Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Tower System 3000 Rx antenna cut in half
Old 10-23-2003 | 10:03 PM
Default Tower System 3000 Rx antenna cut in half
I have a Tower Hobbies System 3000 Transmitter and receiver. I crashed my plane and the antenna for the receiver was cut in half. I would like to replace it, and I was wondering what the tolerance is on the length of the wire. Also, is there a specification on what kind of wire to use (specifically the guage).
Todd
Old 10-24-2003 | 09:17 AM
Default RE: Tower System 3000 Rx antenna cut in half
Hi Todd,
If you are very good with a soldering iron, and safety consideration (do a COMPLETE and thorough ground check, after for safety purposes) and the warranty are not a issue, you would want to look for 22 gauge wire, and the length will be:
approximately 19 1/2" for surface
approximately 39 1/2" for Air
But, our recommendation is to send the receiver in to be repaired.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
