FP-S134
CA
Hello,
I just recently aquired a plane with a Futaba FP-S134 servo in it.
Can you please tell me the torque rating at 4&6 volts? Also if this a metal geard servo, and when this servo was available? I didn't see in located on the Futaba website..
Thanks for your time,
Craig
Craig
Hi Craig,
Please check the bottom of our servo chart on our website:
http://www.futaba-rc.com/servos/futm0029.html
You will not see of course this servo rated at 6 Volts as it is a discontinued item and was not tested out at 6 volts, but rule of thumb for going from 4.8 to 6 volts is that you will gain around 15% more torque and speed over the normal 4.8 rating.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
