Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Futaba 9451 servo matching
Old 11-03-2003 | 05:20 PM
flyinrazrback's Avatar
My Feedback: (69)
Default Futaba 9451 servo matching
I am thinking of trying the new Futaba 9451s, do these require the servo matcher to make them work on ailerons, if using 2 per aileron?
Old 11-05-2003 | 11:50 AM
Default RE: Futaba 9451 servo matching
Hi flyinrazrback,
It would be a good idea to use the Servo Synchronizer, as with this you will be able to trim out both servos. And it will keep you from having to make sure that the control linkages are set perfectly.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
