
Hi,
I have a new Futaba 9C TX, and need some help understanding what the OFST setting is, and what it does, and also NULL. Some programming examples would help. The Manual puts me to sleep!
Slyskydogg
Old 10-20-2003 | 09:45 AM
Default RE: Futaba ofst, what is it? Manual puts me to sleep
Hi Slyskydogg,
An Offset mix (when Offset is master) will activate your slave channel a fixed amount. This gives you a changed Neutral position to the servo you have chosen. This offset position never varies, and it acts kind of like a snap roll or engine kill, but it can be used on any channel that has an on-off switch.
Null, is just what it sounds like, when you have a mix set on a switch and you set the switch to Null, the mix is always active, and can never be changed in flight. So the movement of the switch is "null".
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
