The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Plane 'Start-up' Stand
Old 10-21-2003 | 08:49 PM
SAPropbuster's Avatar
Default Plane 'Start-up' Stand
I KNOW I have seen plans for this stand somewhere..
Can someone help me?
This picture was taken at the San Angelo Fly-in. When it wasn't RAINING!
Old 10-21-2003 | 08:51 PM
Crash Master's Avatar
Default RE: Plane 'Start-up' Stand
I think I remember seeing something like in the AMA mag a few month's back. Sorry that i don't remember which month.
Old 10-21-2003 | 09:00 PM
GaryV's Avatar
Model Aviation August, 2002 page 66
also at this website
http://www.meroke.com
GaryV
Old 10-21-2003 | 09:01 PM
Joe Ortiz's Avatar
My Feedback: (75)
I don't know what your building abilties are, but it looks very simple to build by looking at the picture, I think I'll build one for my back yard
Old 10-21-2003 | 09:26 PM
Thanks a bunch, GaryV....That is it exactly!!
That sure is a great website. You belong to that club?? You have a very talented Webmaster!!
We have a (somewhat) clumsy member that has a difficult time stooping to start his plane. If we build one of these for him (and maybe a few more) he will stop using his body to tach his engines and spattering blood on the tarmac.
Old 10-21-2003 | 09:44 PM
GaryV's Avatar
Bob,
No, I don't belong to that club, I live in Virginia.
I just had the info handy because I plan on building a couple for the club I'm in this winter.
GaryV
Old 10-21-2003 | 09:47 PM
Built one this past week using the planes from the meroke.com web site. You need to be alert to just what you need, the plans do not tell you the quanity of the pieces, they just give you the size. I also found I needed one extra 2X4 piece then what the plan called for. It might have been because I didn't cut the pieces right, but I didn't have alot left over when I was done. Getting the front legs to line up is a little hard also. I don't have alot of power tools, Norm Abrams I'm not, did mine with a skill saw and cordless drill. Not a bad effort but a miter saw or table saw would have been nice, I think I have talked my wife into letting me get one. I took mine to our field this past weekend and it was a total hit. The total cost (less labor, thats free) was around $45.00 from the local lumber store. Good luck.
Old 10-22-2003 | 03:17 AM
Here is a modification I made to my startup stand.
The shelf in the front. comes in very handy.
Lee
Old 10-22-2003 | 02:44 PM
I've used a similar setup but found that, with a low wing plane, when you go to full throttle, the tail will come up and the prop will chew into the wood (if you are lucky!) or the plane will flip vertical. I think having the wing rest on bars, rather than the landing gear rest on a surface, will make this less likely to happen.
Old 10-22-2003 | 03:55 PM
My Feedback: (506)
ORIGINAL: GaryV
lso at this website
GaryV
bookmarked.
I am so going to build a couple of these for our new field!
Old 10-22-2003 | 04:21 PM
Visioneer_one
Here are some more ideas for you.
1. Tie the tail down. This makes it feel safer.
2. I make a piece to hold the plane without a wing. A big wing is a lot to reach around.
This is for engine testing. Remove the specer for smaller planes.
3. Drill some holes in the top for screwdrivers and glow driver.
4. I did not use the original method of holding the TX. That method is a bust.
5. The shelf on the front is really handy.
This stand is at my home. The wheels were added so I can move the stand behing the garage when not in use. Please note the hand hold in the rear to make it easier to pull or push.
Good Luck
Lee
ID:	69323   Click image for larger version
ID:	69324   Click image for larger version
ID:	69325   Click image for larger version
Old 10-22-2003 | 04:26 PM
More photos of the start up Stand.
Lee
ID:	69327   Click image for larger version
ID:	69328   Click image for larger version
ID:	69329   Click image for larger version
Old 10-22-2003 | 06:18 PM
That is a very handy stand there Lee. I like that! I will see if there are any ideas I can incorporate. Especially the one for wingless birds!
Need to see about something for birds without gear! Maybe like RC_Fanatic suggested... Adjustible and/or removable PVC ']' shaped bars long enough to support, say, a Sig Wonder or similar planes... and 1/12 scale combats....
Thanks for the pictures!!
Old 10-22-2003 | 07:17 PM
The materials list in the article is not all correct. I built two for my club and had to buy extra. The author, whose email address is in the article, confirmed that somehow the list when published was incorrect. Regards.
Old 10-22-2003 | 07:30 PM
My Feedback: (19)
LEE BELEW
WE HAVE 6 OF THE ORIGINAL MODEL AT OUR FIELD NEW ONES WILL BE YOUR STYLE PJAMESRC
Old 10-22-2003 | 10:10 PM
PJAMESRC
We have 5 of the original design at our flying field. I will be modifying one of them to install the front shelf.
I have included photos of the flying field. The photos were taken before the startup stands were built.
Lee
ID:	69400   Click image for larger version
Old 10-23-2003 | 10:41 AM
We have 8 tables very similar to this other than building material. Due to the weather we encounter here, it was decided to make the basic frame and uprights out of steel tubing and do the "deck" with plywood. Now we just have to replace the plywood decks every couple years.
Jason
Old 10-23-2003 | 12:44 PM
rc-sport's Avatar
My Feedback: (12)
I built the first one at our club per the instructions in the AMA article. When I showed up with it all the ols timers said "Eh, we don't need those". They tried it out and now we have 8 tables with plans to build 2 more. We added wheels to make them easier to move when we mow. I like the shelf idea, gonna try it.
Old 10-24-2003 | 08:52 AM
My Feedback: (13)
I see the materials list and instructions for assembly on the website but can't find drawings with dimensions on website. Are these only available in MA?
Thanks.
Ray
Old 10-24-2003 | 03:05 PM
For those of you that currently have these in use at your field, do you have any issues with theft or vandalism?
Old 10-30-2003 | 06:05 PM
Here is how I hold the low wing fuselages without the wing.
Lee
ID:	71240   Click image for larger version
ID:	71241   Click image for larger version
ID:	71242   Click image for larger version
