Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Ailevators and 9c
Old 11-02-2003 | 08:51 PM
Josey Wales's Avatar
My Feedback: (61)
Default Ailevators and 9c
I have setup twin elevator servos using the ailevator mix everything is working great. However I want to also try the ailevator feature but dont want it on all the time so Im trying to figure how to assign it to a switch. The only way I figured is to mix channel 2 to channel 8 so the surfaces go the same direction (elevators)
Mix, channel 2 to channel 8, going opposite direction like ailerons..If I do this will they also work as elevators as well??
Old 11-04-2003 | 10:44 PM
My Feedback: (61)
Default RE: Ailevators and 9c
Anyone??
Old 11-05-2003 | 06:48 AM
My Feedback: (16)
You can set the ailevator function to do this. You will see their are two areas. One for Aileron and the other for Elevator. Set up both so that the ailerons and elevators are mixed for their respective functions.
