Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9zap cam pak
Old 10-29-2003 | 10:11 AM
vease's Avatar
Default 9zap cam pak
I havn't got the manual in front of me cause I'm at work so I thought I'd ask you lot.
I've got a campak in my zap. last night I, for the first time since installing it last Christmas tried to program a model to a memory above 10. However, although i could scroll and view all possible memory locations I was unable to select any of them above 10.
Any thoughts. I'm guessing it's something simple which I'd find in the manual straight away but as I said I'm at work and it's bugging me!!!
Old 10-30-2003 | 04:41 PM
Default RE: 9zap cam pak
Hi vease,
You might want to try taking the Campac out and reseating it in the transmitter again, it sounds as though the radio is not recognizing it, if this does not help, I would suggest you send the radio and Campac into us so that we can check this out for you.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
